Battery-Powered Bathroom Fan: DIY 12V Fan Project with Faucet Power Supply Integration
pabloben 87495 12
Can I power a bathroom exhaust fan from its own battery or a 12V supply without running a visible cable, and what is the practical way to wire it in a renovated bathroom?
A battery-powered bathroom fan is usually a bad idea because the battery will drain quickly, so the practical solution is to take power from the bathroom lighting or route a cable up with the ventilation duct [#11326905][#11326980][#11341355] If you really need a self-contained supply, you would need a fairly large battery, around 7–10 Ah, plus a charger or a way to swap batteries, which makes it awkward and costly [#11326905] Another suggested option is to pull the power cable up alongside the ventilation hose [#11326980] Since this is a block of flats, you should also check whether adding a fan is allowed at all, because there may be collective gravity ventilation and a fan may not be permitted [#11728300] The original poster eventually concluded that wiring from the light would be the least invasive fix, even if it means disturbing only the ceiling and one tile [#11343147]
  • #1 11326859
    pabloben
    Can any of you do a faucet-powered fan in the bathroom? I do not want there to be a cable from the hole to the socket (I have no way to mask it), and it is too late to lay a new cable under the tiles (the bathroom is newly renovated).
    Can anyone tell me how to make a fan in the bathroom with its own power supply? can somehow deal with 12V fans?
    God bless you in advance. :)
  • #2 11326905
    vodiczka
    Help: 1185
    Rate: 4311
    It makes no sense, the battery will run out quickly, the cost of operation is high. You can pull the cable from the lighting above the level of the tiles, unless you do not have one.
    You can use a battery (at least 7-10 Ah) but you still have to carve a niche for its placement and replace it with a charged one or connect the charger.
  • #3 11326980
    Rico M
    Pull the cable up with a ventilation hose.
  • #4 11327022
    kefir66
    Rate: 10
    A little bit of information, a flat in blocks of flats, a tenement house, a single-family house?
    You can think about hooking up to the lighting.
  • #5 11327061
    vodiczka
    Help: 1185
    Rate: 4311
    What does it matter? If there is no other option, you can take out a few tiles and put them on so that there will be no trace. It was already about connecting to the lighting.
  • #6 11327204
    pabloben
    flat in a block of flats, tiles to the ceiling, nicely smooth ceiling. the closest (from the vent) power supply is quite far - on the opposite wall, it would also be a bit of removing these plates.
    bathroom done a few months ago, so I really want to interfere with this freshwater as little as possible. :)
    if there is any clever way I will gladly use it. and if not - somehow I will have to live without a fan ... ;)
    thanks to everyone for your interest.
  • #7 11338061
    armus
    And so I will ask: what is the finished ceiling? plaster, gypsum, plasterboard, PVC panel? What did you mask the connection between tiles and the ceiling with? Maybe here you can see the possibility of running a power cable?
    No problem :D
  • #8 11340992
    pabloben
    ceiling - plaster and paint. connection of tiles and ceiling - grout. when I was doing the bathroom it seemed that a fan would not be needed. and now, when the shower is much bigger (previously there was a cabin), but the moisture does not "ventilate" ... ;)
  • #9 11341355
    dzimi
    Help: 822
    Rate: 1285
    Maybe pull up the power from the lighting. Turning on the light in the bathroom will also supply power to the fan, there you can use a switch that you will turn on as needed.
  • #10 11343147
    pabloben
    and it will probably have to be done. it will "destroy" only the ceiling and one tile above the fan ...
  • #11 11726648
  • #12 11728300
    Chris_W
    Help: 386
    Rate: 1051
    It should be checked whether the installation of the fan is allowed there. If it's a block, then there may be collective gravity ventilation there - and then it shouldn't be done.
  • #13 12672790
    rosaldo
    Rate: 13
    Once you make the fan, think about how to turn it on.
    These will be more than one tile.
    The ad has been removed.
    Mod Chris_W.
The discussion revolves around the challenge of installing a battery-powered bathroom fan without visible wiring, particularly in a newly renovated space. The original poster seeks advice on integrating a 12V fan powered by a faucet or alternative methods, as running a cable is not feasible due to aesthetic concerns. Responses suggest various solutions, including connecting the fan to existing lighting circuits, which would allow the fan to operate when the bathroom light is on. Some participants recommend considering the installation regulations, especially in multi-unit buildings, and the potential need for future electrical upgrades. The consensus leans towards utilizing the lighting power source to minimize disruption to the newly finished bathroom.
