Best Method to Impregnate MDF Kitchen Worktop Edges for Moisture Resistance & Durability
39579 10
How should I seal the cut edges of a kitchen worktop so they are moisture resistant and durable?
Seal the cut edge with a hard varnish or resin: users report good long-term results with ordinary wood varnish, preferably chemically hardened/urethane, applied after light sanding [#11456366][#16866243] For a stronger moisture barrier, polyurethane wood glue or polyester resin were also suggested, and one user reported success with polyurethane glue around a sink cutout [#16866560][#16868845] Silicone is mainly for sealing the joint between worktops, not for impregnating the raw edge itself, and the edge is often finished with PVC edging or an aluminum strip near wet areas [#11473157][#16868845]
  • #1 11454399
  • #2 11454539
    saskia
    Help: 174
    Rate: 1086
    I do not think that the countertops are made of MDF, but regardless of whether it is or not, the connections of the kitchen worktops are made on the so-called "cookies" in two rows up and down.
    The cup and the holes for them, and the surfaces between the holes, are lubricated with carpentry glue, and the upper 3-4 mm joints are lubricated with silicone of the color of the table top or colorless.
    from the bottom, two screw clamps are inserted into the previously milled sockets.
    Added after 9 [minutes]:
    Bottom view and
    side view
    Green is glue, yellow is "cookies", and black dot is silicone.
  • #3 11455018
  • #4 11456216
    balonika3
    Help: 1334
    Rate: 3754
    I varnished it with ordinary wood varnish. I would like to add that the end of the countertop touches the sink, so there is no shortage of moisture. A few years have passed and nothing is happening.
  • #5 11456366
    brofran
    Help: 650
    Rate: 1406
    It's a good idea to sand the edge before painting. I have applied several times with a chemically hardened varnish - it has been in use for several years. :D
  • #6 11458666
    saskia
    Help: 174
    Rate: 1086
    101pawel wrote:
    saskia wrote:
    I don't think the tops are made of MDF ...
    I wrote from MDF because I think so; these are the most normal worktops available in every hypermarket and furniture store. Here Link to the side with these tops. As for the method of connection itself, in my case the matter is of secondary importance because I will not stick them together - I want to leave the connection as dismantleable. As I wrote, - I am looking for information about the most appropriate preparation for impregnating the edge created after cutting this countertop, this also applies to the edges created when, for example, cutting a hole for the sink. Silicone as a method is repeated many times in various forums, but according to many debaters, it is more a seal than an impregnation. I share this view, therefore I am asking for further suggestions ;) .
    I see; why don't I ask the manufacturer? Because there is no way :(
    These countertops are chipboard.
    If it is to be dismantled, butaprene covered with a strip of gray paper works best.
    If the cut surface is even, you can veneer with a strip of veneer attached to the top, but as I wrote, butaprene works best with veneer, but thin enough to fit the shavings well.
  • #7 11473157
    Sołtys_Elbląga
    Help: 113
    Rate: 564
    Butapren does not help, even two layers, water will seep through. Usually, the back, side or 3 sides (not counting the curvature at the front) are glued with Rajman glue (hot) and a PVC edge saw. The paper under the table top is simply an advertisement for the company where it was produced. Before they are clamped, the joined tops should be stuffed with silicone, spread with a finger over the entire surface, both of them, and then firmly connected with screws. Of course, collect the excess silicone.
  • #8 16866126
    droopi
    Rate: 18
    Only and exclusively WATER GLASS. The wood sticks them in like water and when it dries it is like a clearcoat. There is NO better way.
  • #9 16866243
    wada
    Help: 168
    Rate: 732
    Any varnish for wooden floors is good for impregnation - you just have to be careful with water-based ones, because the board swells a bit during painting, and after the first painting, lightly sand the swollen chips.
    Elefant
    Wagonowa 34, Wrocław, 52-231 | Company Website: literyzmetalu.pl
  • #10 16866560
    Parowy
    Help: 55
    Rate: 227
    I used a polyurethane wood glue from the Soudal company, symbol probably 66 A.
    I secured it with the edge of the hole for the sink, in the most ordinary cake top.
    So far nothing is happening, a year has passed.
  • #11 16868845
    cezar80
    Help: 94
    Rate: 67
    Soak it with polyester resin and it will be eternal, or if you look around, there are aluminum strips for joining plates or their edges, e.g. near the sink or kitchen.
The discussion centers on methods to impregnate the edges of MDF kitchen worktops for enhanced moisture resistance and durability. Various techniques are suggested, including the use of wood varnish, polyurethane wood glue, and polyester resin. Participants emphasize the importance of sanding the edges before application and recommend using silicone for sealing joints. Some suggest that water glass provides superior impregnation, while others caution against water-based varnishes due to potential swelling. The conversation also touches on the use of aluminum strips for edge protection and the effectiveness of butaprene adhesive. Overall, the consensus is to ensure thorough sealing and impregnation to prevent moisture damage.
