Compatibility of LTA230W2-L01 Matrix with Samsung LE23R32BX / XEH, T230XW01 V1
karelkarel 3303 5
  • #1 11604636
    karelkarel
    Rate: 66
    I would like to make sure that I can insert the LTA230W2-L01 behind the T230XW01 V1 matrix. I have the opportunity to buy one.
  • #2 11604708
    conan02
    Level 30  
    Help: 174
    Rate: 91
    There may be a problem, the LVD signal is not compatible. Pin 20 AUO - original matrix has unconnected, Samsung has GND in this place. If the lack of this connection does not affect the operation, you can risk a change.
    Datasheets are here: T230XW01 and LTA230W2 .
    You can compare the data.
    Komputer Serwis
    Lwowska 147, Nowy Sącz, 33-300 | Tel.: 602-XXX-XXX (Show)
  • #3 11604933
    karelkarel
    Rate: 66
    Datasheets have been browsed before, but I wanted to make sure before buying.
  • #5 11605386
    satgal
    Level 40  
    Help: 482
    Rate: 428
    Both matrices are interchangeable without any modifications.
  • #6 11608463
    karelkarel
    Rate: 66
    I thank my colleagues for the quick answer.
