Samsung LE26A451C1 replacement of T-CON T260XW02 VL01 board with another one
Paweł Gracjasz 4406 5
  • #1 10753107
    Paweł Gracjasz
    Rate: 8
    Hello, as in the subject whether it is possible to swap T-CON T260XW02 VL01 CTRL BD board with T260XW02 VA CTRL BD board
  • #2 10754078
    lisek
    Service technician RTV
    Help: 6332
    Rate: 6843
    T260XW02 VL Matrix
    T-con T260XW02 VL01 CTRL BD (26T02-C01)
    on: AUO-039, M12L64322A, AS15-F, dc-dc: TPS65161
    Link_ foto
    T315XW02 V9 / T260XW02 VA CTRL BD (06A53-1C)
    _____________
    They differ in the elements on the right (seen from the elements side) ie DC_DC converters
    By. I do not like it!
    ps
    But you can always try, someone must be the "first" ?!
  • #3 10757025
    Paweł Gracjasz
    Rate: 8
    I think so too, but maybe my colleague knows what transducer is sitting in this second PCB (VA) it would be possible to compare these transducers, because this AS15-F (EC5575) (TSL1014) is described on the "datasheet", maybe it would be something it helped
  • #4 10762353
    maniek2591
    Level 19  
    Help: 19
    Rate: 91
    hello, I will move on to the subject - I have mistakenly replaced these logics and after fuse the fuse and stabilizer on the Samsung motherboard flew out, I also do not recommend
    I would remind you that the correct spelling rules apply to this forum. The regulations of item 3.1.13, item 3.3. [lamer.]
  • #5 10768029
    Paweł Gracjasz
    Rate: 8
    thanks to my colleagues for closing the topic
  • #6 10768089
    radsat
    Moderator
    Help: 470
    Rate: 209
    So the swap thread? Sentences start with a large letter, end with a dot. At the end, click the "padlock".
