How to change cell background color in Excel 2007 VBA if value starts 'HIGH'?
zbyszekz660 20970 5
  • #1 11738650
    zbyszekz660
    Please help me solve the problem using VBA (Excel 2007)
    I have a range in which some data is entered in some cells. I would like the macro to search for cells whose values begin with "HIGH"
    E.g
    FROM HIGH 500
    FROM HIGH 501
    FROM HIGH 502
    FROM HIGH 503
    The attached macro works for me but if in the IF loop I specify the exact value of the cell and not just part of the text
    Sub polaczone()
        For Each kom In Range("l4:l3000")
       If kom.Value = "Z WYS" Then
                kom.Interior.Color = RGB(255, 0, 0)
            End If
        Next kom
    End Sub
    I know how to do it using conditional formatting but the code is part of a more complex macro and I would like to implement it in VBA code
    Thank you in advance for your help
    Regards
    Zbyszek
    marek003
    Level 40  
    Help: 801
    Rate: 488
    Enter another condition:
    Code: text
  • #3 11739105
    zbyszekz660
    Cool! it works thanks for your help
    I have one more question
    The loop below searches a range of cells in column A and when it finds a specific value it changes the background color for the entire row.
    Is it possible to limit row selection to, for example, the first 15 cells of a given row
    Code: text
    I am slowly learning the VB language, but there is still a lot to learn ahead of me.
  • #4 11739128
    yogi009
    Help: 848
    Rate: 2655
    You can also do this with conditional formatting.
    marek003
    Level 40  
    Help: 801
    Rate: 488
    try this (I write without checking - but it should work)
    change the line of code "With..." on:
    Code: text
  • #6 11739175
    zbyszekz660
    Theoretically, I can do it by conditional formatting, but as I wrote earlier, it is only part of a more complex macro. This macro is attached to the form under the CheckBox control, so for now conditional formatting is off
    Added after 53 [minutes]:
    change the "With..." line of code to:
    Visual Basic Code - [expand]
    With Range(Cells(Row cell,1),Cells(Row cell,15)).Interior
    It works great. thanks for the help.
