Break vector definition and usage in microprocessor interrupt handling systems
rezontor 12387 7
  • #1 11821653
    rezontor
    Rate: 13
    What is a break vector?
  • #2 11821678
    tadzik85
    Help: 415
    Rate: 16
    Maybe please clarify your question?
  • #3 11822568
    rezontor
    Rate: 13
    I corrected it, it was about the INTERRUPT VECTOR. Is it just an interrupt name - e.g. RESET, INT0 ...?
  • #4 11822604
    BlueDraco
    MCUs specialist
    Help: 939
    Rate: 421
    Most often, this term denotes the address of the interrupt handler, which is contained in an array somewhere in memory.
    piotrva
    Help: 625
    Rate: 734
    The processor interrupts work in AVR processors on the basis that (excluding other operations) after a given interrupt ( when operated by the processor ) the command is saved the next one that would have been executed if the processor had not accepted the interrupt (its address in flash) and jump to one of the addresses from the very beginning of the flash. This given address is called the interrupt vector, i.e. the address at which the instruction counter jumps when the interrupt occurs. In place of this vector, enter a jump instruction to the point where the interrupt is handled.
    The case is best seen at ASM. This program only supports one interrupt (TIM0_COMPA).
    If you have questions, I will explain the details of this code and issues ;)
    { remarks written in italics from a colleague of BlueDarco }
    [syntax=asm]
    * Created: 2012-07-12 10:32:21
    * Author: Piotr
    ;dołączenie definicji procesora
    .include "tn10def.inc"
    ;nazwa dla rejestru tymczasowego (x2)
    .def temp = R17
    .def temp2 = R18
    ;nazwa dla zmiennej licznika
    .def ct = R19
    ;tablica przerwań (wektorów przerwań) jest umieszczona na samym początku pamięci flash (rozkazów). Zawsze pod adresem 0x0000 znajduje się wektor RESET który jest wywoływany przy starcie programu. Kolejne początkowe adresy (zgodnie z modelem procesora) zajmowane są przez wektory innych przerwań.
    .org 0x0000
    rjmp RESET ;RESET
    reti ;INT0
    reti ;PCINT0
    reti ;TIM0_CAPT
    reti ;TIM0_OVF
    rjmp TIM0 ;TIM0_COMPA
    reti ;TIM0_COMPB
    reti ;ANA_COMP
    reti ;WDT
    reti ;VLM
    reti ;ADC
    ;po resecie procesora
    RESET:
    ldi temp,low(RAMEND)
    out SPL,temp
    ldi temp,high(RAMEND)
    out SPH,temp
    ;ustawiamy PB2 jako wyjście
    SBI DDRB,PB2
    ;timer w tryb CTC, preskaler 1
    ldi temp,(1
    BlueDraco
    MCUs specialist
    Help: 939
    Rate: 421
    Not "upon occurrence", but "upon receipt", but rather "in operation" (by the processor, not to be confused with programmatic operation).
    Not "currently executing", but "the next one that would have been executed if the processor had not accepted the interrupt".
    These are two quite significant differences.
    And not necessarily "from the very beginning of Flash".
    kamyczek
    Help: 394
    Rate: 569
    Or, otherwise, an interrupt is the occurrence of a specific event. The interrupt vector is a place (physical address in the program memory to which the microcontroller goes after a specific event occurs) generalizing the vector table usually contains only jumps to the interrupt handlers.
    So more vividly you sit in front of the computer and click on the post, at some point you need to go to the toilet (this is an interruption) its vector is the toilet but there it turns out that there is a voltage failure on the door in the second building so you rush to another building (this is the address of the interrupt jump) and the handler will guess for yourself. I hope nobody will ride for it, although it's a slight offtop ;)
    piotrva
    Help: 625
    Rate: 734
    As for the first two remarks - I agree, I added specific quotes in the appropriate places.
    As for the last one, yes, I have already explained that it is usually the beginning of the flash memory, but in specific cases (specifically when setting the IVSEL bit in the MCUCR register in processors where this bit is available) it moves the beginning of this table to the address where it begins Bootloader. And as you can guess, this setting is used primarily when writing Bootloader. Then the reset vector is set to the address where we start the bootloader.
✨ A break vector, often referred to as an interrupt vector, is the address in memory where the processor jumps to execute an interrupt handler when a specific event occurs. This address is part of a vector table that contains pointers to various interrupt handlers. In AVR processors, upon receiving an interrupt, the current instruction is saved, and the processor redirects to the interrupt vector address. The discussion highlights the importance of understanding the distinction between the next instruction to be executed and the actual operation of the processor during an interrupt. Additionally, it notes that the location of the interrupt vector can vary based on specific configurations, such as the IVSEL bit in the MCUCR register, which can redirect to a bootloader address.
