Crack the Code: Understanding VCC, VSS, VAC, VDC and More for Electronics Beginners
Ender 45030 7
  • #1 527555
    Ender
    Rate: 15
    I am a beginner "electronics" :D and looking for information on the markings found in the schemes: VCC VDC VAC VSS etc. What exactly do they mean (but this voltage I know :D ) and what are the differences. Thanks in advance for your help.
  • #2 527912
    adi-niunio
    Help: 9
    Rate: 33
    Vac - alternating voltage (alternating)
    Vdc - constant voltage
    Vcc - supply voltage (most often integrated circuits and bipolar transients
    Vss - nap. power supply of field effect transistors
    you wrote the post as if you needed the whole paper about it ;)
    I wrote after the post from the electrician: it is just like a colleague writes, other signs are + U, + Ucc, Vdd, in general, it is a power supply.
  • #3 528126
    elektryk
    Help: 439
    Rate: 241
    In fact, each designer has his own markings as to the mass and supply voltage, they are practically any sequence of letters. VCC, VDD, + 5V, AVCC ......
  • #4 528897
    Preskaler
    Level 40  
    Help: 492
    Rate: 1057
    I also encountered the designation Vss - as the peak-to-peak voltage (with 230V mains voltage it is about 800Vss).
    This is due to the peak voltage of + 400V and -400V.
  • #5 529270
    adi-niunio
    Help: 9
    Rate: 33
    no inter-peak voltage is also denoted as b, often Vpp peak-peak
  • #6 529280
    Preskaler
    Level 40  
    Help: 492
    Rate: 1057
    New Fashion! From the English Vpp. Formerly in Polish Vss (peak-peak).
  • #7 530021
    Ender
    Rate: 15
    Thank you very much :D now everything is clear but since I have already started this topic, I have a question whether there are any other frequently encountered and not yet clear indications of voltages or currents (if not, sorry for poisoning the ass :D )
  • #8 530082
    adi-niunio
    Help: 9
    Rate: 33
    in my opinion, it is best to ask on an ongoing basis when you find something and you will not know (you will not be sure), etc.
The discussion focuses on the meanings and differences of various voltage designations commonly encountered in electronics, such as VCC, VDC, VAC, and VSS. VCC typically refers to the supply voltage for integrated circuits, while VDC denotes constant voltage. VAC indicates alternating voltage, and VSS is often associated with the negative power supply in field-effect transistors. Participants note that different designers may use varying notations for voltage and current, including terms like VDD and AVCC. The conversation also touches on the concept of peak-to-peak voltage, with Vpp being a common designation. The author expresses gratitude for the clarifications and inquires about other voltage or current designations that may be less familiar.
