Liquid Sealant for Sewage Pipes: Fix Small Leak in Toilet Drain - Plaster & Tile Covered
veder1 45945 16
How can I seal a small leak in a toilet drain pipe when the pipe is built into plaster and tiled over, so I cannot pull it out?
There is no reliable liquid sealant you can just pour into the drain to fix this; if you can reach the leak, clean the area, dry it, degrease it, and use a good PVC/sewer pipe glue on the joint [#11964897][#11965219] If the leak is at the collar gasket, it will not “stick” shut, so the proper fix is to access and repair the joint rather than hope for a poured-in sealant [#11969246] If there is no access, the only real solution is to make access by cutting out some grout/plaster, or have a plumber do it [#11973126][#11969246] One reply also noted that if the issue is actually a blockage causing water to linger, caustic soda may help, but it is not a true leak sealant [#11965219]
  • #1 11962063
    veder1
    Rate: 47
    Hello, I have a problem, there is a small leak in the sewer pipe, i.e. after draining the water from the toilet, a small wet spot appears under the pipe, unfortunately I cannot pull the pipe out because everything is covered with plaster on which the tiles are placed (flush for installation) is there any a type of sealant that will seal the pipe when poured into the pipe?
  • #2 11962080
    DJ_Dexinter
    Help: 90
    Rate: 218
    Caustic soda. You just have to be careful with that.
  • #3 11962103
  • #4 11962193
  • #5 11962282
    veder1
    Rate: 47
    then you could write to me how to do it ....? just pour caustic soda into the shell?
  • #6 11962292
  • #7 11962830
    veder1
    Rate: 47
    Well, what will seal the tiles, I will not take apart ........?
    water glass....?
  • #8 11962941
  • #9 11963731
    DJ_Dexinter
    Help: 90
    Rate: 218
    Choler I was lightly drunk and read "Draining" instead of "Sealing"
    I had a leak once, a plumber (Mr. Kaziu) came and bought some sealing compound. She looked and smelled like Butaprem. It was a can, and a tube with a fixative was stuck to it on the tape. He ordered nothing to be poured into the shells etc 2 days before. Later, he unscrewed the toilet bowl and poured the mixed mass with the fixative there. Unfortunately, Mr. Kaziu is already dead, so I can't ask what this "magic mass" is ...
    Added after 4 [minutes]:
    And he poured it with a bowl on a wire so as to fill the pipe with the mixture halfway up, but if he wanted it and it would flood it all.
    Moderated By _PREDATOR_:
    I warn you!
    PW
  • #10 11964154
    veder1
    Rate: 47
    Hello, if you have any idea what this specific is called, let me know, so far I have put the foil under this leak ...
    How do we start a new sentence / how do we end the interrogative sentence / spelling?
    Please improve on all your posts!
    [_P_]
  • #11 11964897
    zibq
    Help: 83
    Rate: 181
    If you have access to this area, after removing the toilet seat, clean the area, dry it, degrease it and use a good PVC glue.
    Forget there is a magic agent that will find the leak by itself.
    If there is no access, this place must be accessed ...
  • #12 11965219
    saskia
    Help: 174
    Rate: 1086
    This access should be made during the assembly of the flush and the housing.
    The fact that it is a built-in cistern does not mean that it can be filled completely.
    If it is definitely a leak on a sewer pipe, if you find a leak and go there by hand, you can apply sewer pipe glue on the top. The second thing is that in order for there to be a leak in the sewage system, there would have to be a crack in the pipe, which is unlikely, so I suspect that the sewage system is clogged, which causes the water in the pipe to remain in the pipe for a longer time and leak.
    In that case, caustic soda might help.
    I also suppose that it is a leak on the cistern pipe (gland joint under the cistern) and water is dripping onto the sewage pipe.
  • #13 11968981
    veder1
    Rate: 47
    Hello, the leak is exactly in this place ... and I am without any counsel on this leak ....
  • #14 11969246
  • #15 11973119
    veder1
    Rate: 47
    I know that the work is light, but how to reach this seal?
  • #16 11973126
    Samuraj
    Help: 286
    Rate: 619
    If you feel sorry for the tiles, chose the joint and cut the plaster.
  • #17 11995910
    veder1
    Rate: 47
    over time, it seals itself with impurities ... ;) thank you ;)
The discussion revolves around a small leak in a sewage pipe connected to a toilet, which is inaccessible due to plaster and tiles. Users suggest various solutions, including the use of caustic soda, which is known for unblocking pipes but may not effectively seal leaks. One user recalls a plumber using a sealing compound that resembled Butaprem, applied through the toilet bowl. Others recommend cleaning and applying PVC glue if access is possible, while some suggest that the leak may be due to a clogged system rather than a crack in the pipe. The conversation highlights the challenges of sealing leaks in hard-to-reach areas and the potential for natural sealing over time with debris accumulation.
