Sharp LC32LE600E – no response to remote/local keypad, missing 12V?
jacek07 4356 9
Why does a Sharp LC32LE600E have no response to the remote or local keypad and no 12V present on the PL connector?
The missing 12V is generated by the power supply, so if it is absent on the PL connector the power supply should be checked first, not the service menu [#12096436] [#13078111] To enter service mode, the keys must be held down while switching the TV on at the mains, not the other way around [#12098853] In the end, replacing the power supply solved the problem [#13077800]
  • #1 12096124
    jacek07
    TV Sharp Lc32Le600e no response to the remote control and local keyboard.
    After connecting to the power supply, the red LED lights up.
    You can not enter the service mode -V and input.
    I have measured the voltage coming out of the power supply and only 12V is missing on the PL connector.
    Will this voltage be in standby status? The diagram shows that the control signal PNL POW comes from the processor on IC7502 12VREG.
    It is strange that the TV does not report any errors.
    Do you have any advice on where to start?
    Greetings,
    Jack
  • #2 12096436
    Jakant
    Help: 260
    Rate: 123
    [quote = "jacek07"] You can not enter service mode -V and input. [/ quote
    And what do you want to look for in service mode? 12V is made in the power supply and you do not need to enter the service mode to find it.
  • #3 12096448
    jfranc
    User under supervision
    I do not see anything strange in this.
    Start by looking for a professional.
  • #4 12098364
    lamer.
    Help: 138
    Rate: 49
    jfranc wrote:
    E there, immediately a professional .... And the forum is from what? Unless to help myself, is not it?
    You have to wait for a friend of fisk, something reported that he has some kind of workload or something. As soon as it appears, it probably sends a constructive link.
  • #5 12098853
    satgal
    Level 40  
    Help: 482
    Rate: 428
    Keeping these keys pressed, only switch to the network and not the other way round.
  • #6 13077800
    jacek07
    Replacing the power supply solved the problem.
    I think about the subject as closed.
  • #7 13078111
    mirex
    Help: 1950
    Rate: 1990
    jacek07 wrote:
    I think the topic is closed.
    And I do not, as you can see.
    Plate exchangers do not have to assume topics on the forum.
    Help them is also unnecessary! I would even say that it is not recommended. ;)
    jacek07 wrote:
    jacek07 wrote:
    voltages coming from the power supply and only 12V is missing on the PL connector.
    Big problem, just in time for the module replacement.
  • #8 13080203
    jacek07
    You had to say what the problem was and not comment on mirex.
    Fortunately, there are people on this forum who sometimes help and probably just because this forum is still functioning. Unfortunately, from what you can see, there are less and less of them.
    Greetings and I wish you a Merry Christmas.
  • #9 13874972
    Szymanski Jan
    Jacek wrote well, this is a forum and forum members should help each other.
  • #10 13874994
    mirex
    Help: 1950
    Rate: 1990
    Where have you been Szymański so far? I can see that you have been very active during these seven years. . ;)
The discussion revolves around a Sharp LC32LE600E television that is unresponsive to both the remote control and local keypad. The user reports that after powering on, the red LED lights up, but they cannot access service mode or input commands. They measured the power supply and noted a missing 12V on the PL connector, questioning if this voltage is required in standby mode. Responses suggest that entering service mode is unnecessary for troubleshooting, and one user eventually resolved the issue by replacing the power supply. The conversation highlights the importance of community support in troubleshooting electronic devices.
