Sharp LC-32LE244E TV: Unresponsive After Software Update with Solid Red Power Light
arkadiusz kulik 10629 12
  • #1 16415337
    arkadiusz kulik
    I greet everyone. I was updating the software of the above-mentioned receiver with a pendrive, everything was ok. At the very end of the operation, the message "the TV will turn off and restart" popped up. Noooo ... it shut down and that's it! It does not respond to buttons or the remote control. The power light is solid red. I have a question - is it possible to do something at home or just a service? Once again, Greetings to everyone.
  • #2 16423905
    JARPAW7500
    Rate: 30
    Hello. If you entered the correct model, it is SHARP tv. What software version have you uploaded?
  • #3 16428446
    elektrostarman
    I think you've uploaded the wrong soft. Try to unplug it and turn it on again. if that does not help, then upload the correct soft via the service connector using a cable ...
  • #4 16431197
    arkadiusz kulik
    I am so sorry! I typed the stupid things, sharp, of course. I was playing soft 1. 11 [04.03.2013]. I understand that if via a service cable, it's only a service.
  • #5 16431297
    elektrostarman
    As you can yourself, why not only can you have a problem with this cable
  • #6 16431671
    arkadiusz kulik
    Thanks for showing interest. I don't know what cable it is about. And it will not go through the usb cable?
  • #7 16431778
  • #8 16431802
    elektrostarman
    no, that's different.
    Added after 6 [minutes]:
    Try to enter the service mode again:
    1. Turning off the working receiver from the socket - pressing V- and INPUT and inserting the power cord to the socket with the above-mentioned buttons on the local keyboard pressed.
    Moderated By telesat1:
    Warning.
    3.1.11. Don't post messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
  • #9 16433580
    arkadiusz kulik
    I have tried all possible combinations of buttons, including buttons on the remote control. The receiver is still "brick".
  • #10 16435735
    JARPAW7500
    Rate: 30
    Try to load this file from the pen and let me know.
    • xx_LEx44_105_REV00.bin (3.99 MB) You must be logged in to download this attachment.
  • #11 16438290
    arkadiusz kulik
    Welcome. I tried, the pendrake won't even blink. I tried with another pen, same thing. An ordinary corpse. The computer detects the TV as a different monitor, except that it cannot detect the name.
  • #12 16441884
    rob1
    Help: 68
    Rate: 139
    You need to insert the programmed memory (this tv had 2 matrices used), the batch must be under the appropriate one.
  • #13 16442623
    arkadiusz kulik
    So home remedies - milk with garlic for colds. I'll give a professional to earn. Let the baker bake bread, and let the bricklayer build houses. Thanks for the advice. I greet everyone. I close the topic.
✨ The discussion revolves around a Sharp LC-32LE244E TV that became unresponsive after a software update, indicated by a solid red power light. The user attempted to update the software via a USB drive, but the TV failed to restart as expected. Responses suggest that the user may have uploaded incorrect software and recommend unplugging the TV and trying to restart it. Some users mention the need for a service cable to upload the correct software, while others suggest entering service mode by pressing specific buttons during power-up. The user reports unsuccessful attempts to revive the TV, including trying different USB drives. Ultimately, the user expresses frustration and considers seeking professional repair services.
