Understanding VCC in Integrated Circuits: Novice Designer's Guide to LM324 Pin Designation
XXXc 50943 4
  • #1 1251125
    XXXc
    Help: 6
    I am a novice designer and I have such a stupid question. What does the VCC abbreviation mean on the pins of the scalers? I met this designation in the description of the pins of the elements (e.g. in LM324).
  • #2 1251160
    ACULA
    Help: 105
    Rate: 114
    supply voltage
  • #3 1251184
    XXXc
    Help: 6
    supply voltage, i.e. (+)
    then GND stands for (-) or mass?
  • #4 1251209
    Pi-Vo
    Level 37  
    Help: 319
    Rate: 207
    Minus can also be labeled Vdd and GND stands for Ground or ground.
  • #5 1251211
    Jethro
    Help: 28
    I will throw in my 3 cents and say that apart from VCC, GND you will also meet VEE one day. It is used for symmetrical power supply of some integrated circuits, ie it can be, for example, VCC = + 5V, GND = 0V, VEE = -5V.
