Question: Composition & Lifespan of LCD Panel Liquid: Maintenance & Potential Issues
abou jaafar 7101 11
What is the liquid crystal in an LCD panel made of, does it have a limited lifespan, and can it cause panel problems?
An LCD panel does not use one single liquid; many different materials are used in LCDs, and the exact panel technology details are often not shared by the TV maker [#12148349] The liquid-crystal layer is the active part of the display: its molecules behave like a liquid while having a solid-like molecular structure, and the panel uses backlighting because the crystals do not emit light themselves [#12387812] Its life is generally declared as tens of years, and it is expected to last longer than the TV receiver itself, though there is no hard proof because the technology is relatively young [#12148349] For maintenance, avoid wet washing, force, and scratching, and use only cleaners recommended by the TV manufacturer [#12148349]
  • #1 12148265
    abou jaafar
    Rate: 32
    hi for all
    this question can help us for good maintenance with lcd tv .
    that liquid on pannel , from what its made ? and did she have life limits and die ?
    did she make trouble on pannel ?
    thank you all for sharing .
    LCD lifespan is uncertain; avoid moisture, force, and scratches
    #2 12148349
    Rzuuf
    Help: 1355
    Rate: 1700
    Hi, Abou, ! صباح الخير
    There are lot of different materials used for LCD's, read here: http://www.madehow.com/Volume-1/Liquid-Crystal-Display-LCD.html (text slighty obsolete). Every year thousands of new materials for LCD's are elaborated, some of them come to the production.
    The producer of TV's frequently is not producer of the screen itself, and details about technology are not shared.
    The life of LCD's is declared as tens of years, but there is no "hard" proof, because this technology is relatively young (in except of b/w screens in calculators and watches). You can expect the life of LCD as much longer than the life of TV receiver (or even a transmission standard).
    Good maintenance? It's simple: no wet washing (لا ماء), no force (لا المطرقة) & no scratching (لا الرمال)! Some cleaners are commonly accessible (read recomendations of TV' producers).
  • #3 12152630
    abou jaafar
    Rate: 32
    thank you my freind and thx for arabic lang .. how did you know the lang ?
  • #4 12152871
    Rzuuf
    Help: 1355
    Rate: 1700
    كنت أعمل السنوات القليلة في ليبيا
  • #5 12157289
    abou jaafar
    Rate: 32
    And you from where ?
  • #6 12157607
    Rzuuf
    Help: 1355
    Rate: 1700
    I'm polish, but I've spend many years in different countries and therefore I know many languages. Now I'm old and retired ...
  • #7 12158090
    abou jaafar
    Rate: 32
    you are lucky man , i have 35 years and still stuck here .
  • #8 12159638
    Rzuuf
    Help: 1355
    Rate: 1700
    You're a lucky man, you're young!
    When I was in your age (40 years ago) I was 'stuck' much more!
    There was no Internet and I didn't know any "international" language (in except of russian ...).
  • #9 12166481
    abou jaafar
    Rate: 32
    I'm sorry can i send pvt msg for you to tell about your story ?
  • #11 12387812
    sharjeel
    The molecular structure of a liquid crystal matches that of a solid, but its molecules behave like a liquid. As a result, liquid crystals are at the heart of an LCD television. With backlighting (the crystals emit no light of their own), the millions of crystals in an LCD television provide a sharp, high-resolution color picture for their owner.
  • Asking how liquid crystals control light transmission
    #12 12403973
    abou jaafar
    Rate: 32
    sharjeel wrote:
    The molecular structure of a liquid crystal matches that of a solid, but its molecules behave like a liquid. As a result, liquid crystals are at the heart of an LCD television. With back lighting (the crystals emit no light of their own), the millions of crystals in an LCD television provide a sharp, high-resolution color picture for their owner.
    thx for replay
    can you tell me how the liquid crystal work ? i mean : how let the light in and when ? and how cut't off ?
The discussion centers on the composition and lifespan of the liquid used in LCD panels, emphasizing that liquid crystals have a molecular structure akin to solids but behave like liquids. The lifespan of LCDs is generally expected to be several decades, although definitive proof is lacking due to the relatively recent development of this technology. Proper maintenance is crucial, including avoiding wet cleaning, excessive force, and scratching. The responses also touch on the role of liquid crystals in producing high-resolution images in LCD televisions, which require backlighting as the crystals do not emit light on their own.
