[Solved] Electric tankless water heater – what kW is enough for a shower?
karopik 70833 36
How much power should I choose for an electric instantaneous water heater so I can shower without getting cold?
For a comfortable shower, 5.5 kW is only marginal: one reply says it is enough to avoid being cold, but it will not feel warm or comfortable [#12289616], while others say a 5.5 kW unit gives only a weak stream and that 18 kW three-phase is what provides full comfort and warm water [#12290559][#12290289] If you only have a single-phase supply, remember that the practical limit is about 5.7 kW, and a typical 16 A installation is around 3.5 kW, so a stronger heater may require converting to three-phase and checking the wiring and protections first [#12290427][#12294931] The exact required power depends on your water flow and the inlet water temperature, which can be as low as 5°C in winter [#12289998][#12294240] One practical way to estimate it is to measure how long it takes to fill a 10 L bucket with the shower flow and what the water temperature is, then calculate from that [#12289998] In short: 5.5 kW is the bare minimum, but for a truly comfortable shower the thread points to roughly 18 kW three-phase if your installation can support it [#12289616][#12290289]
  • #1 12289436
    karopik
    Rate: 91
    How much power should I buy an electric instantaneous water heater so that I can shower without fear of getting cold.
  • #2 12289523
    mauri_b
    Heating systems specialist
    Help: 109
    Rate: 529
    As large as possible to be installed in your electrical installation.
  • #3 12289568
    karopik
    Rate: 91
    I am looking for a 1-phase one, I do not know if, for example, 5.5 kW will heat the water.
    Above, I would have to convert the installation to a 3-phase one.
  • #4 12289616
    vodiczka
    Help: 1185
    Rate: 4311
    5.5 kW is enough, there will be no warmth, but you will not be cold.
  • #5 12289631
    karopik
    Rate: 91
    Do you have such power at home?
    I am looking for a practically proven heater.
  • #6 12289655
    vodiczka
    Help: 1185
    Rate: 4311
    Kuzyn had such and 3.5 kW for the sink. Complained that the shower was a bit too cold but it was bearable.
  • #7 12289998
    William Bonawentura
    Help: 190
    Rate: 619
    Take a 10l bucket and a thermometer. Give the shower that you currently need to wash well and comfortably from your current shower. Measure in how many seconds you will fill a 10l bucket with it and what is the water temperature. With this data, the required power of the flow heater can be determined.
  • #8 12290049
    karopik
    Rate: 91
    Okay, I'll try tomorrow, does the inlet water temperature matter?
  • #9 12290289
    Tornadoo
    Rate: 10
    I have had an 18kW three-phase heater for several years and this is it. Full comfort and warm water. There is an "economy" switch on it and then it consumes less electricity, but it sneezes because the water pressure is poor.
  • #10 12290427
    omen600606
    Help: 14
    Rate: 51
    Wait a minute, buddy. If you want a 5.5kW heater, and you have phase 1, do you want to turn off almost everything at home for the duration of a shower? 1 phase has a maximum of 5.7 kw, which is about 200 Watt, you have a receiver. It is, for example, in one room a 60 W bulb and, for example, a 75 W bulb in the bathroom, which already gives 135 W. Let's add a refrigerator that is always on and TV / household appliances on standby. This puts you on the verge of endurance. Have you thought what will happen when your pre-meter protection breaks down while you are in the shower? If I were you, I would consider 3 phases or preferably an electric boiler heated on the night (cheaper) tariff. I had to give up the heater myself in favor of the 80-liter boiler, due to the fact that I have phase 1. Let me just say that this boiler is enough for two people and washing the dishes :D
  • #11 12290559
    kwantor
    Help: 352
    Rate: 1227
    A shower with such a 5.5kW heater is naturally possible, but it will not be a delight, but just messing with a stream with the power of a medical syringe.
    18 kW as much as possible.
    That is why boilers were invented when someone does not have power conditions.
  • #12 12292589
    vodiczka
    Help: 1185
    Rate: 4311
    Boilers have been produced for years, when no one was thinking about inventing instantaneous water heaters.
    omen600606 wrote:
    Let's add a fridge that is running all the time
    It's not, unless it has a broken thermostat.
  • #13 12292861
    kwantor
    Help: 352
    Rate: 1227
    I did not write that boilers are an alternative alternative to flow heaters - they are produced, were and will be, I do not need to write why.
    Let me just mention that one of the undisputed features is the possibility of accumulating a large amount of highly heated water in the conditions of a small electrical power allocation.
    I have pointed out to the author the only sensible source of hot water with non-choked outflow using electricity for his situation if he wants to take a pleasant shower.
    Not true, there are times when a refrigerator with a freezer compartment runs for several hours non-stop.
    The stickiness and spite of the users, who rarely bring anything substantive to the topics, is the cause of the usual clutter of the forum.
    I do the moderators here.
    The question is in the subject - I know the topic from the practical side, I provide helpful information - this is the message.
    Greetings.
  • #14 12292909
    vodiczka
    Help: 1185
    Rate: 4311
    kwantor wrote:
    I have not written that boilers are an invented alternative versus flow heaters
    You wrote: "That is why boilers were invented when someone does not have the power supply".
    How should I understand that? Forgive me, I'm not picking on it, but I understand it unequivocally - boilers were invented for those who do not have power conditions.
    A few hours is a long job, but not "all the time"
  • #15 12293042
    kwantor
    Help: 352
    Rate: 1227
    Still the same..
    How does it affect whether a few hours, 10 min. or 24 hours a day in terms of bathing?
    That is why boilers were invented (among others) when someone does not have the power conditions. for the installation of a high-power heater.
    So if I wrote that with the additions in bold, there would be no problem?
    Heh ..
  • #16 12293594
    vodiczka
    Help: 1185
    Rate: 4311
    kwantor wrote:
    Heh ..
    And I thought that (electric) boilers were invented so as not to bother and get dirty when handling coal or wood-fired boilers. :D And they were invented in times when households did not have (or were to a small extent) three-phase power supply. And only after the spread of three-phase power supply, small-size, high-power flow heaters were invented as an alternative to electric boilers.
    In fact, it has no effect because taking a shower does not last longer than 10 minutes and during this time a slight exceeding of the rated load of the network (due to the fact that the refrigerator unit does not turn off) will not work.
    fuse.
  • #17 12294022
    kwantor
    Help: 352
    Rate: 1227
    It is not true, it is a water reserve that allows you to be independent of the time of energy supply, it can even be coal .. it also allows you to save various types, including the use of the night tariff.
    As for point 2, you have to sit by the fridge and wait for it to turn off and then run to the bathroom .. ??
  • #18 12294240
    William Bonawentura
    Help: 190
    Rate: 619
    It has, but the worst value is taken for the calculations, i.e. 5 degrees in winter.
  • #19 12294708
    vodiczka
    Help: 1185
    Rate: 4311
    No need, I admitted you were right that the working time of the refrigerator does not matter because the power consumed by the aggregate is not large and it will not blow the fuses, let alone the pre-meter protections, another thing is to turn on the heater and oven or microwave at the same time.
    kwantor wrote:
    It is not true that it is a water reserve that allows you to be independent from the time of supplying energy, it can even be coal
    Remember what you wrote: "That is why boilers were invented when someone does not have the power supply" and I wrote "(electric) boilers were invented not to bother and dirty when servicing coal or wood-fired boilers" I think I'm closer to the truth because from your entry you can it is presumed that flow heaters were produced earlier and boilers were invented for those who did not have power conditions.
  • #20 12294776
    kwantor
    Help: 352
    Rate: 1227
    So we will write endlessly? It's good - start the fridge, it's even 10A .. and it has an effect for the use of a heater that is selected at the limit of the power available in the apartment, while it has nothing to do with the operating time of the refrigerator what, how many turns on, how many breaks there are. What a colleague noticed so eagerly when he was making any attempts to deviate from the main topic, manifest and pursue some of his strange goals - perhaps putting himself at the heights of technical education: squarewink:
    Nobody will depend on cooling and bathing - although there are priority relays. This is not what this is about.
    And electric boilers were invented for reasons other than getting dirty ..
    The fact that I did not list all the reasons for the invention of boilers does not mean that I did not write the truth, you have to "get it" a bit
    I think someone will remove at least half of this topic by evening, off topic.
    Please do not quote me anymore, because it is enough for me, as well as for my colleague's "doctorates" and the usual picking on ...
  • #21 12294931
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    A few posts earlier it was written that one phase is max. 5.7kW. But such power requires adjusting the wires, meter and accessories to the load current of 25A (sic!). The cross-section of the wires must be appropriate. You cannot give a 25A fuse when the wires are only 10A, because they will burn and there will be a short circuit !!! In general, the installations are adapted to the current of 16A, i.e. the power of approx. 3.5 kW (a bit more). It was common (e.g. in the People's Republic of Poland) to provide 10A protection for the circuit of all plug sockets in the apartment (sometimes an automatic washing machine will crash, the more so as the refrigerator is not turned off from the socket) and also 10A to light (this is even more than necessary). As a result, fuses 10A have been changed to 16A (without changing the wires), but this must be in agreement with the electrician (cable strength, fuses in the stairwell, etc.). I am afraid that for 25A the cross-section of the wires must be at least 2.5mm2 (if not 4mm2) for copper wires.
  • #22 12296156
    karopik
    Rate: 91
    Gentlemen, I know a little from the electric side because I'm an electrician. Please, someone tell me if the 5.5 kW flow heater will heat my water to such an extent that I can not wash myself comfortably. Boilers fall off because they heat the entire tank all day - I think it will be more economical [2 minutes in the shower is enough for me]
  • #23 12296306
    kwantor
    Help: 352
    Rate: 1227
    You've already got the comments, buddy.
    I would not dare to install something like this in the shower - because:
    I know the ones with the power of 3.5 kW; 5.5 kW; and 7.5 kW. with practical applications.
    In order to wash a glass or dishes, it is 7.5 kW, so that the hot water flows somehow.
    For this purpose, aerators are used in the spout, giving the illusion of a large stream.
    Subject experts will quickly count and know what's going on - how much power you need to provide to heat half a glass of water to 40 degrees in 1 second (for example) it will be somewhere around 24kW with a large error.
    This is how water flows in a real shower. Including yours as from a 4-hole window washer. What to talk about next and as an electrician you should know that.
    Of course, this is the most economical NIBA method, but you need to have the power and know that
    the boiler offers the possibility of using a tariff and a time clock, so it is debatable that it is expensive and loss-making - incidentally 1st. C a day ..
    I have a boiler and I don't heat it all day, only 1.5 hours up to 70 degrees Celsius. So at the end.
  • #24 12296329
    Tornadoo
    Rate: 10
    The fellow quantor is right. I have a 5 kW heater to wash my hands in the outbuilding and I cannot imagine a shower with this amount of water. I set the flow so that it could be washed with relatively warm water, and it still annoys me that it flows so poorly. If you want, I will measure how long it takes to fill a liter jar, but it won't be crazy :)
  • #25 12296377
    Zybio
    Help: 8
    Rate: 18
    Buddy quantor, you write nonsense, I have 5.5 kW in the sink and the water is hot that I can wash even very greasy dishes and in the shower I have 7.5 kW and I have to be careful about the water temperature, in the bolier you have 10 kW that it heats up so quickly?
  • #26 12296400
    karopik
    Rate: 91
    Zybio 7.5 kw but 3-phase?
    Just 1-phase no more than 5.5 kw. And for 3-phase I have to convert the installation, then whether 5kw or 10kw does not matter to me.
  • #27 12296448
    Zybio
    Help: 8
    Rate: 18
    no, two phases
    Added after 49 [seconds]:
    to avoid trouble in the kitchen is 5.5 kW on the third phase
  • #28 12296458
    karopik
    Rate: 91
    Probably, without converting the installation to a 3-phase one, it will not be possible.
  • #29 12296482
    kwantor
    Help: 352
    Rate: 1227
    Nonsense, buddy, you write maybe invite a colleague and demonstrate to him before thanking you for such advice.
    Hot water will flow from each heater, the only question is how fast.
    Also write how long it takes you to fill this sink with 40 degrees water.
    Here you have the boiler: http://www.ekwasek.pl/index.php?products=product&prod_id=2062 I have a 2/4 kW switch.
    And don't compromise yourself - a massacre. :crazyeyes:
    Don't think, buddy, that even these 10 kW will be wasteful. 12kW is the absolute minimum.
    You remind me of a guy who knows the word workshop and wants to put it in a crossword, at any cost, but nothing fits.
    You know what I mean?
    So the question is, why are you assuming the topic.
    You will buy 5.5 kW and take a shower - your will, and the fact that this bath will look like the aforementioned crossword, with the word "workshop" is my fun now.
    Greetings.
  • #30 12296516
    Zybio
    Help: 8
    Rate: 18
    See in the DAF data how many degrees it heats the water, measure the temperature of the cold water flowing from the tap and you will see if 5.5 kW is enough, gives about 2.5 liters of water about 40 degrees heat
    Added after 24 [seconds]:
    DAFI
The discussion revolves around selecting the appropriate power for an electric instantaneous water heater to ensure a comfortable shower experience. Users suggest that a 5.5 kW heater may not provide sufficient warmth, with some recommending at least 7.5 kW or even 10 kW for optimal performance. Concerns about electrical installations are raised, particularly regarding the limitations of single-phase systems, which typically support a maximum of 5.7 kW. Users share personal experiences, indicating that while 5.5 kW can deliver warm water, it may not be adequate for a satisfying shower. The conversation also touches on the advantages of electric boilers for those with limited power supply, as they can store heated water and provide a more consistent temperature. The importance of measuring water flow and temperature to determine the required heater power is emphasized.
TL;DR: "23 kW supplies 11 L/min at 40 °C" ["Budujemy Dom"], "Water will be pouring, and quite warm" [Elektroda, kwantor, post #12297254] A single-phase 5.5 kW gives only ~2.9 L/min [Elektroda, kwantor, post #12296553] Choose ≥12 kW three-phase for a real shower.
Why it matters: Right-sizing prevents cold dribble and blown fuses.
• Comfortable shower flow: 8–12 L/min at 38–40 °C [Energy Saving Trust, 2021]. • 5.5 kW heater: approx. 2.5–3 L/min at 40 °C rise [Dafi datasheet]. • 15 kW three-phase user report: stable 38 °C shower, satisfied [Elektroda, karopik, post #12390360] • Single-phase limit: 5.7 kW ≈ 25 A; wiring ≥2.5 mm² Cu [Elektroda, Zbigniew Rusek, post #12294931] • Heaters ≥12 kW require 3×400 V supply per EN 60335 [Manufacturer, 2022].
1. How much power do I need for a comfortable shower?
You need enough power to raise cold water (≈10 °C) to 38-40 °C at 8 L/min. That requires about 18–24 kW. A 23 kW unit delivers 11 L/min at 40 °C rise ["Budujemy Dom"]. Many users choose 15 kW and rate comfort as high [Elektroda, karopik, post #12390360]
2. Will a 5.5 kW single-phase heater work in the shower?
It works, but flow is only 2.5–3 L/min at 40 °C rise [Dafi datasheet]. Forum testers call the stream “a medical syringe” [Elektroda, kwantor, post #12290559] Suitable for hand-washing, not full showers.
5. Do I need to upgrade to three-phase?
Yes, if you want ≥6 L/min hot water. Single-phase circuits cap at ~5.7 kW under 25 A service [Elektroda, omen600606, post #12290427] Three-phase 400 V lets you install 9–27 kW heaters with balanced loads.
6. What wiring and protection are required?
25 A single-phase needs 2.5 mm² copper conductors and matching breakers [Elektroda, Zbigniew Rusek, post #12294931] Three-phase 18 kW draws 26 A per phase; wire 4 mm² Cu and 32 A breakers per IEC 60364 [Manufacturer, 2022].
7. Are storage boilers cheaper to run than flow heaters?
Storage tanks can heat at night tariffs (≈30 % lower) and spread demand across hours, using small 2–4 kW elements [Elektroda, kwantor, post #12296306] Flow units draw peak power instantly; cost per kWh is identical, but high contracted power may raise fixed fees.
8. How does inlet water temperature affect performance?
Every 5 °C drop in inlet temperature cuts possible flow by roughly 15 %. Winter inlet can hit 5 °C in Poland [Elektroda, William Bonawentura, post #12294240] Size for the coldest season to avoid surprises.
9. What does a power overload look like?
If total load exceeds the service limit, the pre-meter fuse may blow mid-shower, leaving you cold and wet [Elektroda, omen600606, post #12290427] Avoid running ovens or kettles simultaneously.
10. Can I run a two-phase 7.5 kW heater?
Yes, splitting across two phases halves current per conductor. A user runs 7.5 kW over two phases plus 5.5 kW on the third for the kitchen [Elektroda, Zybio, post #12296448] Ensure neutral sizing and phase balance.
11. What statistic shows efficiency limits?
Heating 0.5 L of water by 30 °C in one second needs 24 kW [Elektroda, kwantor, post #12296306] This physics ceiling explains why small units cannot deliver strong hot streams.
12. What maintenance do instantaneous heaters need?
  1. Descale annually if hardness >17 °dH.
  2. Check inlet filter monthly.
  3. Test safety valve during inspection. Following these steps keeps efficiency high and prevents element burn-out [Manufacturer, 2022].
