Opening Password-Protected Zip File: Methods to Unlock without Knowing Password
hotairserwis 70593 10
Can I recover or crack a ZIP file without knowing its password?
No direct method is given; the thread says the only practical option is brute force or dictionary-based password recovery, and that is only realistic for very short or simple passwords [#1274598][#1274695] One reply notes that the software itself says there is no known way to extract the password from the compressed file, so the only available method is a brute-force attack [#1274695] Another reply says that trying brute force on a 10-character password with special characters, numbers, and mixed case is not practical [#1274672] If the password is something obvious, like a URL or a phrase included in a text description, it may already be in a dictionary or easy to guess [#1274921]
  • #1 1274574
    hotairserwis
    As the topic ; ) I have a password-protected zip file - can I get to it somehow without knowing the password? Maybe you can suspect the password in some program?
  • #2 1274598
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    It is impossible, the only possibility is a method of force, which will probably take you more than you will live ;-)
    Well, unless the password has 4-5 letters without special characters and numbers, then you can play.
    It is best to use the search on the electrode because this topic has already been touched several times.
    Here you have posts about rar but it's the same thing:
    https://www.elektroda.pl/rtvforum/topic231816.html
    https://www.elektroda.pl/rtvforum/topic228305.html
    https://www.elektroda.pl/rtvforum/topic191571.html
    And as for the password cracking program, look here:
    http://www.google.pl/search?hl=pl&q=zip+password+recovery&spell=1
    But probably most of them are paid, and I don't know any myself because I don't have one
    needed to use such programs :P
  • #4 1274658
    simpo
    Level 19  
    Help: 30
    Rate: 15
    I used to have a problem ;) , I was looking for a suitable software for a long time that could be "legalized" ;) . I present a useful applet below, and a "special sequence of characters" (censorship does not sleep ;) ), which greatly expands its possibilities, I can send it to you.
    • zipkey.exe (910.36 KB) You must be logged in to download this attachment.
  • #5 1274672
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    :arrow: Lucki
    Then try to break a 10-character password containing special characters, numbers, and upper and lower case letters using the brute force method ...
    It's a pity you didn't even read what I wrote in the previous post, but it's normal in this forum.
    simpo
    Level 19  
    Help: 30
    Rate: 15
    Lucki wrote:
    What??? Buhahahahahaha zips are broken with the right programs, no matter the length of the letters or numbers in the password! With this program you can break whatever you want (every zip) RAR Password (illegal add-on) 4.00 Beta 1
    My friend Lucki I suggest you read more before you start criticizing (unfairly) other forum users (especially about the rank of a colleague kolobos'a ;) ).
    A quote from the program you gave:
    At the moment there is no known method to extract the password from the compressed file; so, the only available method is simply a "brute-force" attack.
    Greetings.
  • #7 1274771
    Lucki
    Help: 22
    Rate: 43
    Dear colleagues, why did this program remove the zip haze that contained mp3s? and the password looked like this: www.goldsend.cc ???
    Lucki
  • #8 1274790
    simpo
    Level 19  
    Help: 30
    Rate: 15
    Which program because I think I'm already lost!? ;)
  • #9 1274890
    jannaszek
    Help: 394
    Rate: 673
    Greetings.
    not a non-earthly rank, but it would be more accurate: about such a trip
  • #10 1274921
    paweliw
    IT specialist
    Help: 710
    Rate: 230
    You do not need a program for this password, the description is practically with every mp3 file, you just need to be able to read the description in the text file.
    In addition, this password should be in any dictionary of a "self-respecting" password cracker.
    As he wrote Colobos you have to be very lucky (not to mention patience) to crack a password that you do not know anything about with programs.
  • #11 1980227
    hotairserwis
    Dizeki for everyone's help - I'm closing the topic - a simple application, it's better to remember the password:)
    Moderated By jankolo:
    I close everything explained about it.
    If there is such a need for the post to be opened, please leave a message on PW and provide a link to the post.
The discussion revolves around methods to unlock a password-protected zip file without knowing the password. Users express skepticism about the feasibility of cracking strong passwords, particularly those with a combination of special characters, numbers, and mixed case letters. Some suggest using brute force methods or specific software tools like RAR Password Cracker and other password recovery programs, while others caution that these methods may be time-consuming and often ineffective for complex passwords. The conversation also touches on the possibility of finding passwords in text files or dictionaries used by password crackers. Ultimately, the consensus leans towards the importance of remembering passwords rather than relying on software solutions.
