Laptop Key Repair: Fix Non-Working Keys (A, 1, 2, Shift, Left & Right Buttons) on Laptop
hacajaca 67131 7
  • #1 12564716
    hacajaca
    Rate: 11
    Hello, I have had a problem with several keys on my laptop for a long time. Once they work all day, and once I will probably press hard and it will only press once. All of these keys are related because they all don't work and they all work at the same time. I do not work (a, 1.2 shifts and the left and right buttons on the laptop will only press after some time).
    I would ask for help.
  • #2 12564781
    highlanderus
    Level 30  
    Help: 174
    Rate: 186
    Laptop keyboards usually cannot be disassembled. The only thing that can be proposed after replacement is an attempt to blow it with compressed air. Was it flooded by any chance?
  • #3 12564791
    hacajaca
    Rate: 11
    It just wasn't like that 3 years ago they suddenly stopped working, now e.g. they work again.
  • #4 12564950
    milytuner
    Help: 6
    Rate: 16
    From the description of the symptoms, it looks like a cold solder on one of the resistors between the keyboard connector and the KBC.
  • #5 12565169
    hacajaca
    Rate: 11
    Can it be fixed somehow?
  • #6 12565212
    milytuner
    Help: 6
    Rate: 16
    Yes, locate where it does not connect and correct solder. If you provide the model, brand and preferably the code name of the motherboard, I will try to send the part of the diagram responsible for the keyboard.
  • #7 12565489
    hacajaca
    Rate: 11
    Model: MS2235
    Brand: Acer
    Motherboard ID:
    Motherboard name: Acer Aspire 5730
  • #8 12565638
    termit202
    Help: 23
    Rate: 12
    Maybe the tape on the keyboard does not connect?
    The tape is pressed to the "drawn" paths on the PCB, these paths may not exist anymore or are dirty, you could clean them (note, because they can be easily torn off) and connect, I repaired the keyboard in the T40, I do not know if all this is...
The discussion revolves around troubleshooting non-working keys (A, 1, 2, Shift, Left & Right buttons) on an Acer Aspire 5730 laptop. Users suggest potential causes such as cold solder joints on the keyboard connector and issues with the keyboard tape not connecting properly to the PCB. Solutions include using compressed air for cleaning, checking for cold solder connections, and cleaning the keyboard tape to ensure proper contact. The user provides the model and brand details for further assistance.
