Acer Aspire 5320 - Unable to Access BIOS with F2 or F12 Keys, Alternative Methods Needed
Zaja[!] 8772 3
  • #1 16275492
    Zaja[!]
    I have an unusual problem with my old Acer Aspire 5320 laptop. I can't enter BIOS mode. While the computer is loading, it displays that I should press the F2 key to enter the BIOS, or the F12 key to change the boot position - and nothing works! Why?
    I want to make the format of this laptop and install the trimmed version of XP.
    Is there another way to get into the BIOS or reboot the system automatically to the BIOS mode or is there an option to read the system image from the USB drive when turning on the laptop?
    Here is a video showing exactly what it is about:
    [Film: 3a57b82395] https://filmy.elektroda.pl/9_1486994101.mp4 [/ film: 3a57b82395]
  • #2 16275516
    masterten
    Help: 268
    Rate: 284
    Is the keyboard OK? Try connecting another USB one.
    He would read the USB, but only if you had unplugged the disk so it probably falls off.
    You can still remove the disk, prepare an installation on another computer, after which after starting the laptop it will start itself.
  • #3 16275517
    kindlar
    Help: 919
    Rate: 1622
    F12 works? Look at the bottom of the laptop may have a needle reset hole. Unplug the battery and power supply sooner.
  • #4 16275572
    Zaja[!]
    I will check the laptop with a different keyboard soon, although this one is good, because I can write everything when the system starts. But I'll check with a different keyboard.
    Added after 32 [minutes]:
    Okay you were right The keyboard does not work, however, now probably the pen drive is not reading, and I created a disk image using the Rufus program
    [Film: 4f8d952345] https://filmy.elektroda.pl/91_1486997050.mp4 [/ film: 4f8d952345]
    Added after 15 [minutes]:
    You will probably need to burn this image to CD.
