Acer Extensa 5220 Laptop Keyboard Issues: Letters I O & Numeric Keys 2-9 Not Working
technohunter 86438 10
Why do the I, O, and several number/function keys on my Acer Extensa 5220 laptop keyboard stop working, while some other keys still work?
If the USB keyboard works but the laptop keyboard does not even in Windows or BIOS, the built-in keyboard is most likely faulty and one of the tracks on the keyboard ribbon/cable is damaged, so the keyboard should be checked or replaced [#5899496][#5899130] Testing with an external keyboard is the quickest way to confirm this; if it types normally, the problem is in the laptop keyboard hardware, not software [#5899496][#5899130] Fn+F11 and LeftCtrl+F11 did not help, so this does not look like a function-key lock issue [#5897191][#5897692]
  • #1 5894841
    technohunter
    Help: 22
    Rate: 38
    I have a problem with the acer extensa 5220 laptop, something strange is happening with the keyboard. Wógle does not want to write the letters "I" of the numerical keyboard from 2 to 9, but I write 3 and 1 and also the letters "O" do not write, and also with F1 etc.
    Please help me quickly.
  • #2 5894854
    Jasiek3
    Help: 27
    Rate: 43
    Laptop was not flooded?
  • #3 5895107
    technohunter
    Help: 22
    Rate: 38
    It wasn't flooded, it suddenly stopped working
  • #4 5895393
    Jasiek3
    Help: 27
    Rate: 43
    you don't have the function key turned on? I think it says fn, press it and check if the keys work
    Krzyq
    Help: 46
    Rate: 32
    Clicking the Fn + F11 or LeftCtrl + F11 key combination did not help?
  • #6 5897692
    technohunter
    Help: 22
    Rate: 38
    None of these combinations gave me anything. Keys do not work 2,4,5,6,7,8,9,0 and O and I
    Krzyq
    Help: 46
    Rate: 32
    So I have to understand that the keys from the regular keyboard do not work - and not the numeric one? So "UP [] JKL:" M ? "Are working?
    We need a bit more information so that our forum members can help you. It is possible that it is only the software fault, although I'm afraid it may be a disadvantage of the cheap keyboard that will need to be replaced.
    What keyboard do you have on your system? You haven't installed any new programs recently, and have the keys worked before (or have they been like that since you purchased them?).
    Are these characters not showing up in Wordpad, or are some other characters appearing? What happens when you use these characters in the console - do you get any bushes?
  • #8 5899130
    technohunter
    Help: 22
    Rate: 38
    The keyboard in the laptop does not work, even in windows
    Google languages do not match usb keyboard works.
    I even uploaded the bios and nothing helped 2 days ago, it happened to me.
  • #9 5899413
    fhumr
    Rate: 10
    give a gg number, I will explain what to do and it will work
  • #11 5899608
    technohunter
    Help: 22
    Rate: 38
    Thanks to everyone for your help.
    Merry Christmas
✨ The discussion revolves around keyboard issues with the Acer Extensa 5220 laptop, specifically the failure of certain keys, including the letters "I" and "O," as well as numeric keys 2-9. The user reports that the keyboard stopped functioning suddenly and does not work even in Windows, while an external USB keyboard operates correctly. Suggestions from forum members include checking the function key settings, testing key combinations (Fn + F11, LeftCtrl + F11), and considering potential hardware damage to the keyboard's internal connections. The possibility of a software issue is also mentioned, but the consensus leans towards a hardware fault requiring keyboard replacement.
