Headphone Noise Elimination: Humming with 3.5mm Jack & Disappearing upon Touching PC Case
zaszumiony 75450 12
Why do my 3.5 mm headphones hum on my desktop PC, stop humming when I touch the case, and how can I fix it?
The hum is most likely caused by a grounding or contact problem in the desktop PC or its headphone jack, because touching the case changes the grounding and makes the noise disappear [#12828800] One suggestion was that the computer may be connected to a socket without a proper grounding pin [#12828800] Another practical test is to move the plug gently in the computer’s headphone socket, because a damaged jack or bad contact could be the cause [#12831942] The fact that the same headphones do not hum on a laptop points more to the desktop PC or its output jack than to the headphones themselves [#12828923]
  • #1 12828323
    zaszumiony
    Rate: 13
    I don't know if it's a good department, but I'll try.
    I connect the headphones with a 3.5mm jack to the computer. A hum (hum) is heard in the headphones. When I touch the housing with my finger, the noise disappears. I tried to ground the casing with a cable by connecting it to the radiator :) but it doesn't work - I can still hear humming. What is going on? Why when I touch, the noise disappears, and when I connect it to the radiator, it doesn't? It is definitely a stupid question, but I do not know any electricity / electronics at all: /
  • #2 12828488
  • #3 12828683
    zaszumiony
    Rate: 13
    I turned off the microphone and nothing has changed - there is still noise
  • #4 12828688
  • #5 12828714
    zaszumiony
    Rate: 13
    I don't have a separate device, but the headphones (bose quietcomfort 15) have some sort of noise reduction circuitry.
  • #6 12828716
  • #7 12828719
    zaszumiony
    Rate: 13
    Here, i.e. where? One microphone in the screenshot was on, so I turned it off.
  • #8 12828730
  • #9 12828767
    zaszumiony
    Rate: 13
    I have it like in your picture, but in fact, when I selected the checkbox (in the red frame), I could hear a completely different noise, much louder.
    So that's not the cause. The noise I hear is steady, quiet and I can withstand it, but when I touch the housing with my finger it disappears, so it can probably be eliminated somehow.
  • #10 12828800
    Maciek051996
    Help: 99
    Rate: 300
    So your computer is connected to a socket without a pin.
  • #11 12828815
  • #12 12828923
    zaszumiony
    Rate: 13
    It's about comp. stationary, the socket is on the extension cord and has a pin.
    The same headphones do not have any noise when connected to a laptop. I did an experiment and plugged my laptop with headphones into the same extender as the PC - there was no noise.
    I tried with different sliders and there is one thing: if I set the balance between "L" and "R" the same (eg 50), then when playing, for example, this video: https://www.youtube.com/watch?v = pco91kroVgQ, I don't hear what Lady Gaga is singing at all ;) , but you can hear music, i.e. the headphones filter the frequencies of the human voice (I think), and they probably shouldn't. If I change the balance to, for example, L = 18, R = 100, the voice is heard normally.
  • #13 12831942
    Scyphio
    Plug these headphones into the socket on the computer and try to move the plug a little. Maybe the socket broke.
The discussion revolves around a user experiencing a humming noise in their headphones when connected to a desktop computer via a 3.5mm jack. The noise disappears when the user touches the computer case, suggesting a grounding issue. Attempts to ground the case using a radiator were unsuccessful. The user confirmed that the same headphones, Bose QuietComfort 15, do not produce noise when connected to a laptop. Various troubleshooting steps were suggested, including disabling the microphone in audio settings, checking audio panel configurations, and testing the headphone jack for faults. The user noted that adjusting the balance settings affected audio output, indicating potential issues with frequency filtering in the headphones.
