How to Determine if Resistor is Good or Burnt: Checking Methods & Tips [Max 90 characters]
SUCHAR125 81054 9
How can I check whether a resistor is good or burnt?
Check the resistor with an ohmmeter and compare the reading with its marked value; desolder one leg first so the circuit does not affect the measurement [#1322796][#1323065] If the value is not marked, decode the numbers or color bands, or identify the resistor from the circuit diagram [#1322810][#1323602] If the marking is charred or illegible, the resistor can be treated as burnt, although burnt paint alone does not always mean the part is bad [#1322962][#1323065] A burnt resistor often goes open or its resistance increases, so an ohmmeter may show an incorrect or infinite reading [#1323065] If you cannot verify the nominal value, measuring the remaining resistance layer after removing the burnt coating can give only an approximate order of magnitude [#1322962]
  • #1 1322760
    SUCHAR125
    Rate: 11
    The question is as in the subject, how can I check if resistor is it good or burnt?
  • #2 1322796
    mos18
    Help: 17
    Rate: 19
    Hello, the resistor is checked with an ohmmeter. Apply an ohmmeter to the resistor and check that the resistance shown on the meter matches the resistance rating of the resistor.
  • #3 1322802
    SUCHAR125
    Rate: 11
    I have a meter, but I do not know what nominal resistance this resistor has :(
  • #4 1322810
    stan000
    Help: 51
    Rate: 15
    Enter if it has a description with numbers or colored stripes, and if so, write what.
  • #5 1322962
    maryann
    Level 37  
    Help: 342
    Rate: 337
    If the subtitles or code are illegible due to charring - such resistance can be considered burnt. Even when it is good, it may fall to the rest in a moment. If the ohmmeter measurement shows anything at all, it is rather a true value, which can be verified by the determinations; if verification is not possible - see above.
    Sometimes it is possible to pluck off burnt paint and measure, for example, a resistance layer in the middle of the length; it is not exact, but it allows you to judge at least an order of value that it should have.
  • #6 1323065
    john_t
    Help: 127
    Rate: 89
    Then you have a problem...
    The resistor most often blows on the so-called a break but not always.
    Sometimes it also increases its resistance, in this case the measurement with the meter does not make sense. It may also look like burnt paint and the resistor is OK.
    And one more thing to measure, it should be desoldered (one foot is enough) from the system.
  • #7 1323494
    lebo24
    If you do not know the value of the resistor, you can desolder it and solder the resistors of the highest resistance and then half the resistance, etc.
    But you have to see if the system fires and if the resistor does not heat up.
    Because he burned under the load. So by trial and error you will get to a similar resistance where the system starts and the resistor does not work.
  • #8 1323602
    Czeslaw10
    Rate: 52
    Write what is this system, maybe we will find a diagram and the problem of resistor value will be solved.
  • #9 1701445
    SanceS
    Help: 27
    Rate: 48
    It is best to use a cascade resistor, or a regulated resistor with a large adjustment range, instead of soldering different resistors (you have to move very gently).
  • #10 1703088
    john_t
    Help: 127
    Rate: 89
    Because he was burnt under the load. So by trial and error you will get to a similar resistance where the system starts and the resistor does not work.
    I do not recommend this method!
    And what if this resistor will be in the circuit of a bridge or a control divider, e.g. quiescent current of some power system without overload protection ???
    To do this, you need to have a diagram and know how this resistor affects the rest of the system.
    One more thing, the resistor usually doesn't burn by itself, there is almost always some reason.
To determine if a resistor is good or burnt, use an ohmmeter to measure its resistance and compare it to its nominal value, which can be identified through color codes or printed numbers. If the markings are illegible due to charring, the resistor is likely burnt. It's important to desolder the resistor from the circuit for accurate measurement, as it may show false readings when still connected. If the resistor is unknown, trial and error with various resistors can help find a suitable replacement, but caution is advised to avoid damaging the circuit. Understanding the circuit diagram is crucial, as resistors can fail due to underlying issues rather than just wear.
