How to Detect Damaged Resistors/Capacitors in a Circuit without Desoldering (Beginner Tips)
pgp 42369 13
How can I tell whether a resistor or capacitor is damaged while it is still soldered into a circuit, and do I need to desolder it to be sure?
Usually you need to lift at least one leg, or fully desolder the part, to test a resistor or capacitor accurately because the rest of the circuit can change the meter reading [#754330] In-circuit resistor readings can be wrong because the meter may see parallel paths through the surrounding circuitry, and some bad resistors look normal visually while burnt ones may be obvious [#754330] For electrolytic capacitors, bulging at the top or leakage from the bottom seal is a strong sign of damage, but many dried-out capacitors still look fine even though their capacitance has dropped [#754330][#774783] A good capacitor measured with an ohmmeter should initially look almost like a short and then the reading should rise as it charges; if it shows a constant resistance, does not charge, or stays low, it is suspect [#774559][#774571] For small capacitors, an ohmmeter often can only tell you whether they are shorted, and electrolytics may still pass some leakage current even when healthy, so compare the behavior over time rather than relying on one static resistance value [#774559][#774571]
  • #1 754307
    pgp
    Level 19  
    Help: 6
    Rate: 17
    I am a beginner. I have a question how to check if the resistor / capacitor are whacked since they are soldered into the entire system. Do you need to desolder it to be sure? Even when the resistor is burnt, the meter can show us the resistance of the rest of the system seen from the side of the terminals of this burnt resistor. And even when it is not burnt, the value shown on the meter may be the value resulting from the parallel connection of the resistor and the resistance of the rest of the system. capacitors can always be determined visually ? If possible, how (e.g. how to distinguish an electrolyte leak from the glue used to assemble the kit?) :?:
  • #2 754330
    velsper
    Help: 176
    Rate: 110
    You reason correctly - the easiest way is to desolder a resistor or capacitor and check it with a meter - you can also desolder, for example, only one leg of the element, and then check the element with a meter.
    As for the visible damage to the resistors - sometimes it can be difficult to determine whether they are damaged, because there are resistors that are broken, but visually they look good. Of course, I omit the fact that the resistor is all black, has burnt paint, and sometimes you can't even figure out what its value was...
    As for electrolytic capacitors: as you can see that there is a bulging sheet at the top, or a cork from the bottom - the capacitor is already damaged - although not always. Sometimes it's just dried up, it looks OK visually, but the meter shows a value much much lower.
  • #3 754350
    pgp
    Level 19  
    Help: 6
    Rate: 17
    And as for the transistors. How to know that they are burnt. There seems to be a short circuit between the collector and the emitter then, right?
  • #5 754617
    Kamil_rz
    As for transistors, it's best to check with a diode tester. Knowing where we have individual EBC pins and npn or pnp polarity, you can easily identify a burnt transistor. We treat the transistor as two diodes connected. In the direction of conduction, the meter shows a voltage drop at the junction, i.e. about 600-1000 mV, and in the reverse direction it shows a break!!! four measurements with a meter and everything is clear :)
  • #6 757242
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4258
    The basic method of detecting damage to resistors and transistors is to measure voltages
    constants - e.g. a transistor in a typical system has a voltage of 0.7V between the emitter and the base;
    transistors do not always short-circuit when they are damaged - often a break on the emitter.
    And as for checking the desoldered transistor - four measurements (EB and BC in both directions)
    it may not be enough - how to short EC (e.g. wire E touches C).
    As for the original damage - I had a case that the NPN transistor was damaged so
    that it turned into a properly functioning PNP transistor; it was a BF194 CEMI.
    And when it comes to distinguishing drain - source in FETs - there is probably no simple method,
    maybe like this: when the gate is shorted to one of them, the one-way transistor works as
    current limiter - reliably limited current depends on whether the drain or the source,
    and even more surely the impedance of this limiting is higher, when we short-circuited the source;
    relatively certain results should give: measurement of the slope of the characteristic - as we will replace
    drain with the source, then we will get smaller; and breakdown voltage measurement (GS less).
    Also, it can be difficult to tell the difference between emitter and collector - not all types
    transistors have forward voltage difference EB and CB, you need to measure beta,
    or the breakdown voltage of the junctions (the latter is easier than in FETs).
  • #7 774497
    pgp
    Level 19  
    Help: 6
    Rate: 17
    I have one more question about the capacitors. Will we get a value by testing the capacitor desoldered from the system with an ohmmeter because I sometimes get, for example, 40 Kohm. When this resistance is small, can it be assumed that the capacitor is damaged? How small?
  • #8 774559
    adamjur1
    Help: 772
    Rate: 1003
    It all depends on the meter, its range and measurement time. A good capacitor at the beginning of the measurement should have almost a short circuit, and after a period of time depending on the range of the meter and its current efficiency in this range, it should charge and show max (the smaller the range, the faster). dried - it will not show "almost a short circuit" or break at the operating voltage (and we do not have such in the meter). Aha - the smaller the capacity, the higher the range of the ohmmeter, with picofarads you can only check if it is not shorted.
    As for the transistors, with a little practice, you can check their diode transitions at the base-collector and base-emitter junctions without desoldering, one way about 450 Ohm, the other max (taking into account the surrounding elements. EC should be high resistance in both directions. If EC there is no short-circuit, and BE and BC behave like diodes, it is highly probable that the transistor is operational (does not apply to MosFet, Fet and other field effect transistors)
    Regards J
  • #9 774571
    _jta_
    Help: 3212
    Rate: 4258
    If it's not electrolytic, and if the ohmmeter shows that resistance constantly, it's a capacitor
    it's damaged; when measuring a capacitor with a larger capacitance, the ohmmeter can
    especially in the high range, show some resistance for a while - until the capacitor
    when it is charging it has current flowing through it if you have a 10 megohm ohmmeter and a capacitor
    with a capacitance of 10uF, the current should flow about 100 seconds.
    With electrolytic capacitors a more complicated matter - if the voltage
    with the ohmmeter is in the wrong direction, the best capacitor will let through
    current (and you may have trouble distinguishing a low capacitance capacitor from a diode,
    both pass current in one direction and not in the other); besides the right one
    the capacitor also lets some current through - but it should be a few uA at most
    (for small capacitance capacitors; there are some standards that define it more precisely,
    but I don't have more precise data here), if the capacitor lets more through, then you can
    suspect it's not the best, but it's a good test to plug it in
    some time under DC voltage, then disconnect, wait a minute, and measure the voltage.
    If it is more seriously damaged, there will be almost no voltage, it will be very good
    held the voltage for hours - make a few measurements with different waiting times, and you know.
  • #10 774783
    TomaszJaneta
    Rate: 11
    There is also such a phenomenon as drying up of electrolytic capacitors. You can see this in 10 - 12 year old TV sets that start to behave strangely: first they stop firing, then the colors change, strange stripes appear on the screen, etc. Just replace the old capacitors and ok.
  • #11 775820
    _jta_
    Help: 3212
    Rate: 4258
    Right. How do their parameters change then - decrease in capacitance, increase in resistance?
  • #12 775930
    axxx
    Home appliances specialist
    Help: 376
    Rate: 1720
    Hello!!!
    When I read these arguments about the measurements of ordinary passive elements, my brain likes it, gentlemen! do a little digging in the old press
    Radio Amateur and electronics and you will see how easy it is :D
  • #13 776423
    pgp
    Level 19  
    Help: 6
    Rate: 17
    We amateurs already have it... Lack of books and other professional sources.
  • #14 776849
    axxx
    Help: 376
    Rate: 1720
    I have a collection of electron magazines. since 1969, but unfortunately I did not earn enough
    still a scanner. I advise buying a clock multimeter at the marketplace
    for PLN 10 and the matter is settled, these digital ones indicate what they want, unless they are high-class professional from PLN 500 and above.
    For example, I will show how I check electrolytic capacitors with a dial meter: discharges the end cap and ohmmeters, measures depending on the capacity, the pointer swings by a certain value and returns to O. If it does not return, the end cap is shorted. I have been checking this for years and this method has not failed me yet, what do I know if kndek is 5 m or 7 m and has a tolerance of 20%. exposure :)
The discussion focuses on methods for detecting damaged resistors and capacitors in a circuit without desoldering. It is noted that while desoldering is the most reliable method, checking one leg of a component can also yield results. Visual inspection can sometimes be misleading, as resistors may appear intact despite being damaged. For electrolytic capacitors, signs of damage include bulging or leaking, but some may still function poorly even if they look normal. The use of a multimeter is emphasized for testing components, with specific techniques for measuring transistors and capacitors. The importance of understanding the behavior of components under test conditions is highlighted, including the effects of drying out in electrolytic capacitors.
