What kind of resistor should I put in to connect the diode under 12V and under which you can connect the resistor
Szafa333 wrote:Practically, you can use from 470 ? to even 1 k? and a power of 0.5 W. A lot depends on the parameters of the diode, usually red diodes (2.1-2.5 V) are powered with a slightly lower voltage than green and yellow ones (2, 7-3.2V)
