How to connect 2 or 3 LEDs to the battery?
meduzaaa 33363 16
How do I connect 2 or 3 LEDs to a 12V battery, and do they need separate resistors or can they share one?
You can power the LEDs from one 12V battery, but you must limit the current with a resistor unless you buy LEDs that already have a built-in 12V resistor [#15076172][#15076173][#15076217] If you wire the LEDs in parallel, each LED should have its own series resistor; if you wire them in series, one common resistor can be used for the whole string [#15076172][#19179950] For white LEDs, the long lead is the anode and the short lead is the cathode, so connect anodes together and cathodes together only when wiring in parallel [#15076217] You can extend the LED leads with extra wires if the LEDs need to be separated by several centimeters [#15077214] For higher-power LEDs, a proper constant-current driver is better than just a resistor, because the current adds up in parallel and changes if one LED fails [#19179950][#19180379]
  • #1 15076154
    meduzaaa
    I would like to point out right away that my knowledge in the field of electronics ends with the ability to turn on the light ...
    I need to power two / three LEDs that are about 10-15 cm apart (a dollhouse for a baby girl) and I have no idea how to do it .. is it enough to connect these two rods coming from the diode with a 12V battery? All for 1 battery, does each diode have to have its own?
    Please help...
  • #2 15076172
    jacekko63
    Help: 140
    Rate: 320
    LEDs need to limit the current consumption, resistors are most often used. You can connect in parallel, then you need to count each one and add a resistor or in series, then we add one common in series, to count them you need: supply voltage, diode voltage and diode current not exceeding the allowable.
    Read this topic: Link .
  • #3 15076173
  • #4 15076199
    meduzaaa
    and I can ask more pathologically? What is this resistor? Where to connect it and how ...? The same LEDs, white, as small as possible. I found something like this on the allegro
    led-12v-3mm-real-12v-resistor-free
    Moderated By ANUBIS:
    3.1.18. Do not send links that will cease to be active after some time. This will make the discussion meaningless.
  • #5 15076217
    zybex
    Helpful for users
    Help: 2094
    Rate: 2940
    A resistor is a popular resistor. Often, when buying diodes, it is added for free. For example, for 12V a resistor of 510?-560? is added. To each diode, to one of its ends, it should be connected in series with the 12V power supply. We are talking about white LEDs, because color matters.
    From what you wrote above, you can buy diodes with a built-in resistor for a voltage of 12V. We are talking about the given link. In such a system, you connect the diodes in parallel and connect them to 12V.
    Regarding the parallel connection itself, the diodes have an anode and a cathode. You have to connect them in harmony, i.e. cathodes to cathodes and anodes to anodes. For ease of use, they have different cable lengths. In other words, the longer ends should be joined together and the shorter ones should be joined together.
    You can find more about diode connections here: Link
  • #6 15076336
    meduzaaa
    What if these tips are too short? Ie. The diodes are to be separated by several cm ... or if so, what can I extend them?
  • #7 15077214
    zybex
    Helpful for users
    Help: 2094
    Rate: 2940
    Yes of course. You connect the cables you need. Some time ago I was lighting a nativity scene for someone for Christmas. I have cleverly hidden the cables.
    Here you have an example of connecting three (typical) LEDs with matching resistors.
    The connection in your case may look like below. Of course, resistors are not necessary with LEDs that have them.
  • #8 15078024
    meduzaaa
    And how many such diodes can I connect in this way? If I would buy duods without a built-in resistor, how do I find one that will be suitable? And then one at the beginning of the cable is enough, or must it be separate for each diode?
  • #9 15078784
    DarekLLL
    The voltage of an ordinary diode is color dependent. White is 3.2V. Three diodes connected in series give 9.6V. Thus, one 9V battery is enough for 3 white LEDs connected in series. For two white LEDs connected in series, 4 AA batteries (4 x 1.5V connected in series together 6V) are sufficient. In this case, no resistors are needed.
    However, the problem is age. Children shouldn't play with batteries to keep them from eating, or lest they puncture the batteries or anything like that. Better to buy another one with ready lighting and approval.
  • Using one 15 ohm resistor for four parallel LEDs is unsafe
    #10 19177385
    lev-ele
    I will connect to the topic.
    I have 4 Power Leds - 3W, voltage 3.4 - 3.6 mA.
    I connect the 12-14 V voltage to the car battery
    calculations show that I should use a 15 Ohm and 7.3 W resistor
    question:
    if I give a 15 OM 50 W resistor, can I connect 4 diodes to 1 resistor in parallel?
    the power consumption will be about 30 W so that there will be a power reserve of the resistor so that it does not burn out.
    will it work
  • Separate resistor needed for each 3W LED
    #11 19178241
    Madrik
    Help: 627
    Rate: 1191
    question:
    will it work
    First. Pay attention to what you write. We don't have a cryptology department.
    Second, we measure voltage in volts (V), not milliamps (mA).
    3W LEDs come from several different manufacturers and in several different finishes. If you know your type, you can find their exact datasheet. There will be, among other things, the current range to drive them.
    You didn't mention the one you took.
    Third, if you connect 4 diodes to one resistor, the conditions will change. The currents of all LEDs add up, and a new calculation has to be made. It could be done, but not with a resistor calculated for one LED.
    Resistors are not some very expensive equipment. It is recommended that each LED has its own so that in the event of damage, you do not lose all the LEDs, which, on the other hand, already cost a bit more. It is a pity, to save on an item worth a few zlotys, to lose a few items worth a dozen or several dozen zlotys.
    Fourth: Don't plug into topics from many years ago. Create your topic.
  • Need separate current limiting for each LED
    #12 19179382
    lev-ele
    the fact was a little confused in terms.
    I know that when I connect them to one resistor in series, the conditions change, but I don't know how the conditions change when I connect them in parallel to one resistor.
    I have a resistor more than 5 times stronger than 1 diode requires, so on 4 diodes it should be ok.
    I don't know much about it, so I'm writing for it.
    Please be understanding.
    I have a diode like this:
    https://allegro.pl/oferta/dioda-power-led-3w-ultrafioletowa-uv-430nm-45mil-7005206543
    a resistor like this:
    https://www.sklepledowy.pl/pl/p/Rezystor-50W-15ohm-dla-Zarowek-Led/833
  • Recommend individual resistors or an LED driver
    #13 19179950
    zybex
    Helpful for users
    Help: 2094
    Rate: 2940
    The current of one diode is 700mA. When you connect four pieces in parallel, the current will be 4 x 0.7A, or 2.8A. For this current, you need to calculate the resistor. By the way, if each of them had its own resistor (lower in power and dimensions), it would be better. The point is that if one of them fails, the others will get more current and burn out too. You can also connect them in series, but then you need a higher voltage with a current of 0.7A.
    Formula to calculate the resistor: R = (Usas - Udiody) / Idiody
    It is best to measure the actual current in the circuit.
    A much better solution is to use a driver.
  • #14 19180126
    mpier
    Help: 153
    Rate: 141
    Show these calculations. I recommend Ohm's Law, but you need to learn the basic concepts beforehand. It will be electricity, voltage, power. Connecting it in parallel does not make sense. Serial 4 or 3, or use the driver.
  • Need a 12–14 V driver for four 3 W UV LEDs
    #15 19180214
    lev-ele
    In order not to combine, because I'm not too strong in it, maybe someone will just tell me what resistor or just driver to buy for the diode> https://allegro.pl/oferta/dioda-power-led-3w-ultrafioletowa-uv-430nm-45mil -7005206543. Or maybe someone can make a driver for me.
    I need to connect FOUR LEDs in different places so that it is best to connect in parallel.
    powered by a 12-14 V motorcycle battery.
  • 700 mA constant-current driver for 1–3 LEDs
    #16 19180379
    zybex
    Helpful for users
    Help: 2094
    Rate: 2940
    Here you have an example driver for 700mA. Link
    It can power from one to three diodes connected in series from your battery. When using the driver, you don't have to worry whether the battery is 14, 13 or 12V. The driver monitors the 700mA current all the time. When you use a resistor, unfortunately the diodes will shine dimmer at lower voltage, when you select the resistor to, for example, 14V and the voltage drops to 12.5V.
  • #17 19180517
    lev-ele
    Thank you so much for help
To connect 2 or 3 LEDs to a 12V battery, users can wire the LEDs in either series or parallel configurations. For series connections, the total voltage drop across the LEDs must not exceed the supply voltage, while for parallel connections, each LED requires a current-limiting resistor to prevent damage. Resistors are typically calculated based on the supply voltage, LED forward voltage, and desired current. White LEDs generally have a forward voltage of about 3.2V. If using LEDs without built-in resistors, a resistor should be connected in series with each LED. For longer distances between LEDs, extension wires can be used. It is recommended to use a dedicated driver for multiple LEDs to ensure consistent current and prevent overcurrent situations.
