RCD 310 Volkswagen Golf V Radio Code Retrieval - Memory Load 95128, VWZ1Z216768674 & 1K0035186AA
Jamrug 21009 11
Can I retrieve the RCD 310 radio code from the 95128 EEPROM dump, or do I also need data from the NEC processor?
The code is stored in the EEPROM but encrypted with a key from the NEC processor, so an EEPROM dump alone may not be enough and eeprom substitution does not work well [#13719979] For a Blaupunkt unit, the forum says you need the processor plus EEPROM, and it may only be doable on the bench with tools like Martech [#13720084][#13720041] One suggested method is to change the EEPROM cells from AE0 to CD0 to FF, write that back to the radio, power it on, then read the EEPROM again [#13723522] That process may reveal the first two digits of the code, while the rest must be calculated manually “on the table” [#13722702]
  • #1 13719959
    Jamrug
    Help: 18
    Rate: 177
    Hello all. Is it possible to read the code to the radio based on the memory load 95128, which I put below. Radio is:
    RCD 310 volkswagen golf V numbers
    VWZ1Z216768674
    1K0035186AA
    I read a similar post that the code counts on the basis of the content from the NEC processor. Is it really so?
    Possibly someone can enumerate the code from this memory because I am counting on the NYO 4 program and I get the code 0323 but I'm not sure if it's ok.
    • RCD310.bin (16 KB) You must be logged in to download this attachment.
  • #2 13719979
    adrian1201
    Help: 128
    Rate: 416
    The code is in the eeprom but encrypted with the key that is in the NEC processor. There is another key in each play, so the eeprom substitution does not work well.
  • #3 13720035
    Jamrug
    Help: 18
    Rate: 177
    And what device does it do best with it? For example, Martech? Is it possible to do this with a program reading from the NEC processor?
  • #4 13720041
    piwko
    Help: 87
    Rate: 213
    adrian1201 wrote:
    The code is in the eepromie but encrypted with the key that is in the NEC processor. There is another key in the karzdej so the substitution of the eeprom is not much zda.
    Not on this radio - it's going to count here.
    There is something wrong here. W / g martecha is a Delphi radio, eeprom 24LC32.
    If it's Bosch or Blaupunkt, then unfortunately only on the table can be done.
  • #5 13720059
    Jamrug
    Help: 18
    Rate: 177
    Well, buddy beer. I have a carproga and I can see that the pin can be read and reset. At the moment, he does not read the memory because he is blocked, but this type of radio is working so I am surprised by this key in the prock. Will you be able to count the code for me? And the radio is Blaupunkt at 100% Memory 95128 I read an hour ago.
  • #6 13720084
    piwko
    Help: 87
    Rate: 213
    Jamrug wrote:
    Well, buddy beer. I have a carproga and I can see that the pin can be read and reset. At the moment, he does not read the memory because he is blocked, but this type of radio is working so I am surprised by this key in the prock. Will you be able to count the code for me? A radio is Blaupunkt at 100% Memory 95128 I read an hour ago.
    If it's Blaupunkt, then unfortunately as a colleague wrote - processor + eeprom.
    A moment of work, martech.
  • #7 13722702
    wolf16
    Help: 32
    Rate: 115
    You can optionally read the first two digits of the code by changing the memory contents and the rest by manually typing on the table.
    klucze.sosnowiec.pl
    Długosza, Sosnowiec, 41-219 | Company Website: https://klucze.sosnowiec.pl
  • #8 13722785
    Jamrug
    Help: 18
    Rate: 177
    And what to change in the batch and how to read these numbers? Will you bring it a little?
  • #10 13723478
    Jamrug
    Help: 18
    Rate: 177
    Bin is posted in my initial thread (speeches)
  • #11 13723522
    wolf16
    Help: 32
    Rate: 115
    Change cells from AE0 to CD0 to FF and upload this content to the radio. Turn on the radio, wait a moment (the processor will store new values in memory). Turn off the radio, read the memory and put the content here.
    klucze.sosnowiec.pl
  • #12 13732938
    Jamrug
    Help: 18
    Rate: 177
    Thank you all for help but I have already solved the problem. He found CARPASS.
    I close the subject.
The discussion revolves around retrieving the radio code for a Volkswagen Golf V's RCD 310 radio, specifically using the memory load 95128 and the serial number VWZ1Z216768674. Users confirm that the code is stored in the EEPROM but is encrypted with a key from the NEC processor, making direct EEPROM substitution ineffective. Various tools and methods are suggested, including the use of Martech devices and the Carprog tool, which can read and reset the PIN. A method to change specific memory cells to retrieve the first two digits of the code is also discussed. Ultimately, one user reports successfully finding the code through CARPASS, concluding the topic.
