Recovering Incorrect Code for VW Radio RCD 300 Blaupunkt Purchased on Allegro
Krecik2231 12138 10
How can I recover the correct code for a VW RCD 300 Blaupunkt radio when the seller supplied the wrong code?
You can try the code lookup service at koddoradia.pl for this VW radio, and if the seller deliberately gave the wrong code, the thread also advises reporting the fraud to the police [#16787914][#16788057] If you keep entering incorrect codes, the radio can block itself [#19661577] No other unlocking method was provided in the replies.
  • #1 16787881
    Krecik2231
    Hello, would anyone be able to recover the code for the above radio? I bought a VW radio on Allegro with the code, but unfortunately the seller turned out to be dishonest and sent me the wrong code. I can give the number on the housing. Unless there is some instruction on how to do it, I will also be grateful.
    Thank you in advance for your help!
  • #2 16787914
    bubu1769
    Help: 1177
    Rate: 2375
    Go to www.koddoradia.pl
  • #3 16788057
    powalla
    Moderator of CarAudio
    Help: 847
    Rate: 737
    Why combine? You go to the police, report fraud and the rest goes on without you, ie they have all the data and will do everything to have one more "detection". It may turn out that the guest is a thief and you do not report it, you become a sort of a punishment, and this is punishable! Think what will happen if someone reported the theft of the radio and gave your radio serial number. Stupid more control and you're cooked ...
  • #4 16788073
    bubu1769
    Help: 1177
    Rate: 2375
    That is also right.
  • #5 16788538
    Krecik2231
    I thought about it, but there is something such as low harmfulness of the act, the value of the Radio does not exceed PLN 100, so the western part is massive and the effects are none, and I have no time to testify, etc. I thought that someone with a proverbial bottle would manage to unlock it :-)
  • #6 16788763
    powalla
    Help: 847
    Rate: 737
    You will see what low harm means when you are accused ...
  • #7 16874553
    Tomas812
    i would also need to find out the code order blaupunkt rcd 300
  • #8 19160662
    Croos13
    Rate: 25
    Hello. A colleague solved the problem?
  • #9 19648720
    kstencel1984
    Help me
    Code for rcd 300 blaupunkt radio
    VWZ1Z2E2372226
    1KO 035 186P
    The codes used are:
    1416
    0537
    2323
    6329
    1000
    1410
    Help me
  • #10 19661577
    laciaty19
    Rate: 8
    If the wrong pin is entered too many times, it will block it.
    Moderated By Felini:
    3.1.14. Do not send messages unrelated to the topic.
    [link removed]
  • #11 20631515
    alexxyy88
    Hello all! I hope that somebody will help me with the code for my radio from VW Golf 5 VWZ1Z2F8637938 Blaupunkt VW RCD 300 / 1K0 035 186 P.
The discussion revolves around recovering the code for a VW RCD 300 Blaupunkt radio purchased on Allegro, where the seller provided an incorrect code. Users suggest various approaches, including visiting a website (www.koddoradia.pl) for assistance. Some participants advise reporting the seller to the police for fraud, while others express concerns about the implications of such actions. Several users share their own experiences and codes they have tried, indicating the potential for multiple attempts to unlock the radio. There is a warning that entering the wrong code too many times may lead to the radio being blocked.
