AUDI Q7 2008 3.0TDI Engine CAS - Throttle Error 001592 P0638: VCDS Screenshot & Photo Included
dziugi 46722 12
  • #1 13785345
    dziugi
    Help: 5
    Rate: 126
    AUDI Q7 2008 3.0TDI Engine CAS - Throttle Error 001592 P0638: VCDS Screenshot & Photo Included AUDI Q7 2008 3.0TDI Engine CAS - Throttle Error 001592 P0638: VCDS Screenshot & Photo Included
    AUDI Q7 2008 3.0 TDI ENGINE: CAS
    During normal driving, the engine light came on today.
    I didn't notice any drop in power.
    After connecting to the computer, vcds showed the following error: 001592 P0638.
    If you try to delete it - it returns immediately - no matter if the engine is turned off or not.
    I attach a screenshot from VCDS and a photo of the throttle
  • #2 13785723
  • #3 13785740
    dziugi
    Help: 5
    Rate: 126
    In what channels can it be tested?
    sigwa18
    Help: 1180
    Rate: 3316
    Feedback signal "does not please the driver).
  • #5 13785960
    Pawel wawa
    Help: 1262
    Rate: 4423
    Damper to replace / regenerate. Still see the beam to see if it is starting to break. Start watching from the plug, take a 20 cm look at it, carefully pulling on the wires.
  • #6 13786057
    dziugi
    Help: 5
    Rate: 126
    Hello, thank you for all the hints. It looks like the throttle just gave up. the part number read is: 059129086K, can I buy a stimulant with the same number but with a different suffix - M?
  • #7 13787648
    dziugi
    Help: 5
    Rate: 126
    Saying there is a damaged throttle, what do you mean (in relation to the photo posted)?
    no.1 or no.2 - throttle flap adjusters (whatever it is called)
    or No. 3 - dampers
    Or maybe some other element that I missed?
    The error in VCDS reads: 001592- throttle body actuator bank 1
    domex32
    Help: 585
    Rate: 2450
    Do you have a cable with alledrogo and you do not know which part has broken?
    Turn on the ignition, remove the plugs and you'll find out what's what.
  • #9 13788239
    dziugi
    Help: 5
    Rate: 126
    I have the original VCDS - as you can see from the version - in the attached photo. After disconnecting the next plugs, I had other errors - hence the question for experts on the subject.
    In which measuring blocks I can check these specific components - specifically the throttle flap actuators - because I suspect them - and specifically the left one, in photo no: 1.
    I will only mention that during the observations during the starting of the engine - both of them present themselves ...
    Is this a good lead or something else?
    ste
    Help: 183
    Rate: 275
    J338 (Throttle body actuator) it is in your picture No.3.
    It should have a 4-pin plug; cable colors: brown, red-gray, white, blue.
    The method given by the domex colleague is reliable, if you unplug the plug from the j338 module, you should get an error about j338 with the description "open circuit"
  • #11 13792125
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6402
    Buddy SSP puller for this engine and maybe you will master the topic.
  • #12 13793145
    dziugi
    Help: 5
    Rate: 126
    A new damper has been ordered - delivery will take about a week.
    Thank you for your help.
    I also read on other forums that I will have to do a short adaptation using vcds. I've read a lot of topics but they refer either to a different transmission- kwp2000 ... etc, or to different engines.
    Does anyone know and share their knowledge about the correct procedure for this engine in this car?
  • #13 13828383
    dziugi
    Help: 5
    Rate: 126
    A short update - the throttle has been replaced with a new one - as indicated by the user: STE, and everything returned to normal. Thanks to everyone for your help.
✨ The discussion revolves around a 2008 Audi Q7 3.0 TDI experiencing a persistent throttle error (001592 P0638) indicated by the VCDS diagnostic tool. The user reports no noticeable power loss but seeks advice on troubleshooting the throttle body actuator. Responses suggest checking the throttle body components, specifically the throttle flap actuators and dampers. The user confirms ordering a new damper and inquires about the adaptation procedure post-replacement. After replacing the throttle, the user reports that the issue was resolved, thanking the community for their assistance.
