[VBA] - Macro to Copy Data from External File (wsad.xlsx) into Current Workbook's Sheet 2
tefel 13824 9
How do I copy data from an external Excel workbook into Sheet 2 of the current workbook without the macro running on the active file?
The macro is acting on the active workbook because `Range("A:A").Copy` is unqualified, so you need to explicitly reference the opened workbook and its sheet [#13877019][#13877086] After `Workbooks.Open`, copy from something like `ActiveWorkbook.Sheets(1).Range("A:A").Copy` instead of relying on the current active sheet [#13877019] Then switch to `ThisWorkbook` and paste into `Sheets("Arkusz2").Range("B1")` there [#13877019] The key fix is to avoid `ThisWorkbook.Activate` / generic `Range(...)` calls when you want the source data to come from `wsad.xlsx` [#13877086]
  • Need to qualify source range after opening wsad.xlsx
    #1 13876738
    tefel
    Due to little knowledge, I wrote this code by analyzing the macro recorded earlier. The (probably trivial) error I can't deal with is that I am not copying data from the batch file, but the macro is executing on the file I run it from. Probably something needs to be added after the command to open the file, but although my head and three do not know what; (
    Private Sub CommandButton1_Click()
        Workbooks.Open Filename:="C:\Users\mm\Desktop\Nowy_folder\wsad.xlsx"
               Range("A:A").Copy
               Sheets("Arkusz2").Activate
                    Range("B1").Select
               ActiveSheet.Paste
        Workbooks("wsad.xlsx").Close
    End Sub
  • #3 13877019
    JRV
    VBA, Excel specialist
    Help: 805
    Rate: 455
    PRL ThisWorkbook.Activate = Windows (Booklet) .Activate
    Make a complete link to the sheet.
    ActiveWorkbook.Sheets (1) .Range ("A: A"). Copy
    Perhaps, as the workbook opens, it is copied from the current range.
  • #5 13889568
    tefel
    Great, works fine ;-) I still have the nature of the "aesthetic" issue. Namely, when copying, a message pops up about a large amount of information in the clipboard, can it be turned off or stuck somewhere so that it selects the "no" option?
  • Questioning a more efficient multi-column VBA copy method
    #7 13894880
    tefel
    I may need to copy the B column. The only solution I came up with is below. Is there a more optimal way to prevent the code from taking too long if I add more columns in the future? :D
    Code: text
  • #9 13895021
    Maciej Gonet
    Help: 824
    Rate: 481
    Good morning,
    If the data to be copied begins with the first line, the fragment concerning copying can be abbreviated as follows:
    Code: text
    Regards.
  • #10 13929126
    seba78787878
    Sorry that I turn on, and if we do not know the name of the file and try to find it, open it and copy the same
    Code: text
    enough?
The discussion revolves around a VBA macro designed to copy data from an external Excel file (wsad.xlsx) into a specific sheet (Arkusz2) of the current workbook. The initial code provided by the user had issues with activating the correct workbook and copying data. Several responses offered solutions, including ensuring the correct workbook is activated before copying data, using the `Application.CutCopyMode = False` command to suppress clipboard messages, and optimizing the code to copy multiple columns efficiently. Suggestions included using the `With` statement for cleaner code and the `Intersect` method to copy specific ranges. Additionally, a method to open a file dialog for selecting the file dynamically was proposed.
