[VBA] Paste Excel Table (A1-D1 & Last Completed Row) into Email Body using Outlook Application
Darekstw 10038 6
  • #1 16726004
    Darekstw
    I have a problem with writing a brand that would stick to the e-mail content as tables selected fragments of the table from the spreadsheet as I posted in the comment
    wants in the form of a table cells from A1 to D1 and in the second row from the last completed row from the table Ax to Dx, where x - the last filled row in the table:
    Code: VBScript
    How to approach the topic that it would look like the table below in the body of the email:
    clubs
    Help: 629
    Rate: 406
    Look for Function RangetoHTML
  • #3 16773557
    Darekstw
    I have one more question regarding the macros sending emails, how to make the email be sent back to the sender, i.e. in the CC addressee we have the email address from which the email is sent?
  • #4 16774544
    clubs
    Help: 629
    Rate: 406
    Check
    Code: VBScript
  • #5 16775633
    Darekstw
    After adding this line and variable in the code
    Dim Poczta
    The macro will pass without error in the message of the sender not provided in DW.
    clubs
    Help: 629
    Rate: 406
    I understand that you use this code?
    Code: VBScript
  • #7 16777865
    Darekstw
    Ok, the code fragment shown above cleared up the situation, everything works as I wanted. Thank you, the topic is closed :)
The discussion revolves around a VBA macro for sending an email via Outlook that includes a specific Excel table format in the email body. The user seeks to extract data from an Excel sheet, specifically from cells A1 to D1 and the last filled row in columns A to D. A suggested solution involves using the `RangetoHTML` function to format the table correctly. Additionally, the user inquires about automatically adding the sender's email address in the CC field, which is resolved by using `Poczta.Session.CurrentUser.Address`. The final code provided successfully meets the user's requirements.
