VBA Macro for Auto-Filling Empty Cells with Above Values in Excel Column
PanPiotrAdamus 40653 3
  • #1 6636313
    PanPiotrAdamus
    this is my first post on the elektroda forum.
    I'm just getting started with VBA and have a little problem.
    The problem to be solved looks like this:
                   Kolumna
    Wiersza
        1           aaa
        2           aaa
        3           aaa
        4
        5            bbb
        6            bbb
        7            bbb
        8
        9            c
        n+1
    In my worksheet, I have such a series in column A. The value of each cell has no meaning.
    I would like the macro to check if the cell is empty and if it is empty it will copy the previous value to the empty cell.
    So far I have written such a macro but it doesn't work (I get error 400).
    Sub Macro ()
    FinalRow = Cells(Rows.Count, 1).End(x1Up).Row
    i=1
    For i=1 To FinalRow
          If Cells(i,1).Value 0 Then
              If Cells(i,1).Value=0 Then
                  Cells(i-1,1).Select
                      Selection.Copy
                         ActiveSheet.Paste
                End If
             End  If
     Next 1
    End For
    End Sub
    Unfortunately, the above code returns an error. Could any of the forum members give me advice on how to solve the above problem?
    Thanks !
    Peter.
  • #2 6636630
    adamas_nt
    Help: 1508
    Rate: 659
    I did not check the operation, but:
    Error 1: Invalid Rows.Count (x 1 Up, it should be XLUP). Better:
    FinalRow = Cells(Rows.Count, 1).End(xlUp)
    Or
    FinalRow = ActiveSheet.UsedRange.Rows.Count
    Error 2: For loop. If you assign values to a variable and , this: or (also correctly) the same Next without explicitly naming the variable.
    Error 3: End For - which is completely unnecessary. Exit from the loop (usually conditional) is done with a command Exit For inside the loop. Not necessary here.
    Edit:
    And only now did I look at the body of the loop. Conditions are mutually exclusive. I think that checking should be started from the second line (the first possible "hole" with 3 non-empty) and we will make an additional condition that the macro does not cause an error if there are less than 3 lines.
    Sub Macro1()
    'FinalRow = Range("A65536").End(xlUp).Row 'jezeli tylko kolumna
    If FinalRow < 3 Then Exit Sub
    For i = 2 To FinalRow
        If Cells(i, 1).Value = "" Then
            Cells(i, 1) = Cells(i - 1, 1)
        End If
    Next
    End Sub
  • #3 6655963
    PanPiotrAdamus
    Welcome,
    Thanks. Macro works. This error with
    It's a typo - I think I need to start wearing glasses.
    BTW,
    do you know any page with detailed understanding of VBA functions?
    Thanks and regards
    Peter.
  • #4 6658202
    adamas_nt
    Help: 1508
    Rate: 659
    :) I have the same with "-" and "="
    Worth recommending:
    Link1
    Link2
    Link3
    and many others. Greetings.
