Does a 5.5kW 3-phase motor use 5.5kWh or more per hour at normal load?
hrabia24 47826 18
How much electricity does a 5.5 kW three-phase motor use in one hour at normal load, and is it three times 5.5 kWh because it is three-phase?
A 5.5 kW three-phase motor does not use three times 5.5 kWh just because it has three phases; 5.5 kW is the shaft output rating, not the electrical input power [#14036833][#14032453] The power drawn from the network depends on the motor’s efficiency and power factor, so the electrical input is roughly the shaft power divided by efficiency, and can be calculated from the nameplate values using √3 · U · I · cosφ [#14031581][#14032453] Therefore, at rated load for one hour, the energy taken from the supply is around the input power in kWh for that hour, but it will be higher than 5.5 kWh if you are asking about electrical consumption rather than mechanical output [#14036833][#14032453] If the motor is not at rated load, the consumption changes with the actual load, so the exact value has to be taken from the nameplate or measured in practice [#14029651][#14031996]
  • #1 14028909
    hrabia24
    Rate: 13
    I would like to find out whether my 5.5 kW three-phase motor, operating at normal load for an hour, will consume 5.5 kWh of electricity or three times more. Thank you.
  • #2 14029651
    kindlar
    Help: 919
    Rate: 1622
    Show the nameplate and see the cosφ (its efficiency). The engine will draw enough energy from the network to compensate for the load, which may result in its heating. If you load it more, the rotor`s slip in relation to the rotating magnetic field will be greater, and it will draw more current to keep up with the stator field rotating at a constant speed. (Rotor slippage is normal, so don`t worry).
  • #3 14031122
    hrabia24
    Rate: 13
    The question is: will it use 5.5 kWh when running without load for an hour, or 3 times 5.5 kWh?
  • #4 14031162
    mczapski
    Level 40  
    Help: 468
    Rate: 1659
    hrabia24 wrote:
    operating at normal load for one hour
    If
    hrabia24 wrote:
    working without load for an hour
    First of all, it`s best to check it practically. Power is power regardless of the number of power phases. Going further, power is work over time. So if you`re not putting any load on the engine, you`re basically not doing any work.
    hrabia24 wrote:
    kw/h
    Something doesn`t seem right.
  • #5 14031207
    jurek84
    Help: 33
    Rate: 67
    hrabia24 wrote:
    I would like to know this or mine 3-phase motor 5.5 kW operating at normal load for one hour , will consume 5.5 kW/h electricity or three times more. Thank you.
    It will consume 5.5kWh.
    Moderated By retrofood:
    I removed "He helped" because it is obviously untrue.
  • #6 14031378
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    Is it exactly that much or should something be added to this bill, e.g. some losses or resistances.
  • #7 14031442
    czesiu
    Help: 454
    Rate: 841
    You would have to add it, because engines are determined by shaft power. The power consumed from the network is the product of voltage, current, cosφ and √3.
    Cosφ is not efficiency.
  • #8 14031581
    jurek84
    Help: 33
    Rate: 67
    Right, I forgot to add that for the perfect engine. Divide the power by the efficiency and you will have the power drawn from the network during continuous operation under the maximum allowable load.
  • #9 14031641
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    These are heat losses, bearing resistance, and engine cooling fan. Engine efficiencies are listed in engine catalogues.
  • #10 14031996
    retrofood
    Help: 1140
    Rate: 4798
    hrabia24 wrote:
    I would like to find out whether my 3-phase 5.5 kW motor, operating at normal load for an hour, will consume 5.5 kW/h of electricity or three times more.
    Apart from these kW/h, which please correct, only a fortune teller knows how much the engine will consume under normal load, because apart from the fortune teller, no one knows how much is "normal". Especially since you are about to write about working without any burden.
    However, the technical term is load rated .
    And for the rated load, all values are given on the nameplate.
  • #11 14032011
    Kris555
    Help: 6
    Rate: 20
    The energy consumed by the receiver is the product of its power and time unit. In other words, your engine will consume approximately 5.5kWh per hour at rated load, of course with a constant and unchanging load.
  • #12 14032453
  • #13 14034173
    mczapski
    Level 40  
    Help: 468
    Rate: 1659
    Well, well. And which of the distinguished informants can provide the engine/system with a constant, nominal load for a long period of time? Of course, outside the laboratory or measurement station. And the questioner insisted on knowing for rated parameters or maybe without load. Does this not bother you?
    As I have already testified, power is power regardless of how it is obtained. You consume and pay for work (energy consumption). So, in real conditions, it is unlikely that you will load the engine with just 5.5 kW (never mind the little things) and you will pay for the number of work units multiplied by the unit rate plus additional fees. The measuring system reads the amount of work.
  • #14 14034940
  • #15 14036833
    Aleksander_01
    Help: 1167
    Rate: 3435
    Oh, gentlemen, but these 5.5 kW are shaft power, not absorbed power.
    At rated load, the power of such a device drawn from the network is greater by the efficiency, cos φ (to put it briefly).
    All data is listed on the nameplate, including power consumption.
  • #16 14038337
    jurek84
    Help: 33
    Rate: 67
    This is not a problem with fans or pumps, and these are just 2 examples. I think there is no point in continuing this thread any longer because the author`s question has already been answered several times.
  • #17 14038810
    mczapski
    Level 40  
    Help: 468
    Rate: 1659
    jurek84 wrote:
    at fans or pumps
    There`s really no point in continuing, but when experts write something like this, it`s hard not to react. Did your friend know the laws of thermodynamics? For example, a change in the medium temperature by 1°C causes changes in the engine`s operating conditions. So be careful with exposing your messages.
  • #18 15578160
    hrabia24
    Rate: 13
    I have capitulated and am closing the issue.
  • #19 15578544
    retrofood
    Help: 1140
    Rate: 4798
    In technology, you should use strict terms, if you call something "normal", everyone can understand it in their own way. Hence, there is no chance to obtain a clear answer.
The discussion centers on the power consumption of a 5.5 kW three-phase motor under normal load conditions. The consensus is that the motor will consume approximately 5.5 kWh when operating at rated load for one hour. However, it is emphasized that this value may vary due to factors such as efficiency (cosφ), losses, and the actual load conditions. The power drawn from the network is influenced by the motor's efficiency and the power factor, which are specified on the motor's nameplate. Participants highlight the importance of understanding the distinction between shaft power and absorbed power, as well as the variability of load in practical applications.
