Single phase motor calculation of the current that it draws from the network
apexior 15741 5
  • #1 16280803
    apexior
    I have a problem with one task I would be very grateful for help
    1. Calculate the current that the single-phase motor draws from the network with data:
    Pn = 1.5 KW
    Un = 230V
    cosfn = 0.8
    revolutions = 1450 / min
    85% efficiency
    miecho18
    IT specialist
    Help: 3087
    Rate: 2775
    And books are where you lost? The formula for power drawn from the network is P = U * I * cos?
    Berend
    Help: 15
    Rate: 88
    I=P/Un*cosφ*η
    9,59[A].
  • #4 16280861
    apexior
    I knew this pattern, but don't I have to consider efficiency and frequency?
    Added after 5 [minutes]:
    Berend wrote:
    I = P / Un * * cos ?
    9.59 [A].
    Thank you for your help, so I don't have to consider these engine revolutions?
    Berend
    Help: 15
    Rate: 88
    Turnover and a few other things depend on the frequency, which will definitely not be useful to you at this stage.
  • #6 16280904
    apexior
    To close
