YDYżo Cable Identification: Understanding Wire Types & Decoding Labels (Max 90 Characters)
kolbi 55004 11
How can I correctly identify and decode the type and construction of an electrical wire from its label?
YDYżo denotes a solid-copper cable with PVC insulation and a PVC outer sheath, including a green-yellow protective conductor [#1511258] It is intended for permanent installations, typically with 2–10 conductors [#1511266] The cable is rated 450/750 V, has class-1 solid copper conductors, and is suitable for dry or damp rooms on or under plaster [#1511280] YDYżo is not suitable for direct burial in a trench because it is not intended for wet ground conditions [#1511377] Use a ground-rated cable such as YKY instead [#1517617]
  • #1 1511213
    kolbi
    Rate: 44
    Hello, I can't find a good description of the wires somewhere, I don't know how to read exactly what kind of wire it is, I understand that there was a wire, but it's harder, I had another name, but I also had a problem.
  • #2 1511258
    metalex
    Help: 7
    Rate: 26
    YDYżo cable is a cable with solid copper conductors, PVC insulation and PVC sheath, with a green-yellow protective conductor
  • #3 1511266
    Józef18
    Level 32  
    Help: 168
    Rate: 165
    Yes, I am a colleague above, but also: for permanent installation. Number of wires from 2 to 10.
    Regards
    Joseph
  • YDY and YDYzo cable specifications and applications
    #4 1511280
  • #5 1511310
    kolbi
    Rate: 44
    Ok, thank you very much, and am I suitable for digging into the ground.
  • #6 1511377
    metalex
    Help: 7
    Rate: 26
    this cable is not suitable for laying in a trench
  • #7 1511381
    jiwaniuk
    Help: 142
    Rate: 145
    Generally, cables reinforced with tape or wires, eg YKYFty, should be laid in the ground. If you are 150% sure that it will not be possible to damage the YDYŻo cable laid in the ground, then you can do it (for private use), although it will not be entirely in accordance with the requirements of the regulations. (In other words, you do it at your own risk.)
    I greet everyone
    jjanek
  • Use YKY cables instead of YDY underground
    #8 1512464
  • #9 1513017
    kolbi
    Rate: 44
    Well, gentlemen, so now I don't know anything, I want to run 220V in this cable, I will bury it at my own risk because, by the way, I buried one such cable (sloppy) and it broke down somewhere, there was a break.
  • #10 1517617
    Raaf
    Help: 37
    Rate: 77
    YDY is generally not suitable for laying in the ground. There is YKY to be laid in the ground, as they wrote above.
  • #11 1568966
    piter244
    Help: 56
    Rate: 73
    If I can help you with the old way, you shouldn't bury this wire directly in the ground, but you can buy a reinforced conduit (usually gray) for it and bury it in a conduit
  • YDY hardens in frost; use YKY underground
    #12 1569723
    apistograma
    Rate: 18
    You also have to consider winter conditions. The ground is frost-free up to about 1.2 m deep. Cables with a voltage of up to 1 kV are laid at a depth of 0.5 m and 0.7 m. Ordinary YDY hardens very much at about 0 degrees. It also shrinks by the way. There is a very high probability that in severe frosts + the pressure of the ground, the cable will not withstand and break or the outer coating will come loose and water will enter. Do not be sorry for the money and buy YKYs with a diameter of 1.5 mm?
The YDYżo cable features solid copper conductors with PVC insulation and sheath, designed for permanent installations in dry and damp environments. It is rated for 450/750 V and has a maximum working temperature of 70 °C. The cable is not suitable for underground installation due to its lack of armoring and potential risk of electric shock. Alternatives like YKY cables are recommended for underground use. Users are advised to consider environmental factors, such as frost, when burying cables and to use protective conduits to prevent damage.
