Installing Weeb.tv Plugin on Amazon Fire Stick UK via Kodi and Zip File Instructions
gsacewicz 18723 6
  • #1 14726454
    gsacewicz
    Rate: 42
    I am looking for help with starting weeb.tv on amazon fire stick purchased in the UK. Fire stick works on android. I was able to install kodi, but have no idea how to add a plugin from a zip file. Would someone be able to help me? Maybe someone had a similar problem. Thanks in advance for any suggestions.
  • #2 14731394
    gsacewicz
    Rate: 42
    I would like to close the topic. After a few days of the combination, I was able to start weeb tv. The drobox and the file explorer helped. If someone has a similar problem, I will be happy to help.
  • #3 14758034
    Dominik7878
    Please help me load the weeb tv plugin to the fire tv stick. I was successful with kodi, but I can not install the plug. I have tried with dropbox and exporter already, I can see plugin in kodi but it won't load. I've been fighting for a couple of days now and nothing.
  • #4 14861682
    ds1979
    I have the same problem. I have loaded Kodi on my Fire stick but cannot add WEEB tv. Could you please help?
  • #5 14861939
    gsacewicz
    Rate: 42
    After installing kodi on the fire stick, I also installed a dropbox on it, on which I have a weeb tv plug. I opened the dropbox on the fire stick, found the weebtv plug and transferred the fire stick to the memory using the file explorator, which also needs to be uploaded to the fire stick. I transferred all these applications to the fire stick from tel using apps2fire.
  • #6 18998330
    Mateuszio
    Rate: 10
    Would you help I have a fire stick, I had other TV on it before, and now I wanted to embrace weeb.tv on it.
    I don't know how to do this. Can you help
  • #7 19147412
    bednarus11
    Hi, can someone install WEBB.TV in Kodi on a fire stick?
    Thanks in advance!
Users are seeking assistance with installing the weeb.tv plugin on Amazon Fire Stick devices, particularly after successfully installing Kodi. Common methods discussed include using Dropbox and file explorers to transfer the plugin. Some users report success after following similar steps, while others continue to face challenges in loading the plugin within Kodi. The discussion highlights the need for clear instructions on how to effectively add plugins from zip files on the Fire Stick.
