Playback Error in Kodi Version 18 on MAGICSEE n5 Max TV Box: Weeb.tv Connection Issues
alturis 10284 9
Why does weeb.tv in Kodi 18 stop playback after a few seconds with a connection interrupted error on a MAGICSEE n5 Max TV box, and how can it be fixed?
The playback error is likely caused by Kodi 18.4; downgrading to Kodi 18.3 Leia fixes weeb.tv on this box [#18155311] One user confirmed that it works on 18.3 and noted the problem appeared after the update [#18155554] To reinstall an older version, download the old Kodi APK and install it from file [#18300663] If the TV box will not install from a file directly, use a file viewer app to complete the installation [#18301553]
  • #1 18152514
    alturis
    I have a problem with Kodi (version 18) on box tv, specifically with the weeb.tv plug. Login to weeb.tv correct, I can see the channel list. When I select a channel, it goes for 3 seconds and then I get the message "Playback error! The connection was interrupted for unknown reasons."
    The device Kodi is installed on is MAGICSEE n5 Max TV Box.
    Weeb.tv works on a different device, there is also no problem with internet connection. All devices on the network have access to the Internet.
    The tv box itself works, other applications work properly.
    What could be the reason?
    I will add that I changed the version of Kodi to 16 and Kodi, after selecting the channel, it stops the application. Anyway, it's impossible to use Kodi.
    Anyone have any idea what can be done to make weeb.tv work?
    Regards
  • #2 18152985
    uneasy
    Rate: 13
    A few days ago it worked normally, and I have had the same for 2 days.
    Generally, weeb.tv and kodi have always had some weird actions.
  • #3 18154357
    lordzik0207
    I have the same problem ... is there any other program where you can download a plug from weeb ???
  • #4 18154780
    uneasy
    Rate: 13
    Nothing else is there
  • #5 18155311
    panterkaaaa
    heyo,
    if you have a version of kodi 18.4, reinstall the version to 18.3 leia, which is easily available on the net. On the older version, 18.3, everything works fine. Computer scientists are working on improving kodi, but it is not known how long it will take.
    If there is a problem, write priv.
    Greetings and good luck.
    Marianna
  • #6 18155554
    uneasy
    Rate: 13
    Well, it didn't occur to me that it's after the update. It works on 18.3
  • #7 18300656
    Bestdriver90
    Does anyone know how to reinstall kodi to an older version on Sony tv with android?
  • #8 18300663
    uneasy
    Rate: 13
    Download the old version apk odisntsluj to tv, install from file.
  • #9 18300842
    Bestdriver90
    Only that I can not install from the file on tv. That's the problem.
  • #10 18301553
    uneasy
    Rate: 13
    I have a Sony with an android ;) download file viewer apps and get it done
Users are experiencing playback errors with the Weeb.tv plugin on Kodi version 18 installed on the MAGICSEE n5 Max TV Box. The error message indicates a connection interruption after a few seconds of attempting to stream a channel. While Weeb.tv functions correctly on other devices, users suggest that reverting to Kodi version 18.3 resolves the issue, as version 18.4 seems to introduce problems. Some users are also inquiring about alternative methods to install older versions of Kodi on different devices, such as Sony TVs with Android.
