OpenATV IPTV: Best IPTV Plugins for OpenATV to Upload M3U Lists and Watch Live TV
m2k18 57960 3
  • #1 19158191
    m2k18
    Hello. Are there any plugins for OpenATV that will allow me to upload m3u list to watch IPTV?
    Przem188
    EDA specialist
    Help: 157
    Rate: 156
    JediMakerXtream - you upload your m3u file or streaming server data (link and port, login and password) and you have video streams on the channel list as if they were SAT programs.
  • #3 19171453
    pufa4
    Rate: 27
    Hello, the JediMakerXtream plugin added bouquets from my m3u list to the channel lists without any problems, unfortunately without EPG and picon. Can anyone help on this topic.
  • No EPG support in IPTV plugin itself
    #4 19171543
    Przem188
    EDA specialist
    Help: 157
    Rate: 156
    The fact that there is no EPG is not the fault of the plug. Both only converts m3u or server data into a form that is bearable by the enigma channel display system.
    It's the sender's fault. However, I do not know whether the EPG, which is a system for transmitting information about the program via sat platforms and terrestrial multiplexes, has an implementation in streaming. Ie. there is something, but it's probably about converting from Sat signal to system in stream. I haven't met a broadcaster that offered this for TV yet.
