Understanding Varistor Functionality: Choosing Right Parameters for a 12V LED System
legalnl 46347 11
Can I use a varistor in series to stop a 12V LED system from glowing at 4V, and how do I choose its parameters?
No — a varistor is not the right part for that job; it is mainly used as surge protection, connected so it clamps overvoltage by becoming low-resistance at a threshold, not as a series element to block low voltages [#15112402][#15112822] If you put it in series with the LED load, low voltage will stop current, but then you must raise the supply by the varistor drop, and the varistor will waste power and may overheat or burn [#15112382][#15112402] The “operating voltage” should be below the point where the varistor starts to have noticeable current, while the “varistor voltage” is the threshold where it begins to conduct strongly; for example, one reply describes an 18 V varistor as suitable only up to about 14 V DC or 11 V AC, and another gives a 320 VAC part that starts conducting around 510 V at 1 mA and needs about 700 V for 1 A [#15112402][#20218800] So for your LED problem, use a switch or other circuit that cuts the voltage off completely until the supply is correct, instead of trying to use a varistor [#15112382]
  • #1 15111412
    legalnl
    Hello and welcome!
    I would like to ask for a detailed practical explanation of how a varistor works, because the same description is usually found on the Internet and does not say much.
    I found out that its resistance decreases as the voltage increases, which I understand allows it to eliminate small voltage noises, e.g. induction?
    I have an LED system powered by a changing voltage of 12V, but a voltage of 4V will also light up the diodes slightly, which I would not like, can I use a varistor for this? What parameters should it have and how to choose it? A smaller current would encounter resistance and not flow to the LED system, when the voltage reaches about 12V the resistance of the varistor would decrease and this would allow the system to operate, am I right? how to choose the right one?
    Regards.
  • #2 15111564
    strikexp
    Help: 101
    Rate: 104
    Varistors are mainly used as surge protection. I'm not sure, but probably its resistance decreases dramatically when a certain voltage is exceeded. This causes the connector connected between ground and power to short circuit during an overvoltage and dissipate excess energy (voltage) to ground.
    There are basically 3 types of varistors:
    1. Small electronics - they are mounted in electronic equipment on a board. They cost a few dozen cents to a few zlotys.
    2. Protection varistors - they look like a residual current fuse and are installed in fuse boxes. They protect electrical devices against network overvoltages (from lightning), at least up to a certain value and when other requirements are met. They cost from PLN 200 and up.
    3. Grid varistors - they can be seen on power lines, they discharge lightning striking the power line. They look like insulators and cost a lot of money.
  • #3 15111604
    legalnl
    Example parameters:
    varistor voltage = 18V
    protected voltage = DC 14V, AC 11V
    Does this mean that current above 14V is not subject to resistance? 18v is the maximum voltage? how to understand?
    The most I see are several hundred Vs, e.g.:
    Type: V20N391K
    Maximum operating voltage: 250VAC; 320VDC
    Varistor voltage: 390V
    What does it mean? maximum operating voltage is 320VDC and voltage is 390V, how to understand this?
  • #4 15111635
    strikexp
    Help: 101
    Rate: 104
    Resistance is not found only in superconductors!
    The maximum voltage is most likely the one at which the resistance drops rapidly. The varistor voltage is most likely the voltage at which the varistor behaves like a conductor.
    But let someone else answer because I'm not a varistor specialist :)
  • #5 15112382
    jesion40
    Help: 100
    Rate: 127
    It's always worth using Google ;)
    On the example website with a description of typical elements you can see, among others: characteristics of various types of varistors. The bend of the U/I curve, i.e. the speed of switching on as a function of voltage, varies, but in general there is a clear gap between the voltage at which a significant current begins to flow and the voltage at which the current increases so rapidly that it practically prevents further voltage increase.
    The operating voltage is set below the first threshold, then the varistor has practically no effect on the operation of the system, while the protection is effective at the second voltage, because this is how long the system must withstand before the varistor takes over the current for good.
    Coming back to your idea of using a varistor connected in series to avoid slight LED illumination at a small voltage lower than the rated one, this is probably not the way to go. Yes, when the voltage is low, the current will not flow and the LEDs will not light up, but later
    1) you will have to increase the supply voltage by the value of the varistor voltage to make the current flow
    2) the power dissipated by the varistor will not only worsen the efficiency of the system but may also destroy it
    If you want to solve the problem of LED lighting at low voltage, you should use a key that will cut off the voltage completely until the voltage is correct.
  • #6 15112402
    dpieciak5
    Rate: 45
    In general, a varistor is a valve-fuse that protects a given system against overvoltages - the voltage increases, the resistance decreases and, as a result, the current increases ("overvoltage energy"), which flows to the minus of the power supply or to ground, depending on the place of work, and bypasses it by wide margin. protected device or system :) .
    The protected voltage is the maximum voltage at which the varistor can operate without unnecessary increased current consumption or flow, and the varistor voltage is simply the voltage at which a full short circuit of this element occurs, e.g. according to your example, an 18V varistor will work correctly for DC voltages of max. 14V and AC. max 11V, so let's say you want to protect an electronic system operating at 15VDC and if you insert such a varistor there, its resistance may decrease so much that the "valve", e.g., opens halfway and a larger current will flow through it, causing it to constantly heat up (and consequently burn out). ) additionally loading the power supply system, e.g. the battery, and discharging it faster. The given varistor will well protect the device, e.g. 10VDC or AC, because the maximum operating voltage is 14VDC and 11VAC (high resistance and negligible current). Any exceeding of the operating voltage and varistor voltage causes the overvoltage to be extinguished. The higher the voltage, the faster the overvoltage decay time.
    This results from the characteristics I=f(U) of the varistors. I hope I explained it in a quite layman's terms and simple way.
  • #7 15112822
    Marian B
    Help: 392
    Rate: 1161
    Much can be explained by the physical principle of operation of a varistor and its structure. This is an element in which, when a certain threshold voltage is exceeded, a series of miniature electric arcs occur on many "spark gaps".
    In simple terms, an electric arc is equivalent to a short circuit, low resistance. No arc, e.g., before exceeding the threshold voltage, and after exceeding the threshold voltage, its decrease, high resistance.
    http://www.google.pl/url?url=http://www.zsp1s...KEwjD3Yey7u7IAhXEXBQKHf4fBxc&usg=AFQjCNHqSyG0 tcKDzvV0QpDzHIQOPFRaXw
  • #8 18152841
    lukas198820
    Help: 6
    Rate: 335
    How to check a varistor with a meter without desoldering it?
  • #9 18152934
    jarek_lnx
    Help: 4198
    Rate: 6126
    It shouldn't be conductive, that's all you can check with a meter.
  • Varistor may not clamp before semiconductor failure
    #10 20218670
    Frank-01
    I have encountered such cases: a) the module controlling the operation of my washing machine activates the door lock through a semiconductor control element protected by an appropriate varistor. Once, after turning on the washing machine, a semiconductor element cracked so much that even one of its legs melted, and the driver on the chip died, and the varistor looks healthy and happy; b) in the shepherd, the S10K320 varistor is to protect the thyristor discharging the capacitor on the HV transformer. I charge the capacitor to 500V and it works, the spark is longer and the varistor does not react. How can this be explained?
  • Varistor clamps only one type of overvoltage
    #11 20218800
    jarek_lnx
    Help: 4198
    Rate: 6126
    With a functional lock and installation, the maximum power in the circuit would be too low for the element to fire, there must have been an overcurrent. The driver in the chip failed due to the lack of driver protection - one less element for the manufacturer and a few cents cheaper, and a greater chance that the washing machine will end up in the trash - only advantages. The varistor only protects against one phenomenon that may cause damage, but there are also other causes of damage.
    A varistor designed to operate at 320VAC (450V peak) starts conducting at 510V (1mA), but to flow a specific current, let's say 1A, about 700V is needed, with higher currents it will be even more (data based on the epcos SIOV metal oxide varistors datasheet)
  • Measured varistor current and failure time at 400V AC
    #12 20219477
    CYRUS2
    Help: 1241
    Rate: 3530
    A typical varistor has a power of 2W.
    The continuous operating voltage is one that will not damage the varistor under normal power supply.
    Parameters of the varistor circuit breaker:
    275V AC continuous operation (400V AC will destroy the limiter)
    1.5kV limitation threshold.
    This means that if there is an impulse, e.g. 2kV will limit to the 1.5kV level
    (it must be very short - a longer pulse will destroy the limiter)
    Surge protection strip – limit threshold 1.2kV.
    (applies to impulse)
    I measured the "275L20" varistor.
    Diameter 15.3 mm, thickness 2.9 mm.
    Measurement of AC current consumption.
    275V - 56uA
    330V - 3.6mA
    350V - 10mA
    370V -37mA
    400V - approx. 100mA.
    The time after which the varistor will short-circuit depends on the heat released. (physics)
    In the case of the varistors I measured, 400V AC was about a second.
    However, 390V AC is quite long - a few seconds.
    Joules – more joules – limits the endurance for longer impulses.
    At 400 V AC (instead of 230 V) - more joules = it will take a long time before the varistor short-circuits.
    This means that the device will be under 400V AC voltage for longer
Varistors are components primarily used for surge protection, functioning by decreasing resistance as voltage increases, thus allowing excess voltage to be diverted to ground. They are categorized into three types: small electronics varistors, protection varistors for fuse boxes, and grid varistors for power lines. When selecting a varistor for a 12V LED system, it is crucial to understand the parameters such as varistor voltage and protected voltage. The varistor voltage indicates the point at which it begins to conduct significantly, while the protected voltage is the maximum voltage it can handle without excessive current flow. For a 12V LED system, a varistor with a voltage rating above 12V but below the maximum operating voltage of the system is recommended to prevent unwanted LED illumination at lower voltages. The discussion also highlights the importance of understanding the U/I curve of varistors and their operational thresholds to ensure effective protection without compromising the system's functionality.
