Converting Spaces to Newline Characters in Notepad: Step-by-Step Guide for Text Conversion
speaker1 39204 4
  • #1 15122219
    speaker1
    Rate: 8
    I need to replace spaces with enter characters in the text. I know that it can be done easily in Word, Excel etc. but I'm only interested in the notebook.
    Text before conversion:
    Ala has a cat
    After swapping:
    Ala
    has
    the cat
    Of course, I use the function convert to ctrl + H and type:
    Enter: Alt + 013, but that doesn't work.
    Space: Alt + 032- Works for spaces, but does not for enter.
    Greetings.
  • #2 15124036
    krzysiozak
    Level 40  
    Help: 512
    Rate: 1156
    Unfortunately, I will not give you an answer to your question, but something that may put you on the right path.
    I can get [Enter] by pressing ALT-13 [So no zero]. [?]
    Good luck.
  • #3 15124218
    fakvat
    Help: 12
    Rate: 38
    Use edit plus instead of notepad. is a good replacement, first of all it is not a mare MS Word program. It has many possibilities, one of which is regular expressions. A powerful tool for manipulating text data. You do it this way
    CTRL + H -> replace -> you mark regular expressions -> space as a character searched for replacement at the bottom \ n as a line break
    ps. in linux it's easier to cat old | tr '' '\ n'> new
    nothing is simple in a notebook, not even such trivial things
  • #4 15862078
    mmmaras
    Rate: 36
    Edit Plus is shareware. The method described by a colleague fakvat obviously works nicely, however the same can be done using a free text editor called Notepad ++
    To make this change, just click CTRL + H then in the box " Search text "enter" space "(or another character / text that we want to go to a new line), and below in the field" change to "we type" \ n ".
    Additionally, below in the box " Search mode "you have to select an option" Regular expressions ".
