Export Data from Excel to .txt File with Commas as Column Separators: Step by Step Guide
Skysky2 7377 4
  • #1 16923334
    Skysky2
    I was looking for a long time, but I did not find a solution to my problem, so I am writing here.
    I would like to export data from excel file to txt file and separate each column with comma.
    Specifically, it is about exporting from excel -> txt.
    The data that I want to export from Excel look like the screenshot below.
    I would like it to be written in the .txt file like this:
    1, the text, text, text, text, text ,,,,
    2, text, text, text, text, text ,,,,
    3, text, text, text, text, text ,,,,
    How can I fix this problem?
    best regards
  • #3 16924088
    Skysky2
    zen3x wrote:
    Comma separated values are excel file export to cvs format. https://pl.wikipedia.org/wiki/CSV_(format_pliku)
    Thank you for your answer ;)
    I saved the file in CSV format and opened it via a .txt file, however now the column contents have been separated by a semicolon, not a comma.
    How can I separate them with a comma?
    best regards
    clubs
    Help: 629
    Rate: 406
    It could be a macro
    Code: VBScript
  • #5 16932832
    Maciej Gonet
    VBA, Excel specialist
    Help: 824
    Rate: 481
    The .csv format uses the list separator declared in the operating system settings. If in the Control Panel in the international settings (region) you change the list separator from a semicolon to a comma, and the decimal separator from a comma to a period (so there is no conflict), then the entry in the .csv format will be with a comma, not with a semicolon.
