ACER Q65H2-AM - POWER SW, POWER LED, RESET SW, USB1 and SPEAKER connection
valior96 45531 11
How do I connect the POWER SW, POWER LED, RESET SW, USB1 and SPEAKER wires on an ACER Q65H2-AM motherboard?
Use the motherboard manual and the front-panel diagram under connector 14 to identify the power/reset/LED pins on this board [#15226421] The USB header uses a standard pin layout, so you can verify it with a meter if needed [#15226300] The speaker is already soldered on the board, and the front-panel LED connections may need trial and error because the exact pair can vary; do not connect LEDs directly to Vcc and GND or they can burn out [#15226300][#15273597]
  • #1 15226238
    valior96
    Rate: 11
    Please help me connect POWER SW, POWER LED, RESET SW, Ground, Port +, Port-, VCC and SPEAKER on ACER Q65H2-AM, or if someone has instructions for this CD, I would like to see it too.
    ACER Q65H2-AM - POWER SW, POWER LED, RESET SW, USB1 and SPEAKER connection ACER Q65H2-AM - POWER SW, POWER LED, RESET SW, USB1 and SPEAKER connection ACER Q65H2-AM - POWER SW, POWER LED, RESET SW, USB1 and SPEAKER connection ACER Q65H2-AM - POWER SW, POWER LED, RESET SW, USB1 and SPEAKER connection
  • #2 15226300
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    - SPEAKER, you have already soldered on the board ...
    - USB has a standard pin layout:
    For sure you can check with the help of the meter.
    Which one is the front panel connector? (power_sw etc.). On the screens you can not see. The description should be on the plate, look for it.
    This is a disc drawn from the Acer Veriton M4610, buying such a scrap is never a good idea. The instructions are rather not what I see.
  • #3 15226398
    rafi84
    Help: 52
    Rate: 141
    And over the IDE connector what you have on the disc, manual can not find and also poor quality pictures on the net you can see that there are some goldpins.
  • #4 15226409
    valior96
    Rate: 11
    the problem is that I can not find the front panel connector I have only connectors under usb, F_audio ini_spk and COM2
    I bought anything that fit under the socket, on my current card the entry p16 x16 broke down
    EDIT
    I can make a "zoom" of each element, this is a photo of the disc
    rafi84
    Help: 52
    Rate: 141
    Here you have manual for this CD Link
    under 14 you have a front panel and here you have the description Link
    Greetings
  • #6 15273501
    valior96
    Rate: 11
    does anyone know whether I have connected it well and where to connect what has left me?
  • #7 15273535
    rafi84
    Help: 52
    Rate: 141
    It seems to me that it is bad.
    You got the link how it should look.
  • #8 15273589
    valior96
    Rate: 11
    but I do not embrace those signs you could write to me what to connect in turn?
  • #9 15273597
    sylweksylwina
    Help: 1882
    Rate: 2355
    It is strange to have this output plate on fp. Try it as I drew in the picture. It does not guarantee operation, as it may turn out that eg hdd led should be connected under pins 1-3, and power led for pins 1-2 or 14-12. However, if you connect badly ledy, you should not do anything wrong, you can do it by trial and error (only do not connect directly under Vcc and gnd because diodes can burn). I will not tell you where to connect Vcc and ground from your case because I do not know what they are leading. ACER Q65H2-AM - POWER SW, POWER LED, RESET SW, USB1 and SPEAKER connection
  • #10 15274449
    valior96
    Rate: 11
    I did as you wrote, Sylweksylwina and the cooling fan is spinning for a moment (one pulse as if) and turns off
    does anyone have any idea how to connect it?
  • #11 15274586
    sylweksylwina
    Help: 1882
    Rate: 2355
    Describe the entire computer configuration, including the brand and power supply model. For starters, run the power supply with the board and processor and the only switch connected, the board should turn on, the buzzer should signal the lack of RAM memory.
  • #12 15277038
    valior96
    Rate: 11
    Tagan tg600-u33 power supply. I connect the board memory and i3 3210 processor with box cooling without connected drives in the configuration you recommended.
The discussion revolves around connecting various components such as POWER SW, POWER LED, RESET SW, USB, and SPEAKER to the ACER Q65H2-AM motherboard. Users express difficulty in locating the front panel connector and seek guidance on proper connections. Some provide links to manuals and diagrams, while others suggest trial and error for connecting LEDs, cautioning against incorrect connections that could damage components. A user mentions their power supply model (Tagan tg600-u33) and processor (i3 3210) while troubleshooting the setup, indicating that the board powers on briefly but then shuts down, prompting further inquiries about connection issues.
