ACER RS880M05A1 Motherboard Connection Guide: Front Panel Setup & Link to Instructions
derickk 10275 3
  • #1 16888343
    derickk
    Hello all,
    I bought the ACER RS880M05A1 motherboard. The problem is that I can't find the connection instructions and I don't want to experiment. It's about connecting the front panel. Please help. Welcome link to the site.
  • #3 16889372
    safbot1st
    Help: 2719
    Rate: 1585
    nomudrek wrote:
    A good picture of the Sata nests would help a lot,
    You can see everything. It has more or less the same as in # 2 post from the link, photo 1.
    But the diagram in picture # 2 from the link is wrong, because from the Foxconn board.
    And why Acer has installed an additional yellow and green field - I do not know.
    Buttons that can be mounted freely:
    Blue - Reset
    Red - Power
    Diodes that must be installed with the correct polarity:
    Green - Power LED
    Yellow - HDD LED
  • #4 16891448
    derickk
    Thanks for the helpful information. The disc works! I close the topic. :D
