Renault Tuner List - RENRDW131-10 - request to disable the code.
miecho18 5331 2
  • #1 15490694
    miecho18
    IT specialist
    Help: 3087
    Rate: 2778
    I accidentally mis-entered the code on the radio Renault RENRDW131-10.
    I have entered 3323 and it should be 3321. Now only the ERROR is displayed and the code can not be entered again.
    Is it possible to completely disable the code in this player? If so, please modify the batch.
    Greetings.
    • scenic II tuner list2.bin (4 KB) You must be logged in to download this attachment.
    korek516
    Help: 101
    Rate: 147
    Hello. Annex kode off. Greetings.
    • scenic II tuner list2_00.zip (1.41 KB) You must be logged in to download this attachment.
  • #3 15491286
    miecho18
    IT specialist
    Help: 3087
    Rate: 2778
    I connected the radio on the table and it looks like it's OK.
    Thank you so much for your help.
    Tomorrow I put a radio in the car, I will test it thoroughly and if it's OK, I will close the topic.
    Edit 08/03/2016:
    Everything "plays and hummers". Thanks again.
    Greetings.
