Genius 5.1 5000 Speaker: FR and FL Sound Volume Imbalance - DVD Input, Preamplifier, Output Stage
Floooo 10212 2
  • #1 15649244
    Floooo
    Hello. Please help. My speaker Genius 5000 does not play the same loud.
    Example: Input is DVD and speaker FR is good and FL is 10% louder.
    This is all.
    All input I am working equally.
    Preamplifier can be evil? Or output stage? This may make a potentiometer?
    Thank you
    • Genius_SW-5.1_Home_Theater.pdf (5.77 MB) You must be logged in to download this attachment.
  • #2 15662156
    diddygy
    Rate: 14
    Hi try exchange condesator ...
  • #3 15746037
    Fulcro
    Hello. Different output volume by the speakers is often related to faulty final stage. In your case, the final stage for FR and FL is the same (it seems to be the IC3 TDA7289A).
    Have you tried to swap FR and FL connections?
    This is the first move to do.
    May also be a speaker defective...
    If you have an oscilloscope can verify the input signals in the TDA to see if they are the same amplitude...
