Room Acoustics: Optimizing Genius SW-G2.1 2000 Subwoofer Placement for Better Bass Experience
Huxa3em 8442 13
How can I place a Genius SW-G2.1 2000 subwoofer so the bass is stronger at my desk instead of only being loud in other parts of the room?
Your desk position is likely sitting in a bass null from the room acoustics, so changing subwoofer placement and orientation is the main thing to try first [#16457283][#16457937] Put the sub on the other side of the desk, between the door and the sofa, or in a corner, and experiment with facing it toward the wall or toward the couch [#16457283][#16457344][#16485521] Use the “subwoofer crawl” method to find the spot where bass is most even in the listening area [#16457937] If moving the sub around the room still leaves the desk with little bass, then the room itself is causing the problem and there may simply be no placement that gives the desired bass at that seat [#16461158] In that case, the practical options are to change the room layout, accept the system’s limits, or replace it with a better subwoofer [#16486695]
  • #1 16457264
    Huxa3em
    Recently I bought "Genius sw-g2.1 2000" speakers and I have a problem with them.
    Well, the main problem is bass. I miss it in the place where I use the computer (I sit frontally to the desk)
    However, I noticed leaving the room (when the music was on), or rather I heard that from that place the bass is perfect, deep strong beats and low tones, and at the desk it is completely inaudible. There are 120-60hz tones spinning there, and even 50-35hz can be heard at the door.
    Maybe you can help me with it, because I don't know if it is a problem with the acoustics of my room or if I just put the subwoofer wrong: x.
    This is my room:
  • #2 16457283
    aaanteka
    Help: 729
    Rate: 1195
    Show some inventiveness and put the bass on the other side of the desk, the other side of the room between the door and the sofa. Check how you currently have a subjective listening experience in the room.
  • #3 16457310
    Huxa3em
    So, I walked around the room with the subwoofer, with no results. I want good bass to be heard around the desk, but no matter where I moved the sub, there were differences in the room, but still the same at the desk. I noticed that if I turned the subwoofer with an air tube towards the couch, then the largest bass was heard there, but I tried to place the subwoofer as far away from the desk as possible and unscrew it as in the case of the couch. Nothing helps: C. (it is in the diagram, the subwoofer stands on the desk and not under it. It is strange that when the bass and volume are turned to max, the subwoofer moves so much that I have the impression that it will fly away, the desk shakes and the bass is not heard. And when I approach the door, the bass is jamming.
  • #4 16457344
    398216 Usunięty
    Help: 3925
    Rate: 9450
    Huxa3em wrote:
    the subwoofer stands on the desk, not underneath it.
    And how do you put it under the desk? Also try different settings - e.g. speaker sideways, to the wall ...
  • #5 16457710
    aaanteka
    Help: 729
    Rate: 1195
    And did you also stand against the opposite wall, near the door?
    The problem can be the location of the window and door opening.
  • #6 16457937
    aksakal
    Tube devices specialist
    Help: 1670
    Rate: 3004
    If you do not have big problems with understanding Russian and English on this website, excellent methodology and recommendations after choosing the location of the subwoofer + video on English with the method of choice - Subwoofer Crawl. http://cinemalounge.ru/vse-o-sabvuferax-part3/
  • Desk area remains a bass null despite subwoofer repositioning
    #7 16461121
    Huxa3em
    I placed the subwoofer under the desk, it did not help. I put the subwoofer on the other side of the desk, it didn't help either. I didn't learn anything interesting from the page above. I really walked around the room with the subwoofer, but no results. This is the problem, when I move the subwoofer, I check where it is best to hear the bass and I noticed that as the subwoofer position in the room changes, the power of the bass changes throughout the room except the regions around the desk. Maybe it's the desk's fault? But it's wooden, it doesn't matter?
  • #8 16461158
    fzyga43
    Help: 70
    Rate: 116
    Leaving the room, with the door open, you have created a two-chamber "enclosure" for the bass speaker. This resulted in resonance and amplification of the bass. In one room you will not find the suba position that will provide the bass you are looking for.
  • #9 16485114
    Huxa3em
    The problem is that the effect is the same with the door closed. And if I swapped the place of a desk with a table, and a sub on the table would it give something?
  • #10 16485131
    fzyga43
    Help: 70
    Rate: 116
    You wrote "leaving the room", I understand that you opened the door. Then a two-chamber "housing" will be created.
  • #11 16485163
    Huxa3em
    I may have expressed myself inaccurately, but even when the door is closed, just approach them and you can already hear the effects.
  • #12 16485521
    rimot
    Help: 145
    Rate: 146
    You have a room of 14m?. OKAY. And the height? Nobody mentioned it. It's best to put it in the corner, and if you feel like and want to, attach it to the phase regulator (adjustable). It's too much for me in the room.
    edit
    band-pass is a very hard topic. Still two-chamber? Open door? Place the furniture on the floor (do not run with it on your hands, it should stand on the floor). Play one song and ...
  • #13 16486376
    Huxa3em
    The height of my room is 2.40m. The largest bass can be heard from the back of the subwoofer (through the bass reflex opening, I think). The only way I can think of is moving the computer and sub to another room.
  • #14 16486695
    aaanteka
    Help: 729
    Rate: 1195
    At the beginning, the best solution is to evaluate the sound system by another person. Of course, without suggesting anything to anyone.
    The second solution is to change your hearing preferences and get used to the properties of the kit you have.
    The third solution: purchase of a decent, branded subwoofer.
The discussion revolves around optimizing the placement of the Genius SW-G2.1 2000 subwoofer to enhance bass performance in a user's room. The user experiences inadequate bass at their desk, despite the subwoofer producing strong bass when tested away from the desk. Various suggestions are made, including relocating the subwoofer to different positions in the room, such as under the desk or against walls, and experimenting with its orientation. The impact of room acoustics, including the effects of furniture placement and the room's dimensions, is highlighted. Some participants suggest that the desk's material may be affecting sound quality, while others recommend evaluating the sound system with a fresh perspective or considering a higher-quality subwoofer.
