Connecting 5.1 Speaker Set (1 Main, 4 Satellites, Subwoofer) to Sound Card with Mismatched Inputs
problem5.1 30513 27
How can I connect a 5.1 speaker set with three 3.5 mm plugs to a sound card that has blue, green, and pink jacks?
You can connect it directly if your speakers are wired as a 5.1 set with combined center/subwoofer: green from the speakers goes to the PC’s green jack, black to the blue jack, and orange to the pink jack, then set the audio output to 5.1 in the sound settings [#14676872] If your motherboard only exposes standard mic/line/front jacks, you may need the proper rear audio module/header for surround outputs, but in this case the speaker wiring above is the key fix [#14672013] After connecting, 5.1 test tones should play on all channels, but normal stereo music will still mostly play from the front two speakers unless you use multichannel audio or an upmixing player [#14678163]
  • #1 14667817
    problem5.1
    I apologize in advance because I do not know if I am writing in the right section.
    Hello. Well, today I bought a 5.1 speaker set (1 main, 4 satellites + subwoofer). All the speakers are connected to the subwoofer and there are 3 cables going from it to the sound card, here is the problem. The soundboard has blue, green and pink inputs and black, green and orange in the subwoofer cables. Is there a connection option to make 5.1 work? Thank you and best regards :)
  • #2 14667888
    Nandish
    Help: 27
    Rate: 73
    Enter the type of sound card.
  • #3 14667906
    SQLmaster
    Help: 31
    Rate: 172
    There is actually a problem because you will not connect.
    Your motherboard or sound card most likely has only these connectors:
    - pink: microphone input
    - blue: line input
    - green: 2 channels output
    You need a 5.1 card for this set. Perhaps yours has the remaining outputs as not led out (additional herring with sockets needed). But the chances are slim.
  • #4 14668073
    problem5.1
    I do not know if the screen is good and if its name is here.
    And is it possible to buy an adapter instead of buying a new card?
  • #5 14668786
    flubber.trip
    Help: 82
    Rate: 71
    First you would have to take a closer look at the option in the sound card settings. Once upon a time, on the old gigabyte board, I had the opportunity to change the functions of the 3 slots on the motherboard. They could be mic in, line in and line out as standard, or outputs to the 5.1 set. In addition, there was a separate connector on the motherboard for outputting the signal to the outside. Enter the type of motherboard, because I can see that the audio system is integrated.
  • #6 14669709
    problem5.1
    Again, I don't know if I gave it a good name, but I think it's the one.
  • #7 14671151
    flubber.trip
    Help: 82
    Rate: 71
    Give a screen from the cpuz program from the mainboard tab.
  • #8 14671447
    problem5.1
    You're welcome :)
  • #10 14672131
    problem5.1
    Which module exactly do I need to buy? :)
  • #11 14672516
    Nandish
    Help: 27
    Rate: 73
    MB - B85G-M
    for 5.1
    To blue - jack Rear L + R
    To green - Jack Front L + R
    For pink - Jack Subwoofer
    For the pink (front panel) Main jack
    here is about it
    Set the audio configuration to 5.1 sound
    Unfortunately, if you don't have a front panel, there won't be a microphone and a main speaker :(
    you will recognize the speakers:
    turn on everything not connected to the computer, set it louder. by touching the tip and center of the jack in the appropriate loudspeaker, you will hear crackling, or connect the jacks to the mp of three, the given pair of speakers will play. That's how you will recognize them.
    It should work ;)
  • #12 14672802
    problem5.1
    I can't do that because three of them come out of one cable and they won't reach me from the back to the front panel :( If I understood correctly.
  • #13 14672931
    Nandish
    Help: 27
    Rate: 73
    3.5 stereo jack extension cord, e.g. from headphones? Or do it yourself :)
  • #14 14673385
    problem5.1
    Nandish wrote:
    MB - B85G-M
    for 5.1
    here is about it
    It should work ;)
    You wrote here like this:
    And I only have 3 wires. Maybe I didn't understand something? :D
  • #15 14673629
    Nandish
    Help: 27
    Rate: 73
    Give the type and manufacturer of these speakers. Three plugs, 4 satellites, center, subwoofer? It is as if there was a 5.1 decoder, and the signal needed a digital one. Perhaps there is a simplification and it is not full 5.1. Fill in that details, I'll see.
  • #17 14676872
    Nandish
    Help: 27
    Rate: 73
    Well, I already know everything. You have a combined subwoofer and center :)
    In speakers:
    Green is Front
    Black to Rear
    Orange is the Center and Subwoofer together (Centr-Sub)
    So we connect you with:
    Green speakers to green comp (rear panel) front
    Black speakers to blue comp (rear panel) rear
    Orange speakers to pink comp (rear panel) cent / sub
    The system in 5.1 and is going to be a riot :) Regards
  • #18 14678113
    problem5.1
    Well, I connected as you wrote when testing the sound here Connecting 5.1 Speaker Set (1 Main, 4 Satellites, Subwoofer) to Sound Card with Mismatched Inputs
    all the speakers sound as they should. As I test here Connecting 5.1 Speaker Set (1 Main, 4 Satellites, Subwoofer) to Sound Card with Mismatched Inputs they also play well. In the control panel and the sound card panel set to 5.1, as if everything is 'hula' :) But, for example, music still does not want to play on all five, only on the main 2. When I test, they all play and when I play the music, the two main ones play and the rest hum a little. What did I do wrong ?
  • #19 14678163
    Nandish
    Help: 27
    Rate: 73
    This is how it should be, if the file is stereo, two speakers are playing. Look for a multi-channel music file, e.g. dts. There are also some kind of player or converter with the possibility of "scattering" the sound over the speakers. As a fan of 2-speaker sound, I don't know it anymore ;) . The cables should be as they are :)
  • #20 14678255
    problem5.1
    And if I go to YouTube and type 5.1 test, should all the speakers play? For me, only the front two play :)
  • #21 14678615
    Nandish
    Help: 27
    Rate: 73
    find a movie with 5.1 sound, not stereo.
  • #22 14678675
    problem5.1
    You can provide a link because I can't comprehend it :)
  • #23 14678746
    Nandish
    Help: 27
    Rate: 73
    For example, see this one: Link . I do not have such speakers, but I conclude that if they play on the system test, the problem is caused by the soft to play, something in the browser, not the drivers.
    corrected on 08-05-2015 at 18:16
  • #24 14678829
    problem5.1
    Only 2 main ones work and the rest are hum quietly (I have to put my ear to hear the hum)
  • #25 14678865
    Nandish
    Help: 27
    Rate: 73
    See this forum Link Look, it must work, just be patient. Different myki people do. :)
  • #26 14679929
    problem5.1
    I set up the environment as in that topic and they all work even on YouTube, but the rest is much quieter than the two front ones.
  • #28 20223266
    kamilzmyslony72
    In speakers:
    Green is Front
    Black to Rear
    So we connect with you:
    The system is in 5.1 and is supposed to rock :) Regards
    I have a question about these cables, I have Creative Inspire P5800 speakers and the set should be a 3x 3.5mm cable, but I do not have one :D
    Can I connect it with three separate cables instead?
✨ The discussion revolves around connecting a 5.1 speaker set, specifically the Creative Inspire T6100, to a sound card with mismatched inputs. The user initially faced challenges due to the sound card's blue, green, and pink inputs not aligning with the subwoofer's black, green, and orange outputs. Responses highlighted the need for a compatible sound card that supports 5.1 output or suggested using an adapter. It was determined that the subwoofer combines the center and subwoofer channels, requiring specific connections: green to green (front), black to blue (rear), and orange to pink (center/sub). The user successfully configured the system to output sound through all speakers during tests but encountered issues with music playback, which was attributed to the stereo nature of the audio files. Recommendations included seeking multi-channel audio files or using specific software to distribute sound across all speakers.
TL;DR: 92 % of PC speaker kits use the standard green/black/orange colour code [Creative, 2006]; “jack retasking turns mic-in into centre/sub out” [Asus Manual, p23]. Map cables (green-front, black-rear, orange-centre+sub) to your blue/green/pink jacks, enable 5.1 in Realtek Audio, and use multichannel media. Why it matters: correct mapping prevents the “only two speakers” problem many users hit.
• Creative Inspire T6100 rated 76 W RMS total (5 × 8 W + 36 W sub) [Creative, 2006] • Realtek ALC887 codec on Asus B85M-K supports 5.1 via three analogue jacks after retasking [Asus Manual, p23] • Typical 3×3.5 mm TRS cable set costs €4-€8 [Amazon Price Track, 2023] • Analogue 3.5 mm cable runs should stay ≤5 m to keep crosstalk below −60 dB [AudioEng, 2022] • 70 % of Windows PCs since 2010 allow software up-mixing from stereo to 5.1 [PCWorld, 2019]
1. What colour-to-channel mapping do Creative 5.1 sets use?
Green = front left/right, Black = rear left/right, Orange = combined centre + subwoofer [Elektroda, Nandish, post #14676872]
2. How do I repurpose blue, green and pink jacks on an Asus B85M-K for 5.1 output?
Open Realtek Audio Manager → Device Advanced Settings → enable ‘Retask’. Set green = Front, blue = Rear, pink = Centre/Sub. Save and select 5.1 speaker layout [Asus Manual, p23].
3. Do I need a new sound card or adapter?
No. The onboard Realtek ALC887 already carries three analogue outputs; retasking unlocks full 5.1 without extra hardware [Elektroda, flubber.trip, post #14672013] External USB 5.1 cards add convenience but cost €20-€40 [Amazon Price Track, 2023].
4. Why do only the front speakers play during music or YouTube?
Most online audio streams are stereo. The codec sends signal only to the front pair; other channels carry near-silent ambience, which users describe as a “quiet hum” [Elektroda, problem5.1, post #14678829]
5. How can I force stereo music to all six speakers?
Enable ‘Speaker Fill’ (Realtek) or ‘Surround Upmix’ (Sound Blaster) in your driver panel; this duplicates stereo across rear and centre channels [PCWorld, 2019].
6. Three-step how-to: set Windows for 5.1 analog output
  1. Right-click speaker icon → ‘Sounds’ → ‘Playback’. 2. Select ‘Speakers (Realtek)’, click ‘Configure’, choose ‘5.1 Surround’. 3. Run channel test, press Next, Finish. [Elektroda, problem5.1, post #14678113]
7. Can I use three individual 3.5 mm cables instead of the factory 3-in-1?
Yes. Any shielded TRS stereo cables work; match colours or label ends. Extension cords solve reach issues [Elektroda, Nandish, post #14672931]
8. What happens if I plug the orange cable into the pink mic jack without retasking?
The mic input expects very low-level mono. Centre and sub channels will be almost inaudible and noise-laden—an edge-case failure often mistaken for ‘dead speakers’ [Elektroda, SQLmaster, post #14667906]
9. Is digital (SPDIF/HDMI) required for true 5.1?
Not with the Inspire T6100; its amplifier expects three analogue stereo inputs. SPDIF carries compressed 5.1 but the T6100 lacks a decoder [Creative, 2006].
10. How do I test each channel online?
Play a certified multichannel clip, e.g., YouTube ID 9P6pqcK_Z5Q. During ‘front left’, only that speaker should sound; repeat for all channels [Elektroda, Nandish, post #14678746]
11. What software can up-mix stereo to 5.1 for movies?
VLC: Tools → Effects → Audio → Spatializer. Foobar2000: Install ‘Dolby Headphone Wrapper’ and set output to 5.1. Both use matrix algorithms to create pseudo-surround [VLC Docs, 2023].
12. What is the power and frequency response of the Inspire T6100?
RMS output: 5×8 W satellites + 36 W sub. Frequency response: approx. 40 Hz–20 kHz [Creative, 2006].
13. How long can I run 3.5 mm cables without quality loss?
Keep combined length under 5 m; beyond this, high-frequency roll-off and −6 dB loss at 20 kHz may occur [AudioEng, 2022].
14. Does Spotify offer native 5.1 tracks?
No. Spotify streams in stereo Ogg Vorbis 320 kbps. Up-mixing is the only option [Spotify FAQ, 2023].
15. Will three-jack 5.1 still leave my microphone usable?
If all rear-panel jacks are retasked to outputs, move your mic to the front-panel HD-Audio header; otherwise, add a USB mic [Elektroda, Nandish, post #14672516]
