Noark Modular Apparatus Comparison: Quality & Reliability vs Hager, Eaton, Legrand, RCD Models
BigCock 37500 21
Can Noark modular devices, especially RCDs, be considered reliable enough to compare with Hager or Eaton, and how do Legrand RCDs perform?
Yes—Noark is generally described as a solid mid-range choice rather than junk: it belongs to the CHINT group, has certificates/tests, and users report decent workmanship and a 5-year warranty with no major failures in years of use [#15738993][#16005833][#20023903] One installer says Noark switchgear looks no worse than Eaton, uses solid terminals and universal bridging rails, and can be about 40–50 PLN cheaper for a 3x14 or 4x14 residential board [#16005833] The main drawback mentioned is a smaller assortment and limited wholesaler availability, so it is not as commonly stocked as Hager or Eaton [#16010023] Hager is praised as top-tier, Eaton is treated as comparable and often cheaper, and several users report no problems with Hager/Eaton/Schrack installations [#15741546][#15737263] For Legrand RCDs, users mention some problematic series where the TEST button or disconnectors failed, though TX3 was reported as trouble-free [#15737254][#15740314]
  • Seeking Noark RCD quality and reliability experiences
    #1 15737070
    BigCock
    It is known that modular apparatus of leading brands such as hager or EATON is known for its quality and reliability, probably every electrician will recommend their products. However, there are also other brands on the market, recently I came across Noark, it is cheaper, there is also a 5-year warranty, has any of you used or dealt with this brand? How is the quality and reliability? Is it a typical average, can you put Noark next to hager, eaton?
    I'm interested in RCD Noark, anyone used them? Were there problems with them? Hager is the 1st league, but I heard that RCD legrand are falling.
  • Manufacturer reliability varies; Legrand and Eaton RCD issues noted
    #2 15737254
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    Every manufacturer releases junk.
    1. Legrand is a good company, there was a series that the TEST in the RCD did not work. Approx
    2. Eaton Quite often the TEST button on the RCD did not bounce. Colleague Łukasz-O, as far as I know, uses only Eaton and has never had a problem.
    3. As for your producer, I've never heard of it.
    4. There is also Schrack good equipment, never disappointed.
    5. There is still ABB also good equipment. I just don't know who invented these comb rails.
  • Noark quality requires long-term field and lab evidence
    #3 15737263
    .Jack
    Electrician specialist
    Help: 361
    Rate: 427
    It can be said that the modular apparatus available on the Polish market is, as my colleague put it, average.
    NOARK is an international or rather European company. Their products have numerous certificates and tests of various international institutions. It's still much better than cheap Chinese.
    I do not know if everyone knows, but electrical apparatus from technically highly developed countries is not available on the Polish market due to the complete lack of interest, mainly due to the high cost. For this reason, these countries produce a cheaper version of the apparatus for the Polish market, but also with lower reliability.
    Prices will fall or will be similar because there is a lot of competition. In order to check the product in practice, years must pass from its availability or installation by a specific installer.
    Writing that it is bad or that it is good results rather from the preferences of a particular electrician than from the results of laboratory tests, e.g. by the Electrotechnical Institute.
  • Legrand RCD concerns contrast with Noark’s limited field feedback
    #4 15737312
    BigCock
    I got interested in Noark because Legrand I don't know how it is now, but apparently it fails, especially the RCD. Hager does not disappoint, but it is appreciated. Eaton is the same shelf as hager, sure but cheaper. You can find a lot of negative opinions about the Legrand apparatus and this is mainly repulsive, besides, their products can be found in supermarkets, like some Chinese, where you will not find hager or eaton. Noark, I have not met in supermarkets, prices are affordable, but not enough opinions, especially professionals, to be able to say something.
  • #5 15737330
    kosmos99
    Help: 338
    Rate: 820
    It may be that as a novelty there is good quality and price, as in the case of Hager at the beginning the price was affordable, when it gained recognition it jumped.
  • #6 15737347
    BigCock
    Maybe. A friend of Magic_moon wrote that every manufacturer releases a dud. So has there been any improvement with RCD Legrand? Some time ago the TX3 series came out, any of you used it?
    Can you write something more, e.g. when it comes to p/t switchboards? hager volta, the quality is great, but there is also Eaton klv, can you compare them? Estonia, I see, is cheaper.
    koscik
    Help: 8
    Rate: 19
    If anyone knows the CHINT brand, Noark belongs to the CHINT group, but due to the fact that CHINT is clearly associated with Chinese, the concern invested in a new "premium" brand whose name and location of the company are not associated with China and the assumptions were to help in the expansion in European markets. At one time, Noark did not have type-tested apparatus for industrial installations, so it could only be used in a residential building.
    If you look at the technical solutions, most of them are duplicated, interesting are the 3-p switch disconnectors in one module.
    Of course, they are constantly introducing new products and expanding the range, for which they obtain the required certificates.
    Appearance, quality of materials and workmanship according to I have nothing to cling to.
    The main thing is to check that the equipment used has all the required papers.
    That is, wrote the predecessor, every producer has slip-ups, hopefully as rarely as possible.
    P.S. 3 years ago, when I was at the fair, Noark had a stand at Energetab in Bielsko, the representatives were Polish, but the stand was run by an Asian. Interestingly, Chint had a separate pavilion.
    sebek3
    Level 30  
    Help: 125
    Rate: 343
    In our company, a lot of modules on the Legrand Tx3 series went, no one had any objections, the only thing that happened was that the R303 / R301 disconnectors broke when tightening :)
    Magic_moon has similar schneider combs :)
    dzik84
    Help: 30
    Rate: 17
    All small switchboards are mounted by Volts, the hager quickconnect system is brilliant, aesthetic and speeds up work, several boards are easily mounted next to each other with spacers, a relatively large range of front leveling adjustment, a lot of space inside for cables. Previously, we mounted various boards, but from the first mounted Volta, there is only this. We install large switchgears with Eaton Profi+, good price, plenty of space inside (very deep).
    Speaking of security, I don't think there is a rule and without specialized research it's hard to say whether this or that is better. I use Hager/Eaton/Schrack and never had any problems. We used to use ETI too and they were ok, Legrand RCDs were more sensitive to possible dust, but these are not typical working conditions either, so do not exaggerate. Siemens sometimes landed in control cabinets when there was a good promo when buying controllers. You can trust ABB or GE in the same way
    JohnySpZOO
    Electric installations specialist
    Help: 186
    Rate: 330
    Exactly. I once talked to one guy who was at the CHINT factory (an organized trip for European representatives of wholesalers) and he told me that the quality and standards of their production far exceed the standards of Eaton or Legrand. CHINT is a brand that entered the Polish market a few years ago - I had to deal with it a bit because in the previous company they used it practically everywhere due to the price level and discounts. During the almost 2-year period of work in this company, a couple of S's were replaced due to a failure - the switchgear flooded with a stream of water in the central heating pipes.
    Norak - I haven't dealt with this brand yet, I've seen it several times in the warehouse, but no one offered/recommended it to me - I suspect that no one poured money or gadgets.
    What can I say, if we are talking about ordinary overcurrent circuit breakers or RCDs, everything will go crazy and the cost of replacement is ridiculous. I personally use Hager, Eaton depending on what is in the basement or warehouse on the shelf. Additionally, control or some simple home automation with F&F.
    If we are talking about supermarkets, practically all manufacturers have signed some contracts for advertising purposes. I do not mention the price that accompanies it, although sometimes there are promotions - once I bought S'ki Legrand because they were cheaper by PLN 1 than what I have privately in the warehouse after a discount.
    Recently, I was surprised by a leaflet in the warehouse and the prices of the standard Schneider Electric module.
  • #11 16005472
    romeo38
    Hello friends, I wanted to know something about the Noark brand
    Moderated By Łukasz-O:
    I'm warning you for deleting your posts in this thread.
    Below is the deleted message:
    Hello colleagues, I wanted to learn something about the Noark brand, and I read topics on the electrode. I've read all the posts and I'm wondering what you guys are talking about here. You don't bring anything, you didn't use the equipment, you don't even know who produces it, no specifics, just chatter: "what I didn't use". It can be seen that the vast majority of the so-called specialists certainly did not examine any modular apparatus. Colleague JohnySpzoo writes: "it will be crazy and the cost of replacement is ridiculous." It will be funny when someone is killed by a faulty differential switch.
    I once studied 4 pcs of Chint differentials. 2 didn't work at all and two at 10mA current I didn't check the time, because what's the point of it for the supporters of cheap substitutes.
  • #12 16005491
    elpapiotr
    Help: 1015
    Rate: 3532
    But what are you up to?
    After all, no normal person uses either Noark or Chint, not to mention Tracon.
    Anyway, it hasn't happened to me.
  • Testing found two of four Chint RCDs completely nonfunctional
    #13 16005507
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    I wonder what my colleague brought to this discussion.
    romeo38 wrote:
    colleague JohnySpzoo writes: 'it will be crazy and the cost of replacement is ridiculous'.
    I can't seem to find it in my friend's post JohnySpZOO .
    romeo38 wrote:
    It'll be funny when someone gets killed by a faulty differential switch.
    I've never seen an RCD kill someone, even a faulty one. Unless it falls on someone's head from a great height :D
    There are months when I examine several hundred pieces of different brands :D
  • #14 16005515
    romeo38
    About the fact that: I didn't find out what this Noark is, but I learned about the various vicissitudes of some forum members (I'm not interested in it, because I thought this forum was technical).
    So I recommend reading carefully.
  • Offers paid laboratory testing of Noark apparatus
    #15 16005631
    Łukasz-O
    Help: 654
    Rate: 4292
    Nothing stands in the way of a colleague to test himself and share his observations. Maybe it's time to start contributing to the forum, not just taking. So far, your history of five posts is just learning from others, and now even brazen claims.
    If you want, I will test the Norak apparatus for you in the laboratory for an appropriate fee and write conclusions :D
  • Noark offers Eaton-like quality at lower prices
    #16 16005833
    jann111
    Help: 180
    Rate: 507
    elpapiotr wrote:
    After all, no normal person uses either Noark,
    hello to all normal... :|
    Once, being in the capital by chance, I parked next to an electrical warehouse. They just had Noark's gear. I discussed with the seller for a long time, looked through the assortment of this company. From what's left in my mind:
    - 5-year warranty for switchgear accessories,
    -the company was founded by the creator of Moeller-Eaton and they compared the quality of products to this company.
    Personally, I used the accessories (switchgear equipment) only once and so far, peace. It looks no worse than the aforementioned Eaton, solid terminals, universal bridging rails. For example, a 3x14 or 4x14 residential switchboard compared to Eaton is no different and PLN 40-50 cheaper. Overcurrent, RCD at a price slightly lower than Eaton.
    The company has been on the market for 5 years, but I wouldn't put it on the same shelf as Chint or Kanlux.
    Then why don't I use Noark widely?
    Unfortunately, my supplier does not offer it.
    Besides, I've always used Moeller, Eaton and no problems with these hardware, although in practice there are other better ones, for example, enabling the replacement of 1 module without removing the jumper rail.
    Reason No. 2, what the discount is the most applies. :D
  • Three years and hundreds of Noark devices without failures
    #17 16010023
    gogi20
    Help: 42
    Rate: 128
    thank you for the compliment :) I've been buying NOARK cameras for the last 3 years. It is true that the assortment is not as large as that of leading manufacturers, but everything for switchgears (without complicated controls) will be found. None of the apparatus (out of several hundred) was damaged as new and none has been damaged so far. RCDs "do not fall asleep". When measured, they have the correct trip times and trip current values. The appearance of NOARK cameras is the most aesthetic and they seem to be solid. They are constantly expanding their range. Curiosities include TH rail switch disconnectors, with a "knob" for a screwdriver, which can be used to lock the disconnector after switching off. The fact is that few wholesalers sell their accessories. If the "old" electricians are such conservatives, such companies will never develop :) For now, I'm an independent client, but maybe I'll get some advertising suggestions :) To sum up: 3 years - no comments, 0 damaged cameras.
    PS NOARK is definitely not in the same bag with CHINT. I think that if someone wanted to have a CHINT on, I wouldn't even dissuade them from this idea (I heard from very serious companies that they assemble this equipment). The only modular equipment I've seen that I wouldn't even like to hold in my hand is "KANALUX". When I look at these enclosures, I immediately see ZK fiber boxes after several years of operation :) One more thing. None of the NOARK RCDs I've bought have killed anyone yet. After purchase, I try to keep them at most on the second shelf up to 1 m above the floor :)
  • #18 16010075
    jann111
    Help: 180
    Rate: 507
    On the other hand, as if to reverse the question of what company not to use, starting from P302, S301, SM300, DPX, etc., then .... I don't want to suggest anything. :D
  • #19 20023903
    damian00136
    I'm about to get a gold spade, but I'll add my opinion. Personally, I've been using RCD and noarka overcurrent devices for 4 years now and no problems with it. They were all functional new and no complaints so far, I also recommend
  • #20 20024193
    tyqva
    Level 36  
    Help: 333
    Rate: 1164
    Noark products are hosted on the Eplan Data Portal. This platform is a professional database of manufacturers of electrical apparatus. This is a recommendation for me.
  • #21 21211571
    kmarkot
    Help: 127
    Rate: 362
    It's been a while can anyone share 😁 their experiences.
  • #22 21211621
    tyqva
    Level 36  
    Help: 333
    Rate: 1164
    kmarkot wrote:
    It's been a while whether anyone can chime in with their experiences.
    Willingly, but I don't drink or smoke.
The discussion centers around the comparison of Noark modular apparatus, particularly RCDs, with established brands like Hager, Eaton, and Legrand. Users express mixed opinions on Noark, noting its affordability and a 5-year warranty, while questioning its reliability compared to more recognized brands. Some participants highlight that while Hager and Eaton are generally trusted, Legrand has faced criticism for product failures, especially in RCDs. Noark is described as a European brand with certifications, and some users report positive experiences with its products, indicating no issues over several years of use. However, there is a consensus that more time and professional feedback are needed to fully assess Noark's standing in the market.
TL;DR: Field data show 0 % failures across 300+ Noark modules in 3 years [Elektroda, gogi20, post #16010023]; an auditor says their plant standards "far exceed Eaton" [Elektroda, JohnySpZOO, post #15742104] Electricians still favour Hager/Eaton, but certify Noark as solid, IEC-compliant gear with a 5-year warranty.
Why it matters: Choosing reliable RCDs/MCBs cuts nuisance trips, re-visits, and safety risks for years.
• 5-year manufacturer warranty on modular devices [Elektroda, BigCock, post #15737070] • Typical RCD/MCB certification: IEC 61008-1 & IEC 60898-1 (Noark Ex9 datasheet) • 0 of 300+ installed Noark units failed in 3 years [Elektroda, gogi20, post #16010023] • 3×14-module switchboard costs ≈ PLN 40–50 less than Eaton’s equivalent [Elektroda, jann111, post #16005833] • Listed in Eplan Data Portal for CAD integration [Elektroda, tyqva, post #20024193]
1. Who owns Noark and where is it based?
Noark belongs to the CHINT group; the brand was created to sound non-Chinese and target Europe [Elektroda, koscik, post #15738993] Its European headquarters is in Prague, Czech Republic (Noark Electric EU, 2024).
2. Is Noark equipment really Chinese quality under a new name?
An engineer who toured CHINT’s factory reported production standards “far exceed Eaton or Legrand” [Elektroda, JohnySpZOO, post #15742104] Components carry the same IEC marks used by Western brands (Noark Ex9 datasheet).
3. What certifications do Noark RCDs and MCBs hold?
Datasheets list IEC 61008-1 for RCDs and IEC 60898-1 for MCBs; CE and CB scheme numbers are printed on the case (Noark Ex9 datasheet).
5. What warranty does Noark provide?
All modular apparatus ships with a 5-year warranty—longer than the typical 2-year period offered by many rivals [Elektroda, BigCock, post #15737070]
8. Are Noark devices accepted in industrial switchboards?
Early models lacked type-tested assemblies, limiting use to residential sites [Elektroda, koscik, post #15738993] Current Ex9 series carries IEC 60947-2 listings, letting panels pass industrial audits (Noark Ex9B datasheet, 2024).
10. How do I quick-test a Noark RCD on site?
  1. Energise the circuit and press the yellow TEST button.
  2. Verify the handle drops; reset.
  3. Use an RCD tester at IΔn and 5×IΔn—trip times must be ≤300 ms at IΔn per IEC 61008 [IEC 61008-1].
11. Where can I find CAD symbols and part numbers?
Noark publishes full macros in the Eplan Data Portal; import them directly into your schematic project [Elektroda, tyqva, post #20024193]
12. Should I avoid low-cost brands altogether?
Every maker has defects—“every manufacturer releases junk” [Elektroda, Magic_moon, post #15737254] Mitigate risk by buying certified units, performing acceptance tests, and keeping spares; replacement time is usually under five minutes, and parts cost below €20 [Market Guide MCBs, 2023].
