1.6 HDI Engine (9HR): No Start, No Oil Draw from Rail - Could It Be The High Pressure Pump?
siwy24 92865 24
Why does a 1.6 HDi 9HR crank but not start, with only about 1 bar rail pressure instead of the 250–290 bar needed for starting?
It is not safe to blame the high-pressure pump immediately; the thread says to first check the low-pressure supply, the pressure regulators/valves, and the wiring/sensor circuit, because 1 bar during cranking is far too low to start the engine [#15782474][#15783002][#15783513] The expected starting pressure is around 250 bar (roughly 150–200 bar minimum), so the ECU will refuse injection when it only sees about 1 bar [#15782474][#15783002][#15784704] For a Continental/Siemens system, there is no electric in-tank feed pump in this case; the HP pump sucks fuel through the filter, so you should verify the suction side is tight and unobstructed before removing the timing cover [#15783513][#15785194] If the low-pressure side is OK and the flow/pressure regulator is powered and working, then a mechanically damaged HP pump or a slipping drive/cone becomes the likely suspect [#15784704] Also check the fuel-pressure sensor plug and contacts, because these engines are known for wiring/connector faults that can make the sensor reading jump or go to zero [#17824799]
  • #1 15782458
    siwy24
    Rate: 56
    Dear Ladies and Gentlemen :)
    I have a problem with the car. 1.6 hdi (9HR) engine refused to obey.
    The engine spins, however, does not start. It fires on the cake, but does not draw oil from the rail, as it is returned to the drain at some point.
    At the beginning, I changed the fuel filter to a new original one, I checked the hoses that are tight. The feeder in the tank is checked and also approx.
    Another idea was the sensor on the strip, but after the exchange (difficult access) Nothing has changed.
    I unscrewed the injection supply from the rail and it turns out that the pump does not supply oil to the common rail.
    Proven pressure regulator. Kitten bundles and electricity approx.
    The only thing that comes to my mind now is the high pressure pump ...
    Can someone confirm or to some extent resolve my doubts?
    I ordered Pompey, but if the fault may be something else, I prefer not to disassemble the timing gear.
    I will add that the continental pump number PSA 9672605380
    I would like to thank each individual for help / advice
  • #2 15782463
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4187
    And what pressure does the engine controller see? Errors? Parameters? (synchro, immo status ....) The repair is going in the wrong direction for now - hit or miss.
  • #3 15782474
    siwy24
    Rate: 56
    I'm abroad,
    AUto sciagnete by mechanics,
    They ordered a sensor from the rail, but it did not suit me that nothing was spilled ...
    France and the citroen specialists.
    -Sensors are synchronized,
    - permission to start approx.
    -Pressure 1 bar
    - the engine controller requires 290 bar.
    I will add that after sciagneicu the regulator when turning, pus is pouring from the hole for the regulator.
  • #4 15783002
    marek1977
    Help: 204
    Rate: 710
    If you have 1 bar of pressure during start-up, something is wrong. Must be 250 (+/- 50)
  • #5 15783027
    darfur5
    Help: 267
    Rate: 1716
    This means you have no pressure on the bar!
  • #6 15783041
    marek1977
    Help: 204
    Rate: 710
    Well, the only question is whether the pump, the regulator on the pump that was able to fall out, or the sensor on the strip, which is said to be replaced. As for the pump, I would put the regulator on the pump at the end and at the beginning.
  • #7 15783048
    darfur5
    Help: 267
    Rate: 1716
    Or the pressure valve on the CR rail. Although I found that the pressure sensor and valve were two in one.
  • #8 15783155
    siwy24
    Rate: 56
    A brand new pressure sensor from Citroen,
    The pump gives nothing and nothing to the rail,
    The regulator was replaced from another car.
    As for the ego valve on the rail ... if it would certainly be on it, and if so, in which place. However, I doubt it would be there.
  • #9 15783278
    szymon198312
    Level 30  
    Help: 126
    Rate: 890
    The sensor is screwed into the strip. I do not know whether it is from the bottom or from the top, if I associate the engine correctly, you have a rail under the manifold and a sensor at the bottom of the rail behind the oil filter, but I could have mistaken it with the 2.0. If the sensor is damaged, the controller should allow the start anyway. If you don't have fuel at the pump exit, why keep rummaging around. Focus on it. The valve on the pump, if it was replaced and to no avail, look in the wiring or in the pump itself. Do you have an extra pump in the tank? Because if you have a set pressure of 290 on the parameters, it means that the controller wants to start the piss, but the valve gets too little pressure to go to the rail or the valve has no power.
  • #10 15783513
  • #11 15784553
    siwy24
    Rate: 56
    Thanks to Kotbury2 for the development of the topic.
    So I don't have an electric pvc feeder in the tank. The pump itself sucks the fuel through the filter. So we exclude the failure of the pump in the tank.
    Secondly, all the currents were measured (unfortunately I did not measure what it looked like during the start-up. 5v goes to the sensor of the rail. All contacts are checked and go to the engine's computer.
    After turning the ignition, the Pressure regulator gets 7v (it should be lower) but this is due to the low pressure on the rail)
    Unscrewed rail-injection did not feed any fuel. The pressure was checked and it does not rise during start-up.
    I regret that I did not look at it when replacing the filter, but the mechanics threw it straight into the trash.
    The pump looks like this
    http://www.ebay.fr/itm/Hochdruckpumpe-Citroen...200506?hash=item4afaacad7a:g:dcMAAOSwoudW301u
    And it has only one electric connection (3 mark in the diagram)
    Unscrewing number 3 (the regulator of the oil flow slowly sucks, so I suspect this is correct
    number 4 in the schematic if any. It is without ankle.
    The car was going smart until the ignition was turned off, so it cannot be inferred from my point of view from the car's behavior.
    I am still wondering about the multi-wedge near the sprocket, maybe I know that there is a cone.
    It's hard to check anything with the mechanics, but I fight as much as I can.
    Pump from Pl bedize sent only tomorrow, so a few more days to get married.
    If someone has tried the pump from the link
    Or look at this ...
    http://www.ebay.fr/itm/2011-CITROEN-DS3-1-6-L...543233?hash=item5b1fae5741:g:YXsAAOSwGotWqOZh
    Is it possible to jump out of the ball? theoretically.
    I don't know if there was anything to be desired at the timing, but everything was possible.
    Tomorrow I will remove the timing cover and maybe it will suggest something.
    I also understand that this "black cap is this valve"?
    Now I have to fly, but it gives me a dream so I can come up with something together.
    Regards!
  • #12 15784704
  • #13 15785169
    siwy24
    Rate: 56
    Yes, the wire between the injector and the PWC has been unscrewed.
    When I checked earlier, for example, the pressure regulator, or the sensor on the rail when the car did not fire. excess fuel leaked and the engine fired.
    As for the leak on the low pressure side. THIS I put a transparent tube on the inlet to the filter and after sucking the fuel into the tube, it did not air up, suggesting that the filter supply system is tight. When I was suggesting that the fuel pump (combined with the filter) might be non-audible. I was laughed at :)
    The pump (at least in the old 1.6 hd can be installed by eye and you do not need to set it in accordance with the timing to pump fuel. The condition is to set the rollers to synchronize the firing).
    With indifferent hand, tomorrow I will pull off the timing housing and see if everything is in order with the pump. The timing is certainly ok.
    Just like I eliminated the injection fault.
    Tomorrow I'll do an update in the evening after the fight with the car.
    PS I will add that it could go to a much worse place :)
    Greetings
  • #14 15785194
    hessel.
    Help: 6
    Rate: 15
    This pump can be ventilated, but there is no one to do it for you.
    The low pressure pump itself sucks the fuel (as already) and it is not known what happens with this fuel.
    What was the point of burrowing in a high pressure system when it is not known if she has fuel in her.
    (expense valve and that stuff)
    It looks as if elementary hydraulics were something like a UFO for someone.
    ps.
    It can happen when the low pump does not give, i.e. a leaky restrictor does not offer any resistance, sawdust possible.
    There are two ways to check this.
  • #15 15792152
    siwy24
    Rate: 56
    The car went to PL on a tow truck, Too high costs in France. And you can say that I got the opportunity.
    I will continue the topic when my car comes home. So I'm not closing it.
    For now, thank you for all your help. I hope you will follow the topic.
    Regards
  • #16 17824706
    orzech_swin
    Rate: 9
    Dig out the cutlet, how did the fight end?
  • #17 17824799
    bobytempelton
    Help: 15
    Rate: 150
    These engines have a defect in the electrical installation, so the plug on the fuel pressure sensor does not connect, you can see it after removing the plug that there are traces of connectors on the sensor pins, wash, blow, bend and even replace the plug because it is even new, it goes quickly to diagnose the inputs the pressure of the fuel sensor that he sees and jumps goes crazy or 0 and suddenly 300 or jumps ... I see a bottle
  • #18 18266290
    trrol
    Rate: 102
    Friend, what was that you did not have fuel on the rail because I have the same problem
  • #19 18316079
    piopaw79
    Rate: 56
    Colleague Siwy24 will cope with the problem?
  • #20 20815096
    wojjtekk
    Rate: 44
    Did the author of the topic solve the problem?
  • #21 21616313
    barney79
    Rate: 8
    How did it get resolved because I have the same thing now
  • #22 21723376
    moro871
    Hi all, have any of you dealt with the problem of no fuel at the injectors? I also have this problem: it's spinning, I've replaced the sensor on the injector rail and pump and no pressure on the injector rail. Anyone have any help?
  • #23 21723704
    decybel91
    Help: 1024
    Rate: 4237
    Car, year, engine code
  • #24 21723707
    moro871
    Peugeot 207 1.6 HDi, 2007. No fuel at the outlet from the pump to the injection rail. It shows 7 bar on the rail. Buzzing of the valve on the pump.
  • #25 21723845
    decybel91
    Help: 1024
    Rate: 4237
    7 bar when spinning? If Bosch then pump to be replaced/
Discussion about a Peugeot/Citroën 1.6 HDi (9HR/DV6C) common-rail diesel that cranks but will not start because rail pressure stays extremely low during cranking. The fuel filter, tank supply, rail pressure sensor, and pressure regulator were checked or replaced, but the engine ECU still requests about 290 bar while only about 1 bar is seen. Participants debate whether the fault is the high-pressure pump, the pump regulator, rail valve/sensor wiring, or low-pressure supply, and note that the pump outlet should produce fuel if the timing drive is intact. Later comments mention a possible known wiring/connector defect at the fuel pressure sensor and, for a similar Peugeot 207 1.6 HDi case, no fuel at the rail outlet with only 7 bar indicated and a buzzing pump valve, suggesting pump replacement on Bosch systems.
