Peugeot 307 1.6 hdi no power - Rotations up to 3 thousand and no power
kisia0809 61320 14
Why does my 2004 Peugeot 307 1.6 HDi lose power and refuse to rev past about 3000 rpm?
The car is most likely in limp/emergency mode, so the first step is to read the fault codes on a computer and check live parameters before replacing parts [#17135036] [#17136356] The most suspected cause in this thread is a dirty or stuck EGR valve, especially with 216,000 km, and cleaning it may be enough in some cases [#17135069] Another likely cause is a loss of vacuum/boost control, so check the turbo hoses and vacuum lines for hardening or leaks [#17135054] [#17135533] It was also suggested to inspect the turbine itself and the exhaust-gas path/hot side for blockage or sticking [#17136356] Even without a warning lamp, the ECU can still trigger emergency mode, so diagnosis by codes is the key next step [#17135036] [#17135052]
  • #1 17134989
    kisia0809
    Rate: 14
    Hello! I have a Peugeot 307 1.6 hdi from 2004. The car does not have the strength to accelerate, the revolutions rise to less than three thousand and something like it brakes, go up and feel that there is no more power. What could have happened?
    Moderated By CameR:
    Reg. 3.1.15. Do not ask at once on the forum, if you have not checked anything before or did not attempt to diagnose yourself. Remember that advice is provided remotely in the absence of physical access to the device, the problem must be very well described and understood by users, and the title should contain the brand, model and brief description of the fault.
  • #2 17135036
    servgsm
    Help: 17
    Rate: 73
    You have an emergency mode enabled. There may be many reasons.
    Clogged DPF, too many failed DPF blows, dirty EGR, bad glow plugs, bad extinguishing flap .... Can be changed endlessly.
    The yellow engine light is on? Attach the car to the computer, check the errors and paste them here, then we will know something more.
  • #3 17135052
    kisia0809
    Rate: 14
    I'm just a woman, I do not know everything :)
    The indicator lamp does not burn, once it was CHECK during the holiday once, but it went out after a few days and it's okay.
    And now, on Monday, I was in quite a big traffic jam, and after this move, braking happened.
  • #4 17135054
    kuba20111
    Help: 5
    Rate: 25
    You can do nothing without a computer. Only check if the turbine hoses harden after gasification.
  • #5 17135055
    servgsm
    Help: 17
    Rate: 73
    Car's mileage?
    The turbine hoses may not harden. I do not know how it is in 1.6 HDI, but my 2.2 HDI biturbo looks as if the turbine flaps were closed.
    In my case, the fault is EGR or used candles (they are blown).
  • #6 17135058
    kisia0809
    Rate: 14
    servgsm wrote:
    Car's mileage?
    216tys
  • EGR soot buildup likely causing power loss
    #7 17135069
    servgsm
    Help: 17
    Rate: 73
    kisia0809 wrote:
    servgsm wrote:
    Car's mileage?
    216tys
    It is after the description of the case, when it occurred, that I would be 70% sure about the incorrect operation of EGR due to excessive soiling.
    But just like a colleague wrote earlier, you need to connect your car to the computer to look further. Look for a good mechanic who knows French, because "Mr. Wiesio" can not do it. The units are too complicated.
    If I'm right, with this EGR, it might be enough to clean it, in some cases it will pass the exam.
  • Excessive EGR soot likely causing power loss
    #8 17135078
    kisia0809
    Rate: 14
    servgsm wrote:
    kisia0809 wrote:
    servgsm wrote:
    Car's mileage?
    216tys
    Thank you so much for the hint. I hope I can find someone good :)
  • #9 17135082
    kuba20111
    Help: 5
    Rate: 25
    candles do not have anything to do with it ...
  • Glow plugs not related to limp mode diagnosis
    #10 17135123
    servgsm
    Help: 17
    Rate: 73
    Let a colleague read about the adventures with the French. Sometimes, even a sudden change in temperature (leaving the garage) can do chaffing in electronics, triggering the emergency mode.
    And the most candles, the system determines that they are worn and will force the user to the site. And rightly so. Candlelight ceramics are able to crumble while making the fall of the Middle Ages in a cylinder, and candles wear not only when firing a car in winter, but during the entire operation. Pressure changes and processes in the cylinder do their job.
  • EGR or vacuum loss likely causing limp mode
    #11 17135533
    sly_1978
    Help: 34
    Rate: 284
    Candles do not cause an emergency mode in HDi. Egr is the suspect here as much as possible, or the negative pressure is lost. In addition, I do not quite understand the allusion to the "francs", the motorization is currently at an equally low level, which in the case of once-reliable German brands hurts the most.
  • #12 17136028
    servgsm
    Help: 17
    Rate: 73
    "Ecology" ladies ... "Ecology." :cry:
  • #13 17136356
    jurekk55
    Level 36  
    Help: 182
    Rate: 1580
    We do not write heresy, sometimes it is better to read before the statement ...
    sly_1978 wrote:
    Egr is the suspect here the most,
    More specifically, EGR and flue gas exhaust, I would check the turbidity and the hot side of the turbine.
    Everything, of course, after checking the errors and live parameters.
  • New fuel pressure and turbo sensors fitted
    #14 21485987
    uzn190391
    Hello, I have the same problem that it is in emergency mode and I don't know anymore what to do next, and among other things I have replaced the EGR valve with a new one, air flow meter new, turbo after regeneration, cleaned the intercooler, the air purge also, injectors checked are 100% good, injection cubes new, and the car continues with no power and in emergency mode up to 3 thousand revs and no more.
    Added after 2 [minutes]: .
    And still a fuel pressure sensor strip new and a turbo pressure sensor.
  • #15 21552258
    darekk310
    Older 1.6 HDIs had the problem that if the 1st gear of the radiator fan wasn't working, the engine would go into emergency mode, no power and cranking up to 3k.
    Older 1.6 HDI's had the problem that if the 1st gear of the radiator fan wasn't working, the engine would go into emergency mode, no power and would crank up to 3k.
A Peugeot 307 1.6 HDi (2004) exhibits lack of power with engine revolutions limited to about 3000 rpm, indicating emergency mode activation. Common causes discussed include clogged Diesel Particulate Filter (DPF), excessive DPF regeneration attempts, dirty Exhaust Gas Recirculation (EGR) valve, faulty glow plugs, malfunctioning extinguishing flap, or loss of negative pressure. The engine warning light is not consistently on, complicating diagnosis. High mileage (216,000 km) suggests wear-related issues. Diagnostic computer connection is essential to read fault codes and live parameters. Cleaning or replacing the EGR valve is a frequent recommendation. Some users report that older 1.6 HDi engines enter emergency mode if the first gear of the radiator fan fails. Other components checked in similar cases include air flow meter, turbocharger (including after regeneration), intercooler, air purge system, injectors, injection cubes, fuel pressure sensor, and turbo pressure sensor, but problems may persist despite replacements. Turbine hoses and hot side of the turbocharger should be inspected for proper operation. Sudden temperature changes can trigger emergency mode due to electronic faults. Glow plugs do not directly cause emergency mode in HDi engines. Expertise in French car diagnostics is advised due to system complexity.
TL;DR: Peugeot 307 1.6 HDi limp mode often caps revs to ~3,000 rpm; “engine would go into emergency mode” is the tell. Check radiator fan stage 1 first on older cars. [Elektroda, darekk310, post #21552258]
Why it matters: This FAQ helps 307 owners quickly identify limp‑mode root causes and avoid unnecessary parts swapping.
Quick‑Facts:
What does it mean if my 1.6 HDi won’t rev past ~3,000 rpm?
That symptom matches the ECU’s emergency mode. Owners describe no power and revs limited to about 3,000 rpm. On older 1.6 HDi, a failed first gear of the radiator fan can trigger this exact behavior. Verify that stage before chasing other causes. [Elektroda, darekk310, post #21552258]
What faults most often cause this no‑power limp mode?
Reported causes include a clogged DPF and too many failed regenerations. Also a dirty or sticking EGR, glow plug faults, and a stuck extinguishing flap. Confirm with a scan before replacing parts. [Elektroda, servgsm, post #17135036]
How do I start diagnosing at home?
Start with a scan and structured checks. “Attach the car to the computer, check the errors.” How‑To:
  1. Read fault codes and freeze‑frames with a scan tool.
  2. Review DPF/EGR related data if available; note any EGR or flap faults.
  3. Road‑test briefly, reproduce the symptom, then re‑scan to confirm direction. [Elektroda, servgsm, post #17135036]
My check‑engine light isn’t on; could it still be limp mode?
Yes. One driver reported the CHECK lamp flashed once during a trip, then went out, yet power loss persisted after traffic. Limp mode can occur with no active warning light. [Elektroda, kisia0809, post #17135052]
How can I quickly check the turbo hoses or boost at home?
With the engine idling, blip the throttle and feel the turbo and intercooler hoses. They should harden under load if boost builds. Split or loose hoses will feel soft and leak. [Elektroda, kuba20111, post #17135054]
Do turbo hoses always harden when revving on a 1.6 HDi?
No. A contributor noted the turbine hoses may not harden on this engine. Do not rely on feel alone for diagnosis. [Elektroda, servgsm, post #17135055]
Could the radiator fan cause the 3,000 rpm limit?
Yes. On some older 1.6 HDi cars, failure of the radiator fan’s first speed triggers emergency mode. The engine then lacks power and revs only to around 3,000 rpm. Check low‑speed fan operation. [Elektroda, darekk310, post #21552258]
Can bad glow plugs trigger limp mode on HDi?
No. As one expert put it, “Candles do not cause an emergency mode in HDi.” Prioritize EGR checks and vacuum integrity instead. [Elektroda, sly_1978, post #17135533]
Are worn glow plugs still risky even if they don’t cause limp mode?
Yes. Another member warns glow plug ceramics can break apart and damage the cylinder. They wear during running, not just at cold starts. Replace worn plugs promptly to prevent collateral damage. “Ceramics are able to crumble” was the warning. [Elektroda, servgsm, post #17135123]
Do I need live data or just fault codes?
Use both. A member advised checking errors and live parameters to locate restrictions or control faults. Examine EGR behavior and the turbo’s hot side if indicated. [Elektroda, jurekk55, post #17136356]
Will cleaning the EGR help restore power?
Often. Based on the described timing, an experienced member was “70% sure” EGR was sticking from soot. They added that cleaning the EGR might be enough. Seek a mechanic familiar with French diesels. [Elektroda, servgsm, post #17135069]
Does high mileage make limp mode more likely on the 1.6 HDi?
One owner reporting these symptoms had 216,000 km on the odometer. Treat that as a data point rather than a diagnosis. [Elektroda, kisia0809, post #17135058]
Is replacing EGR, MAF, turbo, sensors guaranteed to fix limp mode?
No. One case replaced the EGR, MAF, refurbished turbo, cleaned intercooler, checked injectors, and renewed fuel and boost sensors. The car still stayed in emergency mode with revs only to about 3,000. [Elektroda, uzn190391, post #21485987]
Could a vacuum leak mimic turbo or EGR faults?
Yes. Loss of negative pressure in the control system can produce the same no‑power, limited‑rev behavior. Check for vacuum issues if EGR seems fine. [Elektroda, sly_1978, post #17135533]
