How to check if the pressure valve on the cr pump is working properly.
klusek1712 55287 23
How can I check whether the pressure control valve on a common-rail pump is working properly?
The valve is ECU-controlled with a fill/pulse signal, so a proper check is to verify that the controller actually drives it and that rail pressure rises when it closes [#16183022][#16183700] A practical test is to unscrew the pressure control valve and crank the engine: fuel should flow out there while cranking; if it does not, the air/fuel supply system or feed pump is not supplying correctly [#16184133] The pump should build pressure when the valve is closed, and without engine running the valve is normally open so the low-pressure pump can fill the system [#16183700] Do not judge it only by applying battery voltage directly; one reply warns that the valve should not be powered that way, and suggests a short test load such as a 45 W bulb while checking ECU control instead [#16184030] If the valve closes on direct battery power but not during ignition/cranking, the problem is likely in the control signal or driver, not necessarily the valve itself [#16183838][#16184030]
  • #1 16182675
    klusek1712
    Rate: 42
    Hello, I need to know how to check it because the cr pump was supposed to fail (it did not feed fuel to the rail), replacing the valves did not give anything.
  • #2 16182707
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    What car, what symptom of non-smoking?
    Check the contents of the tank and ON filter.
  • #3 16182737
    klusek1712
    Rate: 42
    astra 1.3 cdti 90km 2006, half a tank of fuel, new filter and the pump pressure was measured behind the filter. And as for the symptoms, it just does not burn after unscrewing the cable on the pump, the fuel does not flow to the rail.
  • #4 16182802
    pawelht
    Help: 19
    Rate: 86
    Is there voltage to this valve? Maybe the wires are damaged?
  • #5 16182813
    klusek1712
    Rate: 42
    There is voltage, but how this valve works and whether this voltage is correct, I do not know.
    I connected the pump without the corsa sensor for a test and the fuel normally comes out of the pump.
    Added after 5 [minutes]:
    For this reason, I am also very interested in how this valve on the pump works because the mechanics want to replace everything for me.
  • #6 16183022
    tomasz0703
    Help: 69
    Rate: 489
    The valve is controlled by the fill pulse.
  • #7 16183137
    klusek1712
    Rate: 42
    Dude, if you can write it a little clearer because I'm not an electronics guy
    Added after 6 [minutes]:
    On the ignition with the plug removed from the valve, it is 11.70v, with 0.15v assumed, also 0.15v when trying to start.
  • #8 16183233
    Help: 1405
    Rate: 6430
    klusek1712 wrote:
    0.15v is assumed, also 0.15v when trying to start.
    That's ok, because it lowers blood pressure, not raises it.
  • #9 16183602
    klusek1712
    Rate: 42
    Crap, why does all the fuel go back? almost nothing to power the strip.
    And yet the pump in the tank gives 3.8 bar, at least that's what should fly to the rail.
  • Testing the pressure valve by computer-controlled actuation
    #10 16183700
    Daro122
    Help: 165
    Rate: 751
    Having a computer in the executive components, you can control the valve or even a connected light bulb in place of the valve. The pumps with which I had dealings produced pressure when the valve was closed. Without the engine running, the valve is open so that the working primary pump can fill the system up to the injector. Several times I started such pumps even on a makeshift assembled table, no philosophy.
  • #11 16183797
    klusek1712
    Rate: 42
    And do you know why I have two pumps with sensors that do not supply fuel to the rail and one without a sensor gives, sorry if I'm a bit confused but I just don't understand why not for pressure if the valve is open.
  • #12 16183810
    Daro122
    Help: 165
    Rate: 751
    There are some errors, because if the controller does not control the valve, no pump will work, there will be only the pressure of the initial pump, unless this pressure does not reach along the way. I had a case of contamination of the pump, which I did not find even after disassembling the pump, only giving fuel at a much higher pressure helped.
  • Mouth-blown valve fails; electrical power closes it briefly
    #13 16183838
    klusek1712
    Rate: 42
    I just did a mouth-to-mouth test, connected the spare valve to the ankle and started blowing into the valve on the ignition, but it will not close even for a moment, when I give it to the battery for a short time, it closes.
    Lambda probe error because it does not work and probably the coolant temperature sensor (because there is no liquid in the system). All the fuel goes back, if I clamp some wire on the tee, it only then puts fuel at the injection.
  • #14 16184030
    Daro122
    Help: 165
    Rate: 751
    With this battery, be careful because the valve should not be powered like this, by a 45W bulb and for a while, it's best to control the computer, the most suspicious control valve in the CR pump.
  • #15 16184053
    klusek1712
    Rate: 42
    I have already adopted three valves for this pump and the effect is the same. Could it be the driver's fault? if so, can the car electronics check it somehow.
  • #16 16184064
    Help: 1405
    Rate: 6430
    Why is the car not in the workshop yet?
  • #17 16184102
    klusek1712
    Rate: 42
    You know, I already had some cars and for them, I don't know where they get these prices from. Today I found out from a friend that he had an Astra like mine and sold it because his engine died, and one wanted 10,000 for the job, and the other 15,000 for the job.
    And the electronics has already been to me 3 times and the diagnosis came out too low pressure.
  • #18 16184133
    Help: 1405
    Rate: 6430
    Firstly, you need to know the pressure on the ramp, secondly, fuel should flow from the unscrewed pressure control valve after unscrewing it and while cranking the engine.
    If not, the air system or the feed pump does not feed.
  • #19 16184172
    klusek1712
    Rate: 42
    The computer showed about 5 bar, after unscrewing the valve, the fuel flows more when turning the engine, the wires on the injectors are loose, the pump from the tank gives 3.8 bar to the pump.
  • #20 16184178
    Help: 1405
    Rate: 6430
    Aren't your injectors leaking into the overflow?
  • #21 16184191
    klusek1712
    Rate: 42
    Injectors checked on the table and are ok.
    Added after 7 [minutes]:
    If that's what you mean.
  • #22 16187207
    klusek1712
    Rate: 42
    Maybe someone else can help.
  • #23 16187360
    _Megamax_
    Help: 29
    Rate: 131
    Sometimes it is not controlled by the pulse duty factor?
    Maybe the car has some non-series protection?
  • #24 16188119
    klusek1712
    Rate: 42
    It's more controlled that way, but that doesn't tell me anything. I think if it was somehow secured, the computer would show something there.
The discussion revolves around diagnosing issues with the pressure valve on a common rail (CR) pump, specifically for a 2006 Astra 1.3 CDTI. The user reports that the pump is not supplying fuel to the rail despite having replaced the valves and confirmed voltage to the valve. Various suggestions are made, including checking the voltage levels, ensuring the valve is functioning correctly, and verifying the pressure from the fuel pump. The importance of the valve's control mechanism and potential contamination issues are also highlighted. The user expresses confusion over multiple pumps failing to deliver fuel and seeks clarity on the valve's operation and the role of the car's electronics in diagnosing the problem.
TL;DR: Tank pump delivers 3.8 bar [Elektroda, klusek1712, post #16183602]; "It lowers pressure, not raises it" [Elektroda, Strumien swiadomosci swia, post #16183233] Verify 12 V supply, PWM duty ≤80 %, and rail pressure >250 bar before replacing the CR control valve. Why it matters: Misdiagnosing the valve can waste €300+ and keep the engine from starting.
• Supply voltage: 11.5–12.5 V at ignition feed [Elektroda, klusek1712, post #16183137] • Tank (lift) pump pressure: 3.8 bar nominal [Elektroda, klusek1712, post #16183602] • Start-up rail pressure required: 250–300 bar typical [Bosch CR Guide, 2014] • New metering valve cost: €60–€90 (OE) [Autodata Parts, 2024] • Valve retaining screw torque: 35 Nm (M12, typical) [Delphi Service Manual, 2018]
What does the pressure-control (metering) valve do on a common-rail (CR) pump?
It meters how much low-pressure fuel enters the high-pressure section. The ECU drives the valve with a pulse-width-modulated (PWM) signal; more duty opens it, less duty closes it, raising rail pressure [Bosch CR Guide, 2014]. "Without the engine running, the valve is open" [Elektroda, Daro122, post #16183700]
How do I check that the valve gets the correct voltage on an Astra 1.3 CDTI?
Back-probe the two-pin connector. You should read battery voltage (≈12 V) with ignition on and ≈0–1 V average while cranking due to PWM switching [Elektroda, klusek1712, post #16183137] No voltage means wiring or ECU fault.
What PWM duty-cycle does the ECU use?
Typical light-load duty is 20-40 %. During starting, the ECU may drop below 10 % to build pressure quickly [Delphi Service Manual, 2018]. A constant 100 % duty can dump fuel back and give <5 bar rail pressure [Elektroda, klusek1712, post #16184172]
Can I bench-test the valve safely?
Yes. 1) Connect the valve to 12 V through a 45 W bulb as a current limiter [Elektroda, Daro122, post #16184030] 2) Briefly energise; you should hear/feel a click. 3) Apply light air pressure—closed valve should block flow. Continuous battery feed without a limiter can burn the coil.
Why is all fuel returning to the tank instead of reaching the rail?
A stuck-open valve or zero PWM duty allows >90 % of feed fuel to bypass, leaving rail pressure at 5 bar [Elektroda, klusek1712, post #16184172] Faulty wiring, ECU ground, or metal debris holding the pintle off-seat are common causes [Bosch CR Guide, 2014].
What minimum rail pressure is needed for the engine to start?
Most CDTI engines need 250–300 bar before the ECU enables injection [Bosch CR Guide, 2014]. The forum car showed only 5 bar, well below the threshold [Elektroda, klusek1712, post #16184172]
Could bad injectors mimic a failed valve?
Yes. Excessive leak-off can drop rail pressure even with a good pump. Perform a return-flow test; flow difference should be <4 ml in 30 s at cranking speed [Delphi Service Manual, 2018]. The poster’s injectors passed a bench test [Elektroda, klusek1712, post #16184191]
How can I rule out wiring or ECU problems?
Swap the valve connector with a 21 W test lamp. Crank the engine: lamp should flicker. No light = wiring/ECU fault. Continuity check between ECU pin and valve shows resistance <0.5 Ω typical. Open-circuit or short means harness repair [Autodata Wiring, 2024].
What’s an edge-case that blocks pressure even with a good valve?
Microscopic debris can lodge in the pump inlet or bypass channel; normal disassembly may miss it. One mechanic restored pressure only after flushing with 6 bar external feed [Elektroda, Daro122, post #16183810]
Three-step quick test before buying parts?
  1. Measure lift-pump output (goal 3.5–4 bar). 2. Back-probe valve for 12 V and PWM flicker while cranking. 3. Read live rail pressure; if still <10 bar, clamp return line for 3 s—pressure jump points to valve leak. Replace parts only if all three fail.
How much does a new valve or complete pump cost?
Aftermarket Bosch-type IMV valves retail €60–€90 [Autodata Parts, 2024]. A reconditioned CP3/CP1 pump for Astra 1.3 CDTI runs €400–€550 plus fitting.
Is it safe to run the engine with the coolant sensor unplugged?
No. An open-circuit sensor reads −40 °C; ECU enriches fuel and may keep the metering valve open, flooding the return and risking wash-down [Bosch CR Guide, 2014]. Fix sensor before further pressure tests.
