Apator Meter Reading Guide: Understanding kWh for Tariffs with Example Photos
kobietaxxx 74910 7
  • #1 15785039
    kobietaxxx
    Rate: 30
    Hello. How do you read the amount of kWh for a given tariff, I have photos of both tariffs, but I do not know which numbers to write down because I am doing it for the first time, will someone help?
    Apator Meter Reading Guide: Understanding kWh for Tariffs with Example Photos Apator Meter Reading Guide: Understanding kWh for Tariffs with Example Photos
  • #2 15785137
    KlonAdam
    Rate: 18
    Accepted standard:
    1.8.0 Zużycie energii ogółem
    1.8.1 Zużycie energii w strefie dziennej
    1.8.2 Zużycie energii w strefie nocnej i weekendowej
    Additionally, after indicating the phasor diagrams (these arrows) you have a power factor cos? to improve.
    There should be no reactive power consumption Q. You have an overcompensated network, ie capacitive loads in the installation are present in a significant number.
  • #3 15785256
    zbich70
    Help: 1171
    Rate: 6664
    Why shouldn't it?
    If the supplier does not charge for Q (and does not charge for G and C1x tariffs), then what to worry about?
  • #4 15785258
    kobietaxxx
    Rate: 30
    I know what these codes mean, I don't know what values to write down.
    1.8.1 is 755.0 kwh? . and at 1.8.2 - 1377.8kwh? Does it work with these zeros? That's what I mean.
    zbich70
    Help: 1171
    Rate: 6664
    Yes.
    Leading zeros do not matter. Decimal kWh as well.
  • #6 15785273
    kobietaxxx
    Rate: 30
    So 755kwh and 1378 kWh round off?
    zbich70
    Help: 1171
    Rate: 6664
    Yes.
    PS. Watts in kilowatt hours should be written with a capital letter -> k IN h.
    It's by the way ... ;)
  • #8 15785285
    kobietaxxx
    Rate: 30
    zbich70 wrote:
    PS. Watts in kilowatt hours should be written with a capital letter -> kWh.
    It's by the way ...
    I know, I know, carelessness :) Thanks for the help
The discussion revolves around understanding how to read kWh values from an Apator meter for different tariffs. The user seeks clarification on which numbers to record from the provided photos of the meter readings. Responses clarify that the relevant codes for energy consumption are 1.8.0 (total energy), 1.8.1 (daytime energy), and 1.8.2 (night and weekend energy). It is confirmed that leading zeros and decimal points do not affect the recorded values, which should be rounded to 755 kWh for 1.8.1 and 1378 kWh for 1.8.2. Additionally, proper notation for kilowatt hours is emphasized.
