Interpreting PAFAL 16EC3rn/1 Energy Meter Readings: 700 or 70.0 kWh?
Wujek94 20613 16
Is the PAFAL 16EC3rn/1 meter reading of 700 the total consumption in kWh, or should it be interpreted as 70.0 kWh?
It is 700 kWh, not 70.0 kWh, because this meter displays the energy register without a decimal comma [#15312059] The relevant reading is the total energy register 15.8.0, and the meter can also show previous-period values marked with +DA, so it is worth checking that you are looking at the current 15.8.0 value [#15310496] [#15310576] One reply notes that when the consumption display is active, the OBIS code is shown above it, and if the value keeps increasing then it is the current reading rather than a past one [#15310912] With electric heating, such consumption can rise quickly, but the thread also suggests comparing against the handover report and monitoring the next 24 hours to rule out a meter problem [#15311173]
  • #1 15310323
    Wujek94
    The topic is simple and obvious for many people, so I apologize in advance for cluttering up the forum.
    I recently moved into a new apartment and today I checked the energy meter. I was terrified when I saw the last 3 digits, which indicated 700. I have no idea whether I should read it as 700kWh or 70.0kWh. Could I ask dear forum members for help?
    Once again, I apologize for the trivial question, but at the same time I can't believe it, I cry when I think that I could have used as much as 700kWh in 10 days, even with electric heating...
    Best regards and I hope for your understanding and help :)
  • #2 15310496
    m fox
    Help: 92
    Rate: 236
    How did you read it?
    Maybe it's from a previous period.
    0.0.0 - factory number of the counter
    0.9.1 - current clock time
    0.9.2 - current date
    15.8.0 - total energy
    15.8.1 - total energy in zone A
    15.8.2 - total energy in zone B
    15.8.3 - total energy in zone C
    15.8.4 - total energy in zone D
    15.6.0 - maximum power of the current period
    15.36 - number of exceeded maximum power in the current period
    15.2.0 - maximum accumulated power
    0.9.1 + DA - closing time of the previous period
    0.9.2 + DA - closing date of the previous period
    15.8.0 + DA - total energy in the previous period
    15.8.1 + DA - total energy zone A in the previous period
    15.8.2 + DA - total energy zone B in the previous period
    15.8.3 + DA - total energy zone C in the previous period
    15.8.4 + DA - total energy zone D in the previous period
    15.6.0 + DA - maximum power of the previous period
    15.36 + DA - number of times the maximum power was exceeded in the previous period
    0.1.0 - number of closed accounting periods
    0.2.0 - version of the counter program
    0.2.2 - tariff name
  • #3 15310576
    ferdek16
    Rate: 32
    The first basic in which Tariff G11, G12..
    The second issue is the single-tariff meter reading from item 15.8.0 - total energy
    Dual tariff meter 15.8.0 - total energy Sum of zones A and B
    zone A (first tariff) 15.8.1
    zone B (second tariff) 15.8.2
    It is possible that you read from item 15.8.0 + DA - total energy in the previous period, and that is why it turned out the way it did.
  • #4 15310801
    Wujek94
    I read what was shown regularly on the panel... I didn't click anything... it turns out it alternates with G11.
  • #5 15310912
    m fox
    Help: 92
    Rate: 236
    What kind of electric heating do you have, maybe that's what it took :)
    When the consumption is displayed (700 kWh), the code numbering is also displayed.
    Above, smaller numbers.
    And see if it increases, because if it is from the previous period, it will not increase.
  • #6 15310960
    Wujek94
    It increases... 15.8.0, heating Kospel EKO.LN2-8 or something like that... the power on the boiler did not increase above 4kW
  • #7 15311005
    m fox
    Help: 92
    Rate: 236
    Wujek94 wrote:
    I recently moved into a new apartment and today I checked the energy meter. I was terrified when I saw the last 3 digits which read 700.
    When you moved in, was it 0kWh?
    Maybe it's consumption from over a month, not 10 days :P
  • #8 15311006
    ferdek16
    Rate: 32
    If you actually have about 4kWh of power consumed, then you could have slightly consumed 700kWh during these 10 days, check whether the heating is not on all the time, check from today, e.g. if it's 40kWh, you have a problem
  • #9 15311093
    Wujek94
    The boiler runs non-stop, but the thermostat is set to around 21-25*C. The heating turns on from time to time. I feel a financially difficult month... or even several... I will also add that in about 6 hours it charged approximately 6 kWh
    The meter was installed a new one a few days after I moved in... so even more...
  • #10 15311173
    ferdek16
    Rate: 32
    Monitor energy consumption, you mention that the meter was recently installed, find the replacement report, check the condition of the meter. 1kWh per hour with electric heating is not much, but it still doesn't add up, let's say 24kWh per day for 10 days gives us about 240kWh, and you write about 700kWh, in fact we had frosts, maybe I had the thermostat raised to a higher temperature, I suggest checking it by next 24 hours, and then, if possible, turn off the heating completely and check the situation. Perhaps the meter is damaged - it happens even with new ones, the possible cost of sending it to the laboratory and checking it is payable if it turns out that the system is functional. If the system is damaged, the inspection is free of charge and you are entitled to a refund of the incorrectly charged payment.
  • #11 15311194
    Wujek94
    There is also an electric stove, but it is used quite rarely. I will add that both elements are powered by force.
    5kW was added in an hour and a half. I'm terrified...
  • #12 15312059
    m fox
    Help: 92
    Rate: 236
    Wujek94 is also gone :)
    He counted that it is or should be and has 10x less wear.
  • #14 15312690
    Wujek94
    I will cry. Its maximum power consumption is 3x8kW. I think I'll test the durability of the lighting poles with a string at work :D No, you idiot, but I'm still devastated. It draws approximately 20kWh +- 3kWh per day
  • #15 15313081
    m fox
    Help: 92
    Rate: 236
    It's still good that winter isn't harsh this year :)
  • #16 15316377
    Wujek94
    ... still :D Do you think that a washing machine with an area of 23 m^2 will be more economical?
  • #17 15316433
    m fox
    Help: 92
    Rate: 236
    You can use the washcloth to warm up, but not warm, such a surface.
    Moreover, I do not recommend leaving it on unattended or at night when you go to bed.
    Look on the Internet for videos of what happens to lamps that are connected for too long.
The discussion revolves around the interpretation of energy meter readings from a PAFAL 16EC3rn/1 meter, specifically whether a reading of 700 indicates 700 kWh or 70.0 kWh. Users provide insights into how to read the meter, emphasizing the importance of distinguishing between current and previous period readings. The conversation highlights the potential for high energy consumption due to electric heating, with users suggesting monitoring the meter's performance and checking for any anomalies. Concerns are raised about the accuracy of the new meter, and users recommend verifying the installation and condition of the meter. The author expresses anxiety over the high consumption rates, particularly with electric heating systems in use.
