Citroen C3 - The door insert rotates around and you cannot open the door?
Andrzej Gdz 34059 13
Why does the Citroën C3 door lock cylinder rotate freely without opening the door, and how can it be fixed?
The likely cause is a damaged paddle/linkage between the handle and the lock, not the key itself [#15834193] The fix is to remove the door trim and take out the insert/cylinder; a locksmith or car-lock specialist can repair it or fit a replacement and match it to your existing key [#15834430][#15836098][#15838015] In this case the insert was repaired after dismantling, with PLN 50 for removing/refitting the trim and insert and PLN 50 for the repair, which was much cheaper than the dealer’s diagnosis price [#15894458]
  • Rotating door lock cylinder prevents key from opening door
    #1 15833804
    Andrzej Gdz
    Rate: 96
    Hello !
    A problem has arisen.
    Namely, I wanted to check the door opening with a spare key and by inserting the spare key into the cylinder it was not possible to open the door. I treated the door insert with WD liquid and tried to open it again, but after a stronger treatment, now the insert with the key rotates around and the door still cannot be opened.
    Maybe one of the users had a similar case/problem and knows how to solve it?
    Andrzej
    P.S. I read that the cause may be a worn key, which is rather unlikely that 2 keys are worn. The keys also go all the way into the insert, and I rely on the fact that the keys can open the fuel filler without any problems and I looked at how deep they go into the fuel filler cap.
    They go practically the same deep into the door.
  • #2 15834193
    kaczor4011
    Help: 10
    Rate: 60
    You have a damaged so-called paddle. This is the connector between the handle and the lock.
  • #3 15834206
    Andrzej Gdz
    Rate: 96
    Hmmm, is it repairable?
    Can I buy such a part?
  • #4 15834218
    złowrogi_boncur
    Help: 84
    Rate: 420
    The insert needs to be replaced, maybe you can make one out of two, and if you replace it, you will have a new key.
  • #5 15834221
    Andrzej Gdz
    Rate: 96
    I was thinking about replacing the element of the insert that is functional, the so-called paddle/connector, and it would be possible to replace the entire insert.
  • #6 15834430
    szymon198312
    Level 30  
    Help: 126
    Rate: 890
    Because it's doable. It's best to go to a lock specialist and he will translate or adjust your key to the new cylinder.
  • Damaged paddle connector causes rotating Citroen C3 door insert
    #7 15835400
    Andrzej Gdz
    Rate: 96
    There is a problem at the dealership, they charged me a minimum of PLN 170 for diagnosis and then they agree on the phone whether we fix it or leave it as it was. The price may even exceed PLN 500, which is a shock!!!
    All I have to do is look for someone who can do car keys/locks. I went to one of them and he said that it happens when the door is not used for a long time and when it is opened only with a remote control via the central locking. Is it true, I have no idea?
    He said that it was a known fault and that in the future he should open it normally with the key at least once a month. He said it would be no problem to fix it, but unfortunately I had to provide the lock with a key.
    I'm not likely to take on the task of removing the door trim and disassembling the lock myself since I've never done it before.
  • #8 15836098
    invisibleman
    Help: 40
    Rate: 154
    Find a normal workshop in your area. Replacement inserts for this car are available (Valeo). 2 pieces with a key cost PLN 250-300. You won't pay much for replacement either.
  • Repairing the lock insert to retain the existing key
    #9 15836203
    Andrzej Gdz
    Rate: 96
    There is only one insert on the driver's side in the C3.
    This is not a solution because what about the fuel filler? Will I have to have the existing key for the filler cap and a new key for the new insert?
    From what I found out, the solution here is to remove the lock and a "specialist" who knows how to do it will make/repair the insert so that it will work with the existing key.
  • #10 15836331
    szymon198312
    Level 30  
    Help: 126
    Rate: 890
    Is it really such a big problem to remove the door trim? A few screws and latches.
  • #11 15837731
    złowrogi_boncur
    Help: 84
    Rate: 420
    And your friend doesn't remember the times when 3 keys for a car were the minimum? :)
  • #12 15837979
    Andrzej Gdz
    Rate: 96
    What do keys have to do with it?
    Are the keys intact?
    I have 2 keys from the new C3, one with a remote control and the other without a remote control, and this is the emergency key.
  • #13 15838015
    Mechanika Gorzów
    Help: 6
    Rate: 18
    My friend meant that people used to have one for the door, one for the ignition, and one for the trunk. Either way, dismantling the side panel and dismantling the insert is a very simple operation. The specialist will repair the cylinder for you or another one will match it to the key and that's it.
  • #14 15894458
    Andrzej Gdz
    Rate: 96
    Insert repaired;
    1. The cost of dismantling the door trim and the insert is PLN 50, including the installation of the insert and the door trim.
    2. The cost of repairing the insert is PLN 50.
    The total cost of this event is PLN 100.
    However, it is much less than at the ASO (of course I gave up on this ASO option) where they charged at least PLN 170 for the diagnosis alone!!!
The discussion revolves around a problem with the door lock insert of a Citroen C3, where the insert rotates but does not open the door. The user initially attempted to use a spare key and lubricated the lock with WD-40, but the issue persisted. Responses suggest that the problem may be due to a damaged paddle (connector) between the handle and the lock, and that the insert may need to be replaced. A lock specialist can repair or replace the insert, potentially allowing it to work with the existing keys. Users shared experiences regarding the costs of repairs, with some recommending local workshops over dealerships for more affordable solutions. It was noted that infrequent use of the key can lead to such issues, and regular use is advised to prevent future problems.
